My DIY Speaker Cable !
Discuss My DIY Speaker Cable ! at the DIY within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi All, Here's one of my DIY effort at speaker cable. This is 3 meter ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Do It Yourself (DIY) > DIY
Notices
DIY Discuss all audio, video, hi-fi and home theatre DIY stuff here.
Advertise Here
Reply
Thread Tools
  #1
Old 1st May 2008, 03:59 PM
soundsgreat's Avatar
soundsgreat is on a distinguished road
Hi All,
Here's one of my DIY effort at speaker cable. This is 3 meter cable as this enough for me ! Pics of the measurement taken from Phone cam Please bear it ( hadn't bought the digicam then)
The Cable is based on the twisted pair design but after lot trial and error and after lot testing with various pattern of braiding this is one which gave me the best result !
The main problem with the twisted pair cable's are the Figure of eight problem ( I think you already know this),so tried hard to avoid this by using 3 pairs of wires.
I have used 6 16 gauge pure Copper with Silver coating each capable of handling 6-8 amps of current, So the total of 36-48 Amps of current Each Cable is capable off !
Another main problem of DIY cable is the inductance and capacitance, if both are not kept at bay ! well expect some fireworks baby ! So I've managed to keep both under control..As least the Values as much better the result !
The Value's are as follows :
1) Inductance for 3 meter is 0.011 Mh
2) Capacitance for the 3 meter 10.30 Mfd
Consider this and also compare this with commercially available one's
Just to give a few examples, Kimber 4 TC is 44 pF/ft, 8 TC is 100 pF/ft, Cardas Quadlink 5C is 23 pF/ft and the Goertz starts at 500 pF/ ft and goes up from there !!
As with Inductance they are almost similar in range of .345uh /ft to .715uh/ft ( small change here and there from brand to brand)
So I think you get the idea ! any doubts or questions, you know the drill !
I've attached the pics ! so Enjoy my friends !
Regards.
Sponsored Links
  #2
Old 2nd May 2008, 05:42 PM
Anil kumar's Avatar
Anil kumar is on a distinguished road
Re: My DIY Speaker Cable !
Great job......lot of R&D.
Anil
  #3
Old 2nd May 2008, 06:38 PM
Hi Anil,
Thanks for checking out man ! Yes it did take lot of R&D to finally arrive at this !
But as always DIY is not an easy thing right ?? Did my best !
Regards.
  #4
Old 2nd May 2008, 07:16 PM
Anil kumar's Avatar
It's the interest, money & time. As you rightly said DIY is not easy thing....involves lot of homework & R&D
Quote:
Originally Posted by soundsgreat View Post
Hi Anil,
Regards.
  #5
Old 2nd May 2008, 08:29 PM
Hi All,
Am very sorry to inform you guys that the values of the cable ( Shown in the pics ) are not correct ! The reason is I had failed to take the initial Value of the meter to calibrate ( meaning the default value of the meter with any load )
After checking them today when replying to anil's post ( since he was the first one to reply) I noticed huge glitch in them ! As per that Value the capacitance and the inductance was huge and was in no way acceptable !! so as I had taken the pics long time back I thought to recheck the Values again just to re-confirm,then I realised the mistake I had made earlier !
The old Values, Inductance .011mh or .011 /ft (this is not as bad as the capacitance) Capacitance 10.3mfd (10300000000pf ) or 1030000000 /ft you know what I mean !!
So here's the new and correct Value !!
1)capacitance =0.013nf ( or 13pf for 3 meter) or 1.3pf /ft
2)Inductance =0.02mh for 3 meter or .002mh /ft
Iam very sorry once again for the mistakes !! I've attached new pics taken today so that its made clear that Am not bluffing or anything
  #6
Old 9th May 2008, 02:52 PM
Hi Guys,
Here's my new speaker cable effort !! its a 16 gauge wire braided 3 into positive and 3 into negative, Unlike last time where I had braided all 6 into 1,this time I've put them separately ( to test the results) i,e 3 braided into one for + and 3 into. Am still not sure whether I'll join both or run them separately to the speaker !! still in the R&D Zone
Once its done will post the results !! so far in their existing state I comapred it to the one Am using and it did make a small difference in sound,The mids opended a bit and the whole sound stage was bit more open and wide compare to the existing one (this could be right or could be wrong also as Its not properly burnt and might sound different after burning)
Anyway please checkout and give me some feedbacks ( need em badly )
Am unable to put the pics here for some strange reasons ( uploader pages just dies ) so here the link for the web Album
Picasa Web Albums - handsome - My New DIY Sp...
  #7
Old 11th May 2008, 03:00 AM
Hi Guys,
Here's the Speaker Cable that I did for my friend,this time I wanted to try something different and bit economical (he insisted ) so I only used a pair of wire per channel ( as opposed to 3 or 6 that I usually do!) these are 16 gauge pure oxygen free copper wire.
I've used double shielding this time for various reasons. first I've used the heat shrink tube for primary shielding for Airlocking the Cable and reducing the capacitance and inductance of the cable.Second an Nylon Braiding type shield to further reinforce the primary shielding and Avoid static,dust and a bit heat.
We compared the Cable with branded(will not name) cable that I had loaned him for time(until I gave him this).The sound stage was very wide and expensive with the newly made cable and the mids and highs we very open and sweet,the bass was full bodied and deep.
We played Anya latest Album and Ana morchora (something I forgot,sorry bout that) both imported Cds.
Here's the Pics of this Cable.
Please Please do post your comments and feedbacks (anything positive or negative doesn't matter) as this is why I do these things and this is one of the opportunity to correct myself of any mistakes done !!
  #8
Old 11th May 2008, 03:02 AM
Here's rest of the pics
  #9
Old 11th May 2008, 12:02 PM
Just remembered the Name of the artist its "NANA MOUSKOURI" And the as mentioned earlier the other singer is Anya,she has sung among others THE LORD OF THE RINGS Theatrical.
Regards.
  #10
Old 13th May 2008, 02:56 PM
Again a mistake the singer's name is Enya not Anya !! has any one heard of her or heard her songs ??
Regards.
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: My DIY Speaker Cable !
Thread Thread Starter Forum Replies Last Post
Component Video Cable vadiraj Audio & Video Cables 16 11th July 2008 12:23 PM
samsung hdmi cable Chacko Koshy Audio & Video Cables 6 2nd June 2008 10:56 PM
RCA connector for Speaker cable cruise_1982 Audio & Video Cables 0 19th April 2008 10:31 PM
speaker cable suggested rashmikant Audio & Video Cables 6 4th December 2007 10:49 AM
DIY Braid Audio Signal Cable punpeera Audio & Video Cables 0 11th December 2006 09:55 PM
Advertise Here
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
