| Discuss Making of 'MY Double D' guitar distortion at the DIY within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Project Log : -------------------------------- Name: My Double D -------------------------------- -------------------------------- The Idea : -------------------------------- I ... |
| Notices |
| DIY Discuss all audio, video, hi-fi and home theatre DIY stuff here. |
Thread Tools |
#1
Project Log :
-------------------------------- Name: My Double D -------------------------------- -------------------------------- The Idea : -------------------------------- I wanted to make a decent distortion pedal for my guitar , at a lesser expense . Also wanted some thing of small foot print. Online i got good reviews for the Double D . The simple design looked great , component count was less and .only 1 chip! CD 4049 ... power packed with six inverters . The URL [runoffgroove site]:Double D Then i checked the sound clips ..online both modes sounded as pretty nice . The kit should not cost more than 180Rs. leaving the cabinet and accessories . ------------------------------------------------------------------------------------------------ |
| Sponsored Links |
#2
DAY1: Making of 'MY Double D' guitar distortion
DAY 1
12:46 PM 6/26/2008> [Thursday] -today is the first day i just did the shopping[sp road] .. i hope all components are in stock components alone< 100Rs i think ![]() -getting the J-FETs was a pain ..i replaced the J201 with J 112 -i have laid one white paper on floor, placed the parts ..checked taken the pictures -read the runoffgroove.com author's page on my laptop ...the journey begins here ...! ------------------------------------------------------------------------------------------------ Last edited by kaushik; 30th June 2008 at 10:57 AM. |
#3
DAY2: Making of 'MY Double D' guitar distortion
9:38 AM 6/27/2008 >
DAY2 yesterday the following were purchased -Capacitor box , all the reqd pf s , it was lacking some of the reqd values soo i added the values .. still some are missing line 47kpf etc ,plan to purchase today ... -IC CD 4049 , J -FETs j112 [as a replace ment for the J109 ] ,vendor told it should match the actual one upto 90% -Ribbon wire 6 core , 1 mtr , for the pots , -Mic jack and socket , for testing phase i am using a cheap mic jack 10 Rs and Mic socket ![]() -Electorlytics 10uf and 4.7uf ,diodes 1N4007 [for the soldering iron ..heh not part of original double d] -A cutter and Stripper , to be used wire and leg cutter -A soap box ...wait its a temporary cabinet to hold the SIX POTS ,and the mic jack ..battery etc what so-ever - also a thin soap box is . easy to drill ... with the mosquito coils ..my new trick The already exiting parts - resistor box , still some missing values like 1 M , 2.2 M , 220K etc soo i have to add today -solder materials -hook up wire , wires with one solid strand -favicol, see below -Added the components to the board [yellow verro board for a test run] The disaster .. My cheap [25 rs] soldering iron died ! - so i i just the components are added to the verro board as per the plan in the website , This saves time ! - and i used *favicol* to hold them in place as i could not solder the components [usually after the legs are bent and shortened they tend to fall out and if it happens will be a bigg trouble ] -finally i was able to visualize how the assembled circuit will look after it is done to do: -Buy a good soldering iron , missing parts ,extra solder wires , shielded wires -then the solder the board -solder the ribbons to the pots ,fit in the soap box -test by connecting to the pocket AMP (...my secret tiny amp ..runs on 9V battery ) -Add a killer looking final cabinet ..keep watching Last edited by kaushik; 30th June 2008 at 11:00 AM. |
#4
Day3: Making of 'MY Double D' guitar distortion
9:34 AM 6/29/2008 SUNDAY
DAY3 - Today I finished the assemblibng part and soldered all the components - Just 2 Pots are conncted as I planned to test JIGGLE section - A MIC Jack as input and output through a MIC socket 1 st test - I have connected the unit to the 9v battery - connected my guitar and MINI AMP from the out put - "No sounds" !!! meaning 1 st test failed I have made a list of tests to diagnose the problem suspects > 1. DRY JOINTS ,My solder wire was very poor , all the time some coating settled n the Iron..i had to remove that coat so as to make the soldering come in contact with the solder wire ...otherwise it does not melt ' 2.MAY BE THE IC DIED : IC CD 4049 is a CMOS device..sensitive to temperature ... as i did lott of soldering in the past i avoided to use a IC base ... may be during the asembly the IC died 3. May be the Supply, MIC connections ,OUT put connections Diagnosis - Tested the FETs by isolating and applying +ve gate voltage using 100K resistor ,a test LED comnected between Source and Gnd. As i apply the +ve bias the LED glows bright ... soo FETs are alive ! - Visually checked the IC connections ....all ok .. -Next I will do some electrical checks... ... notes:i have taken the pics ... my phone cable is missing soo assume "PICS COMING SOON .." wanted : comments comments .. please |
#5
'MY Double D' guitar distortion in pictures so far
Tools and solder side
#6
Here is ......
LIST] >MY SOLDRON >COMPONENTS SO FAR ASSEMBLED >THE PARTS -GALLERY [/list] you can see the soldron logo ....not burnt up after heating [means original ]... parts including 2 pin connectors to make life easy .... ..i have kept some space between different circuit [ like the pre-boost ,inverters and post-mixer] sections so as to easily examine each one section in case of problems ... ![]() ....any suggestions?? Last edited by kaushik; 6th July 2008 at 10:19 PM. |
#7
Re: Making of 'MY Double D' guitar distortion
The Double D is paused due to my work pressure
... will resume soon ![]() Pics **n**Pics For non members the pics can be found here : ================================================ Flickr: bigbag899's stuff tagged with mydoubled ================================================ |
#8
great project. keep posting pics and details man. would love to see how it comes through. i might wanna try making one. also have you tried amp and effect modelling software?
keep up the great work!! k |
| Sponsored Links |
| Bookmarks |
| Tags |
| ciruits, distortion, diy effect, guitar, guitar effect |
| Thread Tools | |
Similar Threads for: Making of 'MY Double D' guitar distortion
| Thread | Thread Starter | Forum | Replies | Last Post |
| New ...and Making An HT for myself | pranab.beriya | Surround Amplifiers/Receivers | 48 | 17th June 2008 12:15 AM |
| Gods of Guitar in Vh1 | vadiraj | Music | 7 | 10th May 2008 12:11 AM |
| The making of a mini theatre (3) | vinay | My Audio/Video Setup | 0 | 3rd May 2008 01:22 PM |
| The making of a mini theatre (1) | vinay | My Audio/Video Setup | 0 | 3rd May 2008 11:08 AM |
| Naked Guitar by Earl Klugh | Mohan | Music | 1 | 26th September 2006 03:32 PM |
