HiFiVision.com - Audio Video Hi-Fi Forum
crossover parts
Discuss crossover parts at the DIY within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi Guys, Where do you guys get the crossover parts from. I am looking to ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Do It Yourself (DIY) > DIY
DIY Discuss all audio, video, hi-fi and home theatre DIY stuff here.
Advertise Here
Reply
Thread Tools
  #1
Old 28th November 2010, 05:14 PM
doors666's Avatar
Reputation points: 419
doors666 is just really nicedoors666 is just really nicedoors666 is just really nicedoors666 is just really nicedoors666 is just really nice
crossover parts
Hi Guys,
Where do you guys get the crossover parts from. I am looking to build a speaker soon and wanted to get cheap parts if possible for crossover, specially the expensive caps and inductors. I am on a really tight budget as I exceeded the costs in drivers. My friend will bring the drivers in dec end. If there is not much of a difference in costs or if india is more expensive for these, I might as well order from parts express/madisound itself. I can replace the cheap parts later with botiuqe stuff as and when budget allows.
thanx
Sponsored Ads
  #2
Old 28th November 2010, 05:26 PM
Moderator
Reputation points: 1030
GeorgeO has much to be proud ofGeorgeO has much to be proud ofGeorgeO has much to be proud ofGeorgeO has much to be proud ofGeorgeO has much to be proud ofGeorgeO has much to be proud ofGeorgeO has much to be proud ofGeorgeO has much to be proud of
Re: crossover parts
crisscross got his inductors wound recently in Hyderabad from a local vendor, worth checking from him.
  #3
Old 28th November 2010, 06:00 PM
doors666's Avatar
Re: crossover parts
Quote:
thanx george. is it a complicated process using a machine or it can be done by hand if you have an LCR meter. i will ping crisscross also for this. anyone in bangalore who does this.
what about the caps. i know u get caps at sp road, not sure how good/bad/suitable those are for crossovers.
  #4
Old 28th November 2010, 06:10 PM
keith_correa's Avatar
keith_correa is just really nicekeith_correa is just really nicekeith_correa is just really nicekeith_correa is just really nicekeith_correa is just really nice
Re: crossover parts
Erse Audio
  #5
Old 28th November 2010, 07:40 PM
grubyhalo's Avatar
Reputation points: 338
grubyhalo is a jewel in the roughgrubyhalo is a jewel in the roughgrubyhalo is a jewel in the roughgrubyhalo is a jewel in the rough
Re: crossover parts
Russian PIO's from eBay, perhaps?
  #6
Old 30th November 2010, 12:44 PM
Moderator
Re: crossover parts
Check with crisscross. I know that it can be done with a proper winder etc, but there is some trial and error involved in making them, and also one has to source good copper wire to do it.I suspect it is much easier to order them if one needs only a couple.
  #7
Old 30th November 2010, 01:45 PM
doors666's Avatar
Re: crossover parts
thanx guys for all the info. liked all the suggestions, the russian pio, erse etc are all good sources, but shipping ended up killing everything. eventually, I just ordered everything from parts express, with free shipping. Going by other routes, I probably would have saved 5 bucks, not worth the headache. The original BOM was also from PE, so atleast I know I am using what the designer used. Got to know some good resources though.
Please feel free to add more suggestions. I have a feeling I am going to need these for future projects, specially amps etc. Buying cheap parts for crossover has a distinct advantage of better utilizing money on drivers, and then later upgrading to better parts when budget allows. also takes care of upgraditis at a lesser cost.
  #8
Old 30th November 2010, 01:48 PM
grubyhalo's Avatar
Re: crossover parts
Which design are you going for?
  #9
Old 30th November 2010, 02:12 PM
doors666's Avatar
Re: crossover parts
overnight sensations for my desktop. small beginner project. with a sub though
  #10
Old 30th November 2010, 02:25 PM
grubyhalo's Avatar
Re: crossover parts
Looks good! BTW, what sub are you planning to pair it with and how are you going to power them? Good luck with the build!
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: crossover parts
Thread Thread Starter Forum Replies Last Post
crossover question jaudere DIY 34 14th December 2011 12:58 PM
Need parts for my Yammy avr rajatbhasin Surround Amplifiers/Receivers 5 27th September 2010 02:08 PM
HTPC – What parts? jazzysweet Home theater PC (HTPC) or media PC 3 19th September 2009 08:49 AM
Hard to find parts!! sasmit DIY 5 19th July 2009 11:33 PM
Shipping Electronic Parts from USA vianand AV Lounge 2 19th January 2009 07:14 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
