HiFiVision.com - Audio Video Hi-Fi Forum
Make Yourself USB DAC using BurrBrown PCM2902
Discuss Make Yourself USB DAC using BurrBrown PCM2902 at the DIY within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi all , Here is a DIY schematic and PCB layout .The circuit is simple ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Do It Yourself (DIY) > DIY
DIY Discuss all audio, video, hi-fi and home theatre DIY stuff here.
Advertise Here
Reply
Thread Tools
  #1
Old 5th November 2008, 03:42 PM
Reputation points: 535
kaushik is a glorious beacon of lightkaushik is a glorious beacon of lightkaushik is a glorious beacon of lightkaushik is a glorious beacon of lightkaushik is a glorious beacon of lightkaushik is a glorious beacon of light
Hi all ,
Here is a DIY schematic and PCB layout .The circuit is simple and uses Burr-Brown PCM2902 .
Uses:
It is suitable for PC/laptop to AVR connection
or PC/laptop to Integrated amp using analog out.
All components are available at RS COMPONENTS INDIA : Welcome to RS On-line
DAC chip is about 650Rs .I suggest one should use better capacitors /resistors for smooth frequency response ....
Features:
INPUT ---> USB
OUTPUT -----> SPDIF
and Analog Out
collected from : Pavouk's homepage
Link :Click
Sponsored Ads
  #2
Old 5th November 2008, 05:50 PM
Reputation points: 32
Muthusami S is on a distinguished road
Re: Make Yourself USB DAC using BurrBrown PCM2902
Hi Kaushik,
This is useful information. I liked your posts, which are always useful and cost effective. Keep it up.
Quote:
Originally Posted by kaushik View Post
Hi all ,
Uses:
Features:
INPUT ---> USB
OUTPUT -----> SPDIF
and Analog Out
Link :Click
  #3
Old 7th November 2008, 04:52 PM
Thanks muthu... still more to come !
  #4
Old 17th December 2008, 04:50 PM
Reputation points: 92
Surrealistix will become famous soon enough
How much would it cost to get this PCB made to order in India?
  #5
Old 17th December 2008, 10:11 PM
spirovious's Avatar
Reputation points: 1951
spirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant future
Quote:
PCB is very cheap.
I got 3 inch*2 inch for Rs.5 only.If you ask to design,cost will increase.
I maid 5.1 switcher(input selecter) with it.
  #6
Old 18th December 2008, 08:16 AM
Yes PCB is cheap....however rs electronics prices are little high [approx30%]
For PCB there is OmElectronics in bangalore ...such small PCBs wil cost 5 to 10 Rs with green masking.
Else see my PCB making thread..u can make it at home......just a few supplies u need .
  #7
Old 18th December 2008, 08:48 AM
spirovious's Avatar
Arrow Re: Make Yourself USB DAC using BurrBrown PCM2902
Hi all ,
Uses:
Features:
INPUT ---> USB
OUTPUT -----> SPDIF
and Analog Out
Link :Click
Thanks,
I have few Qs-
1.Does this require special driver to get recognized by Windows?
2.Where is Burr-Brown PCM2902 chip available?Mumbai?
3.Can we actualy develope ext DAC without USB?
ie.instead of usb we can set 5v adaptor connection & coax input in place of
USB data points?
4.Does it give stereo output?
check this also-http://www.pavouk.org/hw/spdifdac/en_index.html#circuit_description
  #8
Old 19th December 2008, 04:41 PM
Reputation points: 18
dali is on a distinguished road
Hello Mr.Kaushik ,
Very informative and i am in the process of making one for my computer ( not now , but some times later )
Thankyou
Vijay
  #9
Old 19th December 2008, 05:23 PM
Thank you cranky,
better DAC threads are welcome and your extertise will help the new DIY audiophiles .
actually i must admit here that the circuit is not yet being built by me [in the process of sourcing the components at a lesser price]
Due to component sourcing problems in india i wanted to post a DAC that was simple and uses less components .
As cranky said for top performance there are several mods may be needed .. external Power Supply,Ground Layout changes etc to name a few .
NOTE:PCB layout is not upto scale use these for actual size
PS file :http://www.pavouk.org/hw/usbdac/usbdacbrd.ps
or Eagle file :http://www.pavouk.org/hw/usbdac/usbdac2.brd
Let me check a solution for the 0.5mm track width issue ,as per my sources local PCBs minimum width is 1 mm....how about an IC socket....
update :my diy brain has come up with an idea,i will use an extension board as shown in the pic ....the board will make possible for a greater track spacing.
Vijay,
Forum is waiting for your DAC buit thread...
I am very glad that people are coming forward to build one of these .
  #10
Old 19th December 2008, 10:13 PM
spirovious's Avatar
Thank you cranky,
Vijay,
I can tell you two ways to fit DAC-
1.RS online r providing IC/DAC sockets soldered on PCB which can be fitted
on PCB.
2.You can solder DAC on regular PCB & try to destroy PCB tracks inbetween
them with tools.
The Following User Says Thank You to spirovious For This Useful Post:
Reply
Bookmarks
Tags
usb dac pcm2902
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Make Yourself USB DAC using BurrBrown PCM2902
Thread Thread Starter Forum Replies Last Post
Help me make sense of this (laughs) gobble Amplifiers 26 26th October 2009 05:30 PM
Make Room For Acoustics vinay AV Enhancers & Room Acoustics 12 1st July 2009 12:00 PM
How to make regionfree? spirovious Home theater PC (HTPC) or media PC 6 20th February 2009 07:24 PM
Onkyo SR605 Help (US make) planetavi Surround Amplifiers/Receivers 12 31st August 2008 12:23 PM
importing onkyo 705 - us make zelda_venom Surround Amplifiers/Receivers 8 16th April 2008 04:47 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
