Coaxial Digital Audio Outputs
Discuss Coaxial Digital Audio Outputs at the DVD players & DVD/hard-disk recorders within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hai, Could we connect a coaxial out of a dvd player (with 2 channel audio ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > AV Sources > DVD players & DVD/hard-disk recorders
DVD players & DVD/hard-disk recorders DVD players/recorders and soon available HD-DVD/Blueray players
Advertise Here
Reply
Thread Tools
  #1
Old 29th August 2008, 02:36 PM
ajithlal is on a distinguished road
Hai,
Could we connect a coaxial out of a dvd player (with 2 channel audio out) to coaxial in of an av reciver to get benefit of 5.1 channel dts/dolby from av receiver output?
regards
Ajithlal
Sponsored Links
  #2
Old 29th August 2008, 02:58 PM
vj_box's Avatar
vj_box is on a distinguished road
Re: Coaxial Digital Audio Outputs
hi ajith,
can you tel the dvd player brand?
or are you asking this as a general question?.
IME,if the dvd player has dolby,dts compatibility,yes you can connect it to a A/V reciever with either a optical or coaxial cable and benefit from 5.1 surround sound.
hopes this makes sense.
Vj
  #3
Old 29th August 2008, 04:06 PM
Dear Vj,
Consider samsung P180 for the DVD palyer. It has Dolby digital soround sound. But not suppert DTS.It seems doesnt support vcd format also.
Pls check.
ajith
  #4
Old 29th August 2008, 05:18 PM
vj_box's Avatar
mmh,in that case,you can experience just the DD i guess,i have seen a lg player which says,just DD compatibility,but i saw the Receiver was able to decode DTS from it.Any way lemme double check.
Vj
  #5
Old 29th August 2008, 05:24 PM
Moderator
venkatcr has much to be proud ofvenkatcr has much to be proud ofvenkatcr has much to be proud ofvenkatcr has much to be proud ofvenkatcr has much to be proud ofvenkatcr has much to be proud ofvenkatcr has much to be proud ofvenkatcr has much to be proud ofvenkatcr has much to be proud ofvenkatcr has much to be proud of
Ajithlal:
The coaxial digital out is considered to be better than optical, and will give you full 5.1 surround sound to be decoded by the AVR. Do not worry about DTS decoding. If you connect via coaxial digit, the DVD will send the data is 'raw' format and the AVR will do the decoding.
Regarding VCD, almost all DVD players will play VCDs. The specifications may not mention VCD in particular. VCD is a comparatively simple format and all DVD players should be able to handle it. If you have not yet purchased the DVD player, just take a good quality VCD and try it before purchasing it.
  #6
Old 30th August 2008, 07:42 PM
vj_box's Avatar
Hey Venkat,just to clarify,as per my knowledge,i guess optical is one step ahead of the coax,as the signals are transferred as light instead of electrical signals right?
What i also know is optical is better for short interconnects,as they also tend to get weaker in the long run and are more prone to external hazards.
Or i might also be wrong.Just clarify.
Vj
  #7
Old 30th August 2008, 10:43 PM
Moderator
VJ:
First, actually optical is better for longer runs (say over 50 feet). But for connecting a source to a amp, the distances (at least in our homes) are around 6 feet max. For these lengths, coaxial or optical should theoretically give identical performances. Optical cables could also minimize RF noise as they are immune.
Some people say that a CD signal which is an electrical signal is converted to light and reconverted, leading to possible degradation. This may not be true as the signal being transmitted (PCM or bitstream) is sampled at low frequencies (44-48KHz) and thus are more immune to conversion hassles. .
The only issues with optical are it's fragile connections and higher price for the cable. A bit of dust in the connection point could affect the movement of the light beam. If you notice all optical connection points have a small dummy plug. This should always be plugged-in unless you are using an optical cable.
The general feeling in the market is the co-axial is preferable to optical. That is why I said, coaxial is 'considered' to be better. For all practical purposes (and short runs) there should be no difference at all.
The Following 2 Users Say Thank You to venkatcr For This Useful Post:
abhijit15 (21st September 2008), vj_box (1st September 2008)
  #8
Old 21st September 2008, 03:31 PM
abhijit15's Avatar
abhijit15 is on a distinguished road
coaxial is always better than optical,it sound great with good branded coaxial cable.and i think it depend on qulity of boyh cable
  #9
Old 21st September 2008, 09:04 PM
illusion will become famous soon enough
Quote:
Define Quality Please . I use a local coaxial cable and it works great . I tried my friends $70 Monster coaxial cable and there was no difference sir .
I also tried using a $10 optical cable (now fixed to my htpc sound card) and again the same output. No noticeable difference at all.
  #10
Old 21st September 2008, 09:10 PM
abhijit15's Avatar
i know there is little diffrance but coaxial is always better than optical mr.venkat also post same .coaxial cable with good qulity of coper is better
you notice the diffrance of MID frq. will improve
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Coaxial Digital Audio Outputs
Thread Thread Starter Forum Replies Last Post
Coaxial or Analog L&R Rohit Verma Digital Cable and DTH 3 26th February 2009 09:18 AM
philips ht 3569 - optical out to coaxial in - help needed vint Home Theater In A Box 42 5th February 2009 02:49 PM
optical to coaxial switch vint Audio & Video Cables 12 26th January 2009 11:22 AM
Receiver with 2 HDMI outputs. jackpatel Surround Amplifiers/Receivers 4 30th October 2008 05:11 PM
Pioneer DV600 audio with coaxial audio cable? Ajit DVD players & DVD/hard-disk recorders 2 8th August 2008 03:46 PM
Advertise Here
Copyright © 2006-2010, HiFiVision.com All Rights Reserved.
Recommended Websites - www.CameraVision.in
