HiFiVision.com - Audio Video Hi-Fi Forum
Which Washing powder/liquid detergent do you use with Top Loading Washing machine
Discuss Which Washing powder/liquid detergent do you use with Top Loading Washing machine at the General Lounge within the HiFiVision.com - Audio Video Hi-Fi Forum; Ok guys wanted to check from people who use Top Loading Washing machine which washing ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Community Centre > General Lounge
General Lounge Discuss anything not related to audio video here.
Advertise Here
Reply
Thread Tools
  #1
Old 3rd May 2012, 08:40 PM
andy78's Avatar
Reputation points: 33
andy78 is on a distinguished road
Ok guys wanted to check from people who use Top Loading Washing machine which washing powder/detergent Liquid do you use?
I have tried both liquid and the powder variety not too happy with the results.
Also what is the purpose of the liquid which we get separately called Softener?
Any suggestions on this would be great!
Sponsored Ads
  #2
Old 3rd May 2012, 10:00 PM
Reputation points: 542
avidyarthy is a glorious beacon of lightavidyarthy is a glorious beacon of lightavidyarthy is a glorious beacon of lightavidyarthy is a glorious beacon of lightavidyarthy is a glorious beacon of lightavidyarthy is a glorious beacon of light
Re: Which Washing powder/liquid detergent do you use with Top Loading Washing machine
We use either Ariel or Surf Excel Blue at home for our top loading semi-auto LG machine. Fair results.
Water quality is important. Hardness must be less than 500 (forget the units) and TDS (total dissolved solids) should be less than 1000 (again, forgetting the units).
Softner would significantly take care of the water hardness, but can do nothing if the TDS is high. Then, only DM (de-mineralized) water or RO (reverse osmosis) water is effective. Sad luck then, since only manufacturing units can afford those. Lesser TDS water (between 500 and 1000) can somewhat be taken care of by de-alkalizers.
Water is also sometimes contaminated by Iron compounds. Leads to 'reddishness' on clothes. Iron filters are readily available, though.
  #3
Old 3rd May 2012, 10:45 PM
utkarsh's Avatar
Reputation points: 74
utkarsh will become famous soon enough
generally water supplied by municipal corporation take care of hardness and iron level. If anyone using borewell water then TDS & Iron level can be high for that chemicals are coming which has to be added during washing.
Unit of all parameters is ppm as CaCO3.
I use Henkomatic for my front loading washing machine.
Sent from my iPad using Tapatalk HD
  #4
Old 3rd May 2012, 10:55 PM
Reputation points: 738
hemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to behold
1) Try changing washing machine cable by OFC cables and hospital grade plug.
2) Upgrade motor ,try using speciality motors with silver claddoing
3) Remember water pipes are directional - ie water flow from tap to washing machine
4) Try balancing the washing machine by sprit level or laser beam
5) Re - cap your washing machine
6) Try to change some transitors by valves..
The Following 5 Users Say Thank You to hemantwaghe For This Useful Post:
  #5
Old 4th May 2012, 12:44 AM
Flash's Avatar
Reputation points: 585
Flash is a name known to allFlash is a name known to allFlash is a name known to allFlash is a name known to allFlash is a name known to allFlash is a name known to all
If your main objective is to not get caught with lipstick marks on your shirt when you get home .
start a bonfire and BURN IT.
The Following 2 Users Say Thank You to Flash For This Useful Post:
  #6
Old 4th May 2012, 01:11 AM
svenkateshsmart's Avatar
Reputation points: 254
svenkateshsmart is a jewel in the roughsvenkateshsmart is a jewel in the roughsvenkateshsmart is a jewel in the rough
oh my God, am I logged into HFV?
  #7
Old 4th May 2012, 01:14 AM
Flash's Avatar
Quote:
What next
Tips to get to first base
  #8
Old 4th May 2012, 07:42 AM
manoj.p's Avatar
Reputation points: 681
manoj.p is a splendid one to beholdmanoj.p is a splendid one to beholdmanoj.p is a splendid one to beholdmanoj.p is a splendid one to beholdmanoj.p is a splendid one to beholdmanoj.p is a splendid one to behold
Quote:
Originally Posted by Flash View Post
What next
That we won't mind sharing.
  #9
Old 4th May 2012, 09:09 AM
santhosh's Avatar
Reputation points: 1171
santhosh has much to be proud ofsanthosh has much to be proud ofsanthosh has much to be proud ofsanthosh has much to be proud ofsanthosh has much to be proud ofsanthosh has much to be proud ofsanthosh has much to be proud ofsanthosh has much to be proud ofsanthosh has much to be proud of
Hemant,
You forgot a few mate:
Use spikes instead of Castor Wheels (3 Spikes work better than 4)
Use diluted isopropyl alcohol instead of detergents
Dampen the lid, they are usually flimsy and cause unwanted resonances
Upgrade bearings on the motor
The Following User Says Thank You to santhosh For This Useful Post:
  #10
Old 4th May 2012, 09:51 AM
manoj.p's Avatar
and don't forget the power cord. Otherwise the motor will not have smooth rotation, causing the clothes to have very subtle stains/uneven cleaned clothes which only a true audiophile can see. Also, the power cords are shown to have some coloration.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Which Washing powder/liquid detergent do you use with Top Loading Washing machine
Thread Thread Starter Forum Replies Last Post
Need Help with Front load washing machine pungan General Lounge 15 14th March 2012 01:50 AM
Step up Transformer loading Calculator Rajiv Phono/Turntables 0 22nd July 2010 04:56 AM
Suggestion for Fridge & Washing Machine tellranga AV Lounge 37 16th April 2010 07:30 PM
Pioneer DV 600: Slow loading of AVI via USB alladinkachirag Blu-ray/DVD players & DVD/hard-disk recorders 10 4th August 2009 11:03 AM
Washing Machine Woes... moserw AV Lounge 50 9th June 2009 08:38 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197
