HiFiVision.com - Audio Video Hi-Fi Forum
Review of Sharp AH-XP18MV 1.5Ton Eco-Inverter Air Conditioner
Discuss Review of Sharp AH-XP18MV 1.5Ton Eco-Inverter Air Conditioner at the General Lounge within the HiFiVision.com - Audio Video Hi-Fi Forum; Originally Posted by Coolharry Hi Rishi, After remaining indecisive regarding selection of inverter AC between ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Community Centre > General Lounge
General Lounge Discuss anything not related to audio video here.
Advertise Here
Reply
Thread Tools
  #101
Old 13th May 2013, 09:49 PM
rishiguru's Avatar
Reputation points: 276
rishiguru is a jewel in the roughrishiguru is a jewel in the roughrishiguru is a jewel in the rough
Re: Review of Sharp AH-XP18MV 1.5Ton Eco-Inverter Air Conditioner
Quote:
Originally Posted by Coolharry View Post
Hi Rishi, After remaining indecisive regarding selection of inverter AC between LG BS-Q186C8R2 and Sharp AHXP-18MV finally purchased Sharp AHXP-18MV today.
Congratulations for the purchase. May you enjoy long years of cooling bliss.
Although Cooling range and EER of LG model is marginally better but input power is higher than the Sharp model. Further the manufacturing defect in the OD unit in case of LG as posted on several threads has also been a deterant.
I am quite sad at LG's current build quality. It seems LG have dropped their Inverter AC's product quality from BEST to WORST in no time with a hefty reduction on price. It has been just about a year and a half that my friend got the LG 1.5 Ton (BS-Q186C7M1).
The older 1.5 Ton LG Inverter (Model No: BS-Q186C7M1) unit over which my previous assessments were based used to be 10 grand costlier than this new model and had much better build quality with no issues. My friend is super happy with this old unit. The indoor unit also used to be much more advanced than the current one in having double horizontal louvers to precisely control airflow and many more types of advanced air filters were provided. It also used to come with free installation kit.
The current models IDU is more of a knocked down version of the former model in having a single top hinged horizontal louver and Plasmaster. It seems a copycat of the unique top hinged louver topology of Sharp along with its Plasmacluster. Also it does not come with installation kit any more.
In other words LG have cut corners to be in the competitive Inverter market. Though LG have slightly better performance than Sharp in the 1.5 Ton category, no more can I say they come with equal built quality. We have seen issues with broken louvers of IDU’s. Almost every forum member here or in other forums are facing some kind of manufacturing or design issue where the ODU fan grill is touching the fan which amazingly persists in almost all their current Inverter models and in extreme cases busted new ODU's !!!
Can you throw some light on the installation regarding the lenght of pipes from ID to OD unit . Is the whole lenght of Cu pipe provided in the kit is to be used or can be reduced if site conditions permit. Else if they are rolled and not cut will it affect the cooling.
The pair of refrigerant pipes as provided is of 4 meters in length. Ideally the pipes should traverse the shortest distance from IDU to the ODU having minimum number of bends. Shorter lengths are better. That being said the minimum pipe length for Sharp AH-XP18MV is 1 meter while the maximum chargeless pipe length can extend to 7.5 meters. Do not roll the pipe. Cut it to the minimum desired length required which should be between 1 ~ 7.5 meters.
The Following User Says Thank You to rishiguru For This Useful Post:
Sponsored Ads
  #102
Old 14th May 2013, 10:17 PM
Reputation points: 10
Coolharry is on a distinguished road
Hi Rishi,
Thanks for responding so promptly.The Co Engineer insists that the refrigerant gas filled accounts for the volume of 4m pipes provided alongwith the unit. In case the pipes are decimented it would lead to loss in cooling as gas has to transgress 4m distance for proper cooling. What do you suggest?
  #103
Old 14th May 2013, 10:34 PM
Hi Rishi,
Thanks for responding so promptly.The Co Engineer insists that as per the Co design the refrigerant gas that is filled up includes the volume of 4m pipes as well.The gas has to transgress a distance of 4m for proper cooling.In case the pipe is cut I will have to compromise on cooling for which Co shall not be responsible.What do you suggest?
  #104
Old 14th May 2013, 10:35 PM
rishiguru's Avatar
Hi Rishi, Thanks for responding so promptly.
You are most welcome.
I suggest you you stick to the plan of shortest pipe. Mind you it must be between 1 ~ 7.5 meters in your case. The installers might not have proper tool to cut those pipes.
Anyway keeping the supplied 4 meter copper pipes will not be detrimental to its performance unless bend. The refrigerant gas will make two/three useless loops before reaching the ODU.
Here is an example:
  #105
Old 16th May 2013, 08:03 PM
[QUOTE=rishiguru;496525]You are most welcome.
Thanks Rishi !
  #106
Old 19th May 2013, 09:13 PM
rajarshigh@gmail.com is on a distinguished road
After reading forums and specially this one, i have finalized Sharp 13LV. I am getting quotes of around 36500 from Shahs and 37000 from Viveks.
How is Sharp after-sales service in Chennai? A specific question to Sharp AC owners. I will be purchasing the AC next weekend.
  #107
Old 19th May 2013, 10:07 PM
akb akb is offline
Reputation points: 12
akb is on a distinguished road
Thats steep. I bought it for 28.5k + (1.5K installation) in Delhi. I am not using any Stabilizer with it though which might be included in your price.
  #108
Old 19th May 2013, 10:25 PM
Quote:
Yes that is steep, even though it includes installation and stabilizer.
  #109
Old 19th May 2013, 10:41 PM
How is your LV performing by the way? How big is your room
  #110
Old 20th May 2013, 11:02 PM
Hi friends, please let me know the Sharp service for ACs in Chennai. I need to buy this Friday/Saturday.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Review of Sharp AH-XP18MV 1.5Ton Eco-Inverter Air Conditioner
Thread Thread Starter Forum Replies Last Post
Help!!! Power conditioner from Furman venk61176 Audio Video Accessories 0 5th September 2012 11:23 AM
power conditioner with sub manu4panjab Speakers 13 20th July 2010 08:11 PM
power conditioner aji.kumar61 Blu-ray/DVD players & DVD/hard-disk recorders 1 19th November 2009 05:49 PM
Sharp 32 LCD ( LC-32A33M ) ,Worth Buying Sharp ? Lost Television 4 17th February 2009 03:33 PM
AV Rack & Power Conditioner in DELHI spycatcher Audio Video Accessories 1 29th August 2008 12:24 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197
