| Discuss Need your suggestion in buying a package home theater system for home purpose at the Home Theater In A Box within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi, I am interested to buy a home theater system for a small 2 or ... |
| Home Theater In A Box Home Theater In A Box type units are all-in-one devices that are a Receiver, DVD Player, Amp, and speakers all in one unit. |
Thread Tools |
#1
Hi, I am interested to buy a home theater system for a small 2 or 3 BHK apartment. I have been reasearching on this and drilled down on Onkyo HT-S3100 5.1 home theater. Could you please if this is a good choice or i can have some thing better in the similar price? Purpose is pure home viewer and listen and i have a sony HDMI LCD 32 inch screen as well. Also i would like to connect my computer to avoid usage of DVD or VCD. thanks in adance.. regards, Piyush |
| Sponsored Links |
#2
Re: Need your suggestion in buying a package home theater system for home purpose
Piyushcom:
Though Onkyo is a good brand, please look at options from Denon, Yamaha Sony, and Panasonic also. All of them offer decent HT packages. Reviews are only the first step that help you set aside the flak. The next and most important step is to audition the system. Take a few DVDs and music CDs you like and are familiar with and spend a few evenings visiting retailers who have demo rooms. Once you do this you will be able to decide what you want based on which system sounds good to you. Remember as you visit the retailers, you will be shown more options and may get confused. So fix your budget and the system combination that you want to live with and stay focused. If you get into separates - that is AVR and speakers purchased separately - there is an ocean out there. Always base your purchase decision based upon your own ears. Cheers |
#3
Thanks VenkatCR,
Thats really a great and encouraging response. I have not been able to find retailers who has denon or Yamaha HT systems. I got a demo of Sony but the one i liked was completly out of my budget so had to come back to onkyo.If you know a Denon or Yamaha dealers in pune pls let me know. Thanks & regards, Piyush Sharma |
#4
Piyushcom:
Please consider also the suggestion of VenkatCR, if it's within your budget, you won't regret it: "If you get into separates - that is AVR and speakers purchased separately - there is an ocean out there." |
#5
Here are the Pune contact details as printed in AV Max and WhatHifi
Onkyo 256, Boat Club Road Near bund Gardens 3231 0478 Yamaha Audio Visual & More 5609 6339 Maharashtra Electronics 2634 7681 Denon Sound & Vision 98220 88022 2635 7647 AV Excellence 2612 7000 |
#6
Thanks a lot VenkatCR,
Can you also suggest the mix n match combination of Amplifier / reeciver , sub woofer and 5 speakers? I would go to these dealers and try to have a demo. Regards, ~Piyush |
#7
Piyush,
As I said before that is a large ocean that will drag you in all directions. Unless you have a lot of time and patience, best is to go in for a HT Package. believe me it took me 18 months to decide my system, and by that time, technologies had changed. And you have to consider the budget. With power conditioning, speakers, cables, DVD Player, etc, you could easily run up 100K to 150K for a entry level system. If you are yet interested, SIGH !!!!! Here we go again !!!!!!
#8
No way.
, My budget is 25 K only..So it would be better to go for a HT package system. See i am classical vocal music fan and any ordinary system supresses instrument quality. So my idea was to have a decent system that will suffice my set of requirements. Anyways thanks much, let me know if you can suggest some good package HT in my budget.. Cheers, |
#9
That is a tough call. 25K? Hmmmm. Ok. here we go. What I have done is take WhatHiFi and AV Max issues from Jan 2008 and listed their reviews of HT packages I have seen around that price. The comments are purely those of WhatHiFi / AV Max.
1. LG HT 902TB Price 24,900 FOR: Good Pictures, even better sound, build and looks AGAINST: Not much given the price. VERDICT: A stellar system for very little money, 2. Samsung HT-X30 Price: 13,900 FOR: Great build and design. decent performance. Wireless upgrade options AGAINST: Lacks the power, scale, and pitch of the best in class VERDICT: A worthwhile small room system, but you can get more living room ooomph from the LG 3. Panasonic SC-PT850 Price: Unknown FOR: Good Specs AGAINST: Disappointing picture, rivals offer more sonic detail and punch VERDICT: An OK system but rivals have a serious edge 4. Sony DAV-DZ750K Price: 26,990 FOR: Build and design. Good performance. AGAINST: Slightly forward treble. Picture beaten by the LG VERDICT: A good system but not best in class. 5. Samsung HT-TX25 Price: 19,900 FOR: Flexibility. Convincing sound and picture AGAINST: No HDMI, and not much else VERDICT: A very decent all rounder, but not class leader. 6. Sony DZ855KW Price. 39,990 FOR: Good picture, stylish speakers, wireless flexibility AGAINST: Fussy infrared signals to rear. Premium price. Poor Auto configuration. VERDICT: A system that offers good picture and sound but has flawed wireless convenience. 7. LG HT762TZ Price: 29,990 FOR: Smart styled and with good specs. Can upscale to 1080p. Good integration. Fast sats. AGAINST: Some noise to picture. Treble sounds a little detached. VERDICT: LG's design art range is shaping up nicely indeed. This is a solid cinema system for under 30,000. 8. Onkyo. HT-SR800 (B) Price: 45,000 This is AV Max award winner for 2007-2008. AV Max has this to say. The SR 800 is much more promising than the S990 even though it is not offering anything new in terms of features. It sounds a lot more refined and authoritative for approximately the same moderate price; which is why it comes highly recommended. It may not be the best thing you have laid eyes on, but it does its job dutifully. 9. The Philips HTS-6600 and MCD-288 have won the silver and bronze awards, but I do not have any details. If others can pitch in with more details of these or other models, it will be appreciated. |
| The Following User Says Thank You to venkatcr For This Useful Post: | ||
gap g j (30th January 2009) | ||
#10
venkat how is Onkyo HT-S5100
HT-S5100 - 7.1-channel system, 3x 1080p compatible HDMI inputs + 1x pass-through, 130 Watts per channel amplifier using Onkyo's Wide Range Amplifier Technology (WRAT), 290W subwoofer and dedicated iPod dock pls advise yarr ![]() ---------------------------------- Quote:
| Bookmarks |
| Thread Tools | |
Similar Threads for: Need your suggestion in buying a package home theater system for home purpose
| Thread | Thread Starter | Forum | Replies | Last Post |
| Help needed in Buying a Home theater | Glolla | What Should I Buy? | 11 | 30th March 2010 06:45 PM |
| Checklist to avoid buying Demo Piece - Home Theater in a Box | tellranga | Home Theater In A Box | 1 | 16th October 2009 10:40 PM |
| Home Theater package for <1 lakh | sforsuresh | Introductions | 22 | 22nd June 2009 10:03 PM |
| help to buy home theater speaker package | balar_amit | What Should I Buy? | 14 | 8th February 2009 06:47 PM |
| Upgradation of audio system to full home theater package | diplomat | Introductions | 0 | 11th February 2008 10:36 AM |
