>20K: ONKYO? Panasonic? SONY? Gigaworks?
Discuss >20K: ONKYO? Panasonic? SONY? Gigaworks? at the Home Theater In A Box within the HiFiVision.com - India's Audio Video Hi-Fi Forum; I am looking for a HT below 20k. My Choices are: ONKYO S3100 Panasonic PT550 ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > AV Sources > Home Theater In A Box
Notices
Home Theater In A Box Home Theater In A Box type units are all-in-one devices that are a Receiver, DVD Player, Amp, and speakers all in one unit.
Advertise Here
Reply
Thread Tools
  #1
Old 9th August 2008, 11:19 PM
kaykayshah is on a distinguished road
My Choices are:
ONKYO S3100
Panasonic PT550
SONY DDW685
All these models are priced at 19990/-
Other option I am also looking at is Gigaworks G500 5.1Ch 300wt RMS
What do you guys suggest?
Sponsored Links
  #2
Old 10th August 2008, 12:16 AM
SAMUEL's Avatar
SAMUEL is on a distinguished road
Thumbs up Re: >20K: ONKYO? Panasonic? SONY? Gigaworks?
Hi Kaykay,
For 20K you can't go wrong with the Onkyo.
For the other two model's I don't have any idea.
I think sony has got an active subwoofer whereas the onkyo has passive.
Lets see other members viewpoints also...
Good Luck with your purchase.
Sam
  #3
Old 10th August 2008, 01:14 AM
SAMUEL's Avatar
Oh I forgot,
Welcome to the most Happening AV-HiFi Forum of India H*I*F*I*V*I*S*I*O*N
SAM
  #4
Old 10th August 2008, 01:37 AM
soundsgreat's Avatar
soundsgreat is on a distinguished road
First off welcome to the forum ! have pleasant time here !
I also will say Onkyo is the safest bet among the shortlisted systems !! for the simple reason that only Onkyo has a dedicated AVR in this system compared to the others ! the Sony and Panasonic both have the DVD player and Amp crammed into a single unit and are not that great !! the Creative has the Amp built into the Sub so again that not the ideal choice !! One more reason is the supplied speakers with the Onkyo,Though not path breaking and phenomenal but is very decent and a tad bit better then the others !
So please check out !!
Regards.
  #5
Old 10th August 2008, 01:56 AM
Sony too has a dedicated AV Receiver Check
HT-DDW685 : Home Theatre Component System : Home Theatre System : Sony India
This model of sony has two subwoofers! Thats because the satelites doesn't have it..
  #6
Old 10th August 2008, 02:11 AM
Ohh Yeah Missed that one !! my mistake!!
But anyhow the suggestion remains the same !! coz some of the Sony entry level AVR's sounds mediocre and lacks the stuff !
Regards.
  #7
Old 11th August 2008, 11:14 AM
vj_box's Avatar
vj_box is on a distinguished road
I also just bought the onkyo 3100 on saturday in HYD e-zone.Its simply amazing for that money.
I would highly recommend for any one looking in that range.
I thanks all the members for the valuable suggestions.
Special thanks to Venkat cr.
Thanks all!!
Vj
  #8
Old 2nd November 2008, 12:20 AM
moserw's Avatar
moserw is on a distinguished road
Quote:
My Choices are:
ONKYO S3100
Panasonic PT550
SONY DDW685
Onkyo is the way to go at that budget. Don't even bother looking at anything else and don't even consider PC speakers like Gigaworks. Dedicated HT system rocks all the way and a decision you will not regret for a long time to come!
  #9
Old 2nd November 2008, 03:11 AM
Nishanth is on a distinguished road
Onkyo is a pretty good for its price. Its pretty good with movies.
But checkout the Sony AV Receiver+speaker system. Its not as balanced as the Onkyo, but offers good performance when it comes to movies.
  #10
Old 3rd November 2008, 12:51 AM
devp24 is on a distinguished road
Y not go and check out the Logitech Z-5500 speakers....i havent heard them but as per reviews online I think its quality should be better than the Onkyo speakers...
wat do the others say??
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: >20K: ONKYO? Panasonic? SONY? Gigaworks?
Thread Thread Starter Forum Replies Last Post
Sony vs Panasonic 32 LCD compare spirovious Television 0 4th August 2008 03:53 PM
Sony vs Panasonic 32 LCD spirovious Television 0 4th August 2008 09:41 AM
Home theatre: Sony DAV-DZ556KB or Panasonic SC-HT540GCSS or Philips HTS3548/98 Hot Punekar Home Theater In A Box 3 28th March 2008 06:56 PM
Samsung, Sony or Panasonic LCD TV ? vinod_david Television 5 31st December 2007 11:35 AM
Sony STR DA 1200 ES Or Onkyo TX SR 605 Or Denon AVR 1507 sandip_d Surround Amplifiers/Receivers 5 5th November 2007 07:02 AM
Advertise Here
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
