| Discuss need help in purchasing???? at the Home Theater In A Box within the HiFiVision.com - India's Audio Video Hi-Fi Forum; but i like to play loud so what should i do should i buy upgraded ... |
| Home Theater In A Box Home Theater In A Box type units are all-in-one devices that are a Receiver, DVD Player, Amp, and speakers all in one unit. |
Thread Tools |
#11
Re: need help in purchasing????
but i like to play loud so what should i do should i buy upgraded receiver says 130 watts/channel at 8ohms i'm gonna buy these speakers in few days klipsch synerengy f-2 complete package of 5.1 its specification 100 watts(400 watts peak),8ohms,95.5 db for front speakers and center speaker,100 watts(400 watts peak)8 ohms, 91 db and subwoofer 12 inches 300 watt(600 watt peak) so what to do please help me out from this confusion and no.2 important thing as today we can mostly get 7.1 receiver do i play 5.1 speakers without any loss of quality or do i miss sumthing if not use extra rear speakers because mine room layout i can't use extra 2 rear speakers for 7.1 please reply and thankx for all your support i really appreciate it |
| Sponsored Links |
#12
Quote:
As I mentioned yesterday, the 606 should pump out something like 100 watts of continuous power into all your speakers. If you mate this with your Klipsch which is also rated at 100 watts, you will enough 'volume' to make you deaf. The Klipsch's sensitivity is also good. Believe me, unless you are deaf, you will not be able to cross 115 to 120db on the 606. This will be roughly half the power of the amp. Going back to olden days of using a pot to control volume, this will be between 11 '0' clock to 12 '0' clock position in the volume knob. As I mentioned elsewhere, you can set different speakers at different power settings. I usually set the center channels and the surround channels slight higher than the fronts. Your 12 inch sub is an active sub and adds another 300 watts. Quote:
You can also biamp your front speakers with output of your rear channels. Please refer to page 17 of the 606 manual which tells you how to do it. This way you will get improved bass and treble performance from you front speakers. Cheers |
#13
hey bro
As I mentioned elsewhere, you can set different speakers at different power settings. I usually set the center channels and the surround channels slight higher than the fronts whats the meanig of the above you see i'm on zero level for using av receiver and sperate receiver so i don't know the proper meaning of you above lines ok as you suggested do not play loud and i can use 606 with klipsch speaker i will do the same 2nd point ( Your 12 inch sub is an active sub and adds another 300 watts) whats the meanig of this and third point as you say bi amping mine front speakers with rear outputs doest that mean i need extra amplifiers because as much as knowledge i have i guess bi amping means adding one more amplifier right if i'm wrong please correct me and one more thing do bi amp really improves the overall sound quality and one more important thing i want to know how the hell you know that much knowledge are you some kind of sound engineer or something don't mind just asking thanks again i'm waiting for your reply |
#14
Quote:
Quote:
Quote:
A floor standing speaker generally has three drivers inside - one for low frequencies, one for mid frequencies, and one for high frequencies. These are called subwoofer, midrange, and tweeter. Usually you have an amplifier sending the full range of frequencies through a single pair of cables to the loudspeaker. Inside, the loudspeaker has a small electronic circuit called a crossover that takes all the frequencies, and sends three independent frequency ranges to the three drivers. If you look at the rear of the speakers that can be bi-amped, there will be two sets of binding posts marked low pass and high pass. There will also be a small brass plates shorting (connecting) these two binding posts. In general condition, you connect to one pair of the binding posts, and let the loudspeaker do the frequency separation inside. (see picture below) ![]() When you use an amp or an AVR that can bi-amp, the frequency separation is done by the amplifier, and two independent set of speaker cables carry the signals to the loudspeaker. One is connected to the low pass to drive the sub woofer directly and the other is connected to the high pass to drive the midrange and tweeter separately. By removing the brass plate that connects the two binding post you also disable the crossover inside the loudspeaker. It is believed that doing this helps in bass response, dynamics, and overall fidelity. There is also electrical isolation between highs and lows of the speaker system as they are independently connected to separate amplifiers. This reduces cross talk and mutual inductance. Quote:
![]() Cheers Last edited by venkatcr; 18th April 2009 at 04:00 PM. |
#15
hey thanks yaar
ok as in your previous replies you said don't play loud but what if i sit from 19 feet away from speakers because i'm using 720p sony projector with 120 inch screen and i sit around 19 feet from it for optimum viewing so i have read on internet that if you sit further away from speakers you need atleast 3 db increase for any 1 metere of distance after 12 feet from speaker so according mine seating position do 100 watts/ channel is enough or not for me kinda confuse so help me out and most important thing i'm sorry if i bores or disturb you by asking too many questions also need more advise as i mentioned about klipsch speakers i send you some information about two systems known as f-1 ,f-2 and you tell me which system fits into mine needs mine room dimensions are 12 feet wide,20 feet long and 10 feet high and don't forget i sit atleast 19 feet from screen that means 19 feet from front,center and subwoofer also here are the models klipsch f-1 Model Specifications. Price F1 100w(400wPeak),8ohms,97db 25000/- C1 50w(200wPeak),8ohms,93db 9000/- S1 50w(200wPeak),8ohms,88.5db 12000/- Sub10 10' woofer,200w(400w Peak) 21000/- 5.1 Total 67000/- f-2 speakers Model Specifications. Price F2 100w(400wPeak),8ohms,95.5db 34000/- C2 100w(400wPeak),8ohms,95.5db 12000/- S2 100w(400wPeak),8ohms,91db 18000/- Sub12 12' woofer,300w(650w Peak) 25000/- 5.1 Total 89000/- and about receiver which av receiver onkyo 606 or onkyo 705 onkyo 606 produce 90 watts/channel @8 ohms (cost 36000) onkyo 705 produce 100 watts.channel @8 ohms (cost 45000) right now i have 1 lakh and 25 thousand atleast spare for buying complete package ![]() atlast as you mentioned in your reply (When you use an amp or an AVR that can bi-amp, the frequency separation is done by the amplifier) this means when i had to bi amp mine front speakers with rear speakers out put i need one more amplifier or pre amp and what if i don't use any bi amping for front speakers and only use 5.1 connection do i loss sumthing so i'm waiting for your reply Last edited by manu4panjab; 1st September 2008 at 03:19 PM. |
#16
Manu,
If you have a 20ft room, the ideal seating should be around 3 to 5 ft from the rear wall. this distance will allow you to sit within the throw ( cant think of the right term ) of the rear surrounds. If you sit at 19ft from front, then you have 1ft distance, and may not get good rear surround effect. If you plan to have a dedicated HomeTheatre room, you should go for a 7.1 setup, with bipolar surrounds on left/right and a forward facing rear surround. For a 5.1 setup, use bipolar rear surrounds to disperse the sound and bounce it off the side walls, or use only left/right bipolar surrounds - in which case you can sit at 19ft. Bi-Amping. This is normally done using the 2nd Zone/ ZoneB amp in the receiver, so you will not loose the surround effects. This however will restrict you to a 5.1 setup. Bi-Amping improves the Sound Quality of the Front tower speakers as there are two amps driving the Bass and Mid/high range respectively. If I understand correctly, there is less loading on the amp, and less loss in the cross overs with bi-amping. Make sure the receiver supports bi-amping. |
#17
Quote:
It is not only the amplifier's power but also a lot of other factors that go into ensuring that you get good sound. One of the most important is room acoustics. If there is a lot of external noise,one tends to increase the volume and that is not good. I have a large room myself, and I sit some 12 feet away from the front speakers. The rear speakers are about 5 feet behind me and the surround speakers are about 4 feet on either side of my ears. The AVR has way of compensating for these positions through what is called an Audyssey system. That will take care of your worries. If you match the 606 with the F1, and the 705 with the F2, either way you will have a good system. Or you can also match the 705 with the F1, and that way you will have a more powerful system. Quote:
Quote:
Quote:
Onkyo 705 - 45,000 F2 Speakers - 89,000 Total 1,34,000 Onkyo 606 - 36,000 F1 Speakers - 67,000 Total 1,03,000 Onkyo 705 - 45,000 F1 Speakers - 67,000 Total 1,12,000 So the decison will depend a lot on what you can afford. Quote:
Both the 606 and the 705 support bi-amping, so you do not need additional amplifiers. My greatest concern is that you seem to be making your purchase decision based on just what this forum is saying. Though we will not lead you in the wrong direction, it is always better to see and listen to the systems before you buy. Can you do this please? I would very strongly advise that you audition before placing the orders. Cheers |
#18
hey brother
thanks yaar i never thought that online someone could help me like the way you did i really appreciate it from mine heart as you suggest about three options for speaker and receive selection i decide this 705 receiver 45000 f1 speaker 25000 c1 speaker 9000 s1 speaker 12000 as i can see f1 has sub 10 wth its whole package at the rate of 21000 can i alternate it with sub 12 which is 25000 so a total of 116000 what you think about it i like to know this from you because you has sooo much knowledge one more thing as you suggest 705 + f1 and i can have more powerful system i have one thing to ask as you can see c1(center speaker) has 50 watts of continous power(200 watts peak) and s1(surround speakers) also has the same so by using 705 with it do i have som kind of problem running them last yaar can you send me some hand drawing how to bi amp front speaker with rear speakers output for 5.1 i send you back panel of 705 thanks one more time Last edited by manu4panjab; 1st September 2008 at 10:45 PM. |
#19
Quote:
Quote:
Quote:
![]() Please read the manual very carefully page by page before you start to install the system. I would also suggest, don't try the bi-amping on day one. Run the system as a pure 5.1 for a few weeks. See if the 'volume' you are looking for is there directly. Listen to some music, and see some movies. The speakers need a few weeks to break in. After that you may need to retune the AVR once again in terms of speaker set up. Once you are happy with all this, then try bi-amping, and that too, only if you think you need more. And PLEASE, take a trip to Delhi if needed, and do audition the system before placing the order. Cheers |
#20
thanks yaar for all your support
can i message you in future for further support thanks again
| Bookmarks |
| Thread Tools | |
Similar Threads for: need help in purchasing????
| Thread | Thread Starter | Forum | Replies | Last Post |
| Purchasing Component & HDMI cable | tech2010 | Digital Cable and DTH | 5 | 10th January 2010 07:55 AM |
| advice for purchasing AVR | ram | Surround Amplifiers/Receivers | 5 | 11th December 2009 03:01 PM |
| purchasing outside india?? | manu4panjab | Speakers | 25 | 10th June 2009 10:57 PM |
| Help in Purchasing a New Amplifier | cyber_cat | Amplifiers | 36 | 14th February 2009 01:10 PM |
| How safe purchasing TV thru ebay? | kams | Television | 0 | 16th August 2008 12:45 AM |
