Help with a Home + Computer Theatre
Discuss Help with a Home + Computer Theatre at the Home Theater In A Box within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Guys, I am looking for a home theater setup for a room which is about ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > AV Sources > Home Theater In A Box
Notices
Home Theater In A Box Home Theater In A Box type units are all-in-one devices that are a Receiver, DVD Player, Amp, and speakers all in one unit.
Advertise Here
Reply
Thread Tools
  #1
Old 09-07-07, 01:15 PM
kiranchitnis is on a distinguished road
Guys,
I am looking for a home theater setup for a room which is about 16x10 feet dimensions. I am looking for a setup which will support my television (read as movie) requirements + playing music off my computer located in another room. My budget is Rs. 40,000/- Could you please suggest me some good equipment here. I have just managed to google for a system in my budget and this is what I came up with:
__________________________________________________ __________________
Yamaha RX-V350 with Dahlquist Orbit 5.1A HT Speaker System
RX-V350 supports Dolby Digital Matrix 6.1 and DTS-ES Matrix 6.1, Dolby Pro Logic II, various DSP effects and a 5-band graphic equaliser. Orbit 5.1A speakers are sleek and pack a sizeable punch for the size. The 8-inch powered subwoofer delivers 100-watt RMS. (Approx Rs 37,000)
Sponsored Links
  #2
Old 10-07-07, 07:37 AM
Mohan is on a distinguished road
Re: Help with a Home + Computer Theatre
You can also audition the Onkyo HT–SR600 5.1 Channel A/V Surround Home Theater Receiver/Speaker Package or the new Onkyo HT-S680 6.1 version of their HT System for INR 35K.
  #3
Old 13-07-07, 11:39 AM
particleman's Avatar
particleman is on a distinguished road
Hi Kiran,
I don't want to sound discouraging but I would recommend you stay away from Yamaha. I made the "mistake" of buying one last year (a low-end, HTIB model) but it sounds rather bad for music (its okay for movies).
I would second the suggestion to look at Onkyo but also suggest that you look at the JBL packages which feature a Harmon/Kardon receiver with JBL speakers (jbl.rediff.com) . It may stretch your budget a bit but will serve you well in the long run.
  #4
Old 07-02-08, 02:37 PM
skt skt is offline
skt is on a distinguished road
Check out for Marantz ER 2500 HT in box qulaity DVD player, 6+1 amp with sepaker in around 38K. Good speaker which reproduce real image sound.
Whr you are located and check with any marantz people ask them opinian, if you not geting one I can help you.
Sk.
  #5
Old 28-03-08, 03:49 PM
ranjeetrain is on a distinguished road
Quote:
Originally Posted by particleman View Post
Hi Kiran,
particleman is right on the money. Yamaha's have the thinnest sounds and highs are brights. They lack weight.
Onkyos are completely opposite, tight bass but dry sound.
Best HTIBs in India around INR 50K are Harman kardon/JBL systems.
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Help with a Home + Computer Theatre
Thread Thread Starter Forum Replies Last Post
please help me configure my first home theatre system.. shamps Surround Amplifiers/Receivers 31 17-06-08 06:48 PM
20 top tips to improve your home cinema or theatre cyrus AV Enhancers & Room Acoustics 2 06-04-08 04:25 PM
Buying guide to a home theatre projector Anil Home Theatre Projectors & Screens 7 17-03-08 04:00 PM
Looking for a good Home theatre system within 30-35K vipul Home Theater In A Box 5 24-07-07 11:13 PM
Buying a home theatre bangalore hassan-shafiu Introductions 0 06-12-06 10:53 AM
Advertise Here
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
