Need help, totally confused regarding a HT setup
Discuss Need help, totally confused regarding a HT setup at the Home Theater In A Box within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Have been thinking about setting up a better Home theater at my home. I've been ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > AV Sources > Home Theater In A Box
Home Theater In A Box Home Theater In A Box type units are all-in-one devices that are a Receiver, DVD Player, Amp, and speakers all in one unit.
Advertise Here
Reply
Thread Tools
  #1
Old 24th June 2009, 08:04 PM
KonfuSed is on a distinguished road
Have been thinking about setting up a better Home theater at my home. I've been going through the forum postings and google God but more I'm into it more I'm getting confused. So please help me out to make a decision.
Current Setup : Sony MHC-GND8Z (I hope I got the model no correctly). This one doesn't have any Audio input and no HDMI output. Only plays the DVD's at their native resolution of 480i or 576i. Sound quality is not that good but I'd adjusting myself to it. But now I want something better.
Budget: 40k max.
Size of the room : 16x12 ft. Viewing distance is around 13.5 ft as of now.
Options : (packages)
1. Yamaha 463 (19k) with Jamo 406 speaker setup(15-16k). I'll add a sub later.
2. Onkyo 5100 HTiB (40k)
3. Denon 1509 with ProFx speakers(39k). But I auditioned them and I didn't like the sound much. The highs were bit harsh and didn't find the setup any better than my current setup. So instead I can go for Jamo 406 with the Denon 1509(24+16=40k).
4. Pioneer VSX-917 with Jamo 406(18+16 = 34k). Not sure about the Pio receiver as I've not found much reviews about it on the net.
Requirements: Movies and music 60:40. But I want the music to sound good too and hence not very enthu about the Onkyo as the reviews says that Onkyo is not good for music. And none of these receivers have 2 zone options so that I can plug in two speakers just for music.
Won't mind to have as many features as it can through in. It's ok if the receiver doesn't upscale the signal but it should sound decent for both movies and music.
Speakers :
And lastly, how are the Jamo speakers that I've decided? Are they ok for the price? Is there any other option for that price?
Or should I add two front L/R floorstandars as of now and add the center , surrounds and Sub later? But that would kill the experience of Home Theater.
Sub-woofer : I was thinking of adding the Sonodyne 210 Roarr Sub later as for that price(14.5k) I found the sub to be really good and punchy. Is there any other option available? I wanted to go for the Wharfedale 150SW but the price has gone up to 21.5k it seems :-(
So please please help me out here. I'm planning to atleast get the receiver soon.
Sponsored Links
  #2
Old 24th June 2009, 08:21 PM
reju has a spectacular aura aboutreju has a spectacular aura about
Re: Need help, totally confused regarding a HT setup
Quote:
I feel this is very wise thing to do. I have heard many talk on these lines. But in my eagerness to get my HT kicking, I had overlooked it during my purchase. Now I repent, and feel this option is the best if you are temporarily low on budget.
Later (3-6 months or whenever) if you are not very happy with the fronts, you can still get better fronts and swap the these fronts as rear speakers.
Just imagine how good your HT will sound then
BTW I feel the Jamo 406 and Fusion speakers are very poor performers.
  #3
Old 24th June 2009, 08:23 PM
unleash_me's Avatar
unleash_me has a spectacular aura aboutunleash_me has a spectacular aura aboutunleash_me has a spectacular aura about
Another B'lorian? Welcome aboard!
This topic has been discussed here almost on a daily basis. Do a little search and you will get your answers.
Cheers.
  #4
prakasse will become famous soon enoughprakasse will become famous soon enough
Jamo 406 is not good in my opinion. I auditioned them with Onkyo and i did not like it.
In your budget Onkyo 5100 should be good. Later you can upgrade the front speakers to better ones
Thanks,
Prakash.
  #5
Old 25th June 2009, 12:06 AM
Any suggestion for the fronts in that budget? I'm thinking on that line but will miss the surround for quite a few time as it'll take lots of time to gather some more funds. Will the front speakers do a good job as surround?
There goes my HT ;-) I did audition the fusions but I didn't liked them.
Cheers.
Thanks for the welcome. Yup doing the research, but more I'm searching more confused I'm getting. Have been doing the research for last 2 weeks but I'm going nowhere and hence the post.
Thanks,
Prakash.
Heard that Onkyo's are not good for music and I need one receiver which will be good for music too. Or am I expecting too much? How are the Yamaha or Denon compared to Onkyo 5100 receiver?
  #6
Old 25th June 2009, 07:47 AM
srikarkav's Avatar
srikarkav has a spectacular aura aboutsrikarkav has a spectacular aura about
Since you want to hear quality music too, Onkyos are out of contention here. Believe me i am an Onkyo owner.
You can go with a Marantz AVR and Wharfedale 9.2 BS for starters at your budget. They will be good for both movies and music.Wharf 9.2s have very good bass, you may not miss a sub for now.Later you can go for wharf 9.5 FLs.
Or if u are very particular about FLs you can go for an entry level Marantz AVR and the 9.5 tho' it may exceed your budget slightly.
Hey we are really 'konfused' about your location
cheers,
sri
  #7
Old 25th June 2009, 08:03 AM
Quote:
Actually he has given very a precise location. He is located in Koramangala, Bangalore. There is a possibility that he drinks a lot of milk as he stays very close to milk dairies
So konfused is probably looking for precise answers about which HT go for.
  #8
Old 25th June 2009, 08:17 AM
With a view of building a good HT within your 40K budget, go for mid range AVR like Yamaha/ Denon from grey market, as it can be much cheaper!!
Then add good bookshelves like Polk Audio Rti A3 or PSB or Wharfedale.
I own the Polk and they are good performers. While many experts here have recommended/ purchased PSB/ Wharedales etc.
Later if your budget permits, get good subs & floor speakers and use these BS as surrounds.
  #9
Old 25th June 2009, 01:18 PM
Now Marantz also in to add more to my konfusion. Where can I audition Marantz in Bangalore?
How much would the wharfedale FLs cost? I'm kind of sold for FL's as I heard that they produce better bass than the bookselfs. Also I won't have to spend on the stands and FL's looks good too ;-) Is there any good FL's southwards of 20k? How is MS Avant 914i? Or they can't be used for HT?
WHich Marantz AVR's are these? Can you tell me the model names? And their pros and cons?
cheers,
sri
He he that was my office address (well, almost, not exactly) .. Now changed to home address ;-) But yeah, looking for precise answer to my quest and there probably won't be just one answer.
I;m bit worried about buying stuff from Grey market, in fact I don't think I'll comfortable to buy such pricey stuff from Grey market. But would like to know how much will be price difference? If the difference not around 10k then there is no point also.
About bookselfs, let me think about them as I was more inclined towards floorstandars..
  #10
Old 25th June 2009, 04:57 PM
In your budget it would be difficult to do justice for both music and movies.
A decent AVR which is good for both music and movies will be costly. eg. Yamaha 663 does good in terms of movies and music. But it is costly and you will be left with only 7k for speakers
else try to build the HT in steps.
Thanks,
Prakash.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Need help, totally confused regarding a HT setup
Thread Thread Starter Forum Replies Last Post
Old vs New ... I am confused... gautamz Amplifiers 0 14th December 2009 01:34 AM
please help totally confused??? manu4panjab Audio Video Accessories 6 19th May 2009 02:54 PM
Advice needed: Totally confused!! MPM Home Theater In A Box 13 6th December 2008 10:21 AM
Confused ... khaadu75 Television 41 15th October 2008 10:01 AM
??? confused xavier Surround Amplifiers/Receivers 11 16th September 2008 09:37 PM
Advertise Here
Copyright © 2006-2010, HiFiVision.com All Rights Reserved.
Recommended Websites - www.CameraVision.in
