Problem with Pairing a passive sub-woofer from Sony in a box, with Yamaha RX440 AV
Discuss Problem with Pairing a passive sub-woofer from Sony in a box, with Yamaha RX440 AV at the Home Theater In A Box within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hey Guys, I'm in a crazy situation where i need to make use of the ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > AV Sources > Home Theater In A Box
Home Theater In A Box Home Theater In A Box type units are all-in-one devices that are a Receiver, DVD Player, Amp, and speakers all in one unit.
Advertise Here
Reply
Thread Tools
  #1
Old 9th February 2010, 01:26 PM
demigod is on a distinguished road
Hey Guys,
I'm in a crazy situation where i need to make use of the speakers sub from Sony HT in a box. I'm planning to power them with my Yamaha RX440 AV receiver and another DVD player.
Speaker outputs are matching Yamaha specs and RX440 able to drive the speakers, how ever i'm not able to drive the sub.
The sub is passive one and with a standard +/- speaker wire bindings behind. However the sub output from Yamaha is one single RCA jack.
So i connected a RCA pin to the standard speaker cable (1 RCA at source and two split ends at sub) - but there is no signal.
Can passive sub work with RX440?
Or am i missing anything with the cable?
Please help.
Sponsored Links
  #2
Old 9th February 2010, 01:56 PM
spirovious's Avatar
spirovious is a name known to allspirovious is a name known to allspirovious is a name known to allspirovious is a name known to allspirovious is a name known to allspirovious is a name known to all
Re: Problem with Pairing a passive sub-woofer from Sony in a box, with Yamaha RX440 A
Quote:
Originally Posted by demigod View Post
Hey Guys,
Please help.
Not directly,but if you get a sub amp ,you can connect it to AVR subout.
You need to check spk impedence,power ratting if they match with AVR.
  #3
Old 9th February 2010, 02:32 PM
rohigupt is on a distinguished road
a simple solution is to connect +/- of ur left channel to your +/- of passive sub.
So, +/- of left channel would then be driving ur left speaker as well as sub. Low frequencies from ur sub doesnt have much of stereo effect..
Cheers !
  #4
Old 9th February 2010, 03:04 PM
Oh, i thought AVR is providing amplified sub out. If this is the case, can i get an active sub and connect it directly?
  #5
Old 9th February 2010, 03:12 PM
cruise_1982 is on a distinguished road
If you get an active sub, you can connect it directly. There will be no issues.
  #6
Old 9th February 2010, 03:20 PM
ranojoy's Avatar
ranojoy is on a distinguished road
Cheers !
I dont know whether that would be a good idea. Yamaha website suggests usage of 440 with a sub-sat system since its only a 65 WPC AVR. However, I've used it with Jamo floorstanders and Yamaha sats for 6+ years with absolutely no trouble at sane volume levels but I suspect it would struggle to cope if asked to deliver low frequencies on a sustained basis to a passive sub.
The situation would get worse if the LFE signal is redirected to the fronts thru bass management. On the other hand, if the LFE is not redirected, it would continue to be output from the LFE RCA socket which is not connected to anything - so all LFE effects would be lost.
Hope my logic is not messed up. Please correct me someone, if I'm wrong.
  #7
Old 9th February 2010, 06:13 PM
jeevabobby26's Avatar
jeevabobby26 will become famous soon enough
hi demigod,
Avoid connecting the sony passive subwoofer to the yamahha AVR. Normally in the HTIB sony systems, the subwoofer or speakers are 3 ohms to 3.8 ohms in impedance. The yamaha AVR impedance ratings are from 4 ohms to 8 ohms or more. If you connect a speaker which has lesser impedance than 4 ohms, it will affect the yamaha AVR. Only the active subwoofers can be connected to the yamaha AVR.
Passive subwoofers can also be connected to the yamaha AVR, by using a seperate subwoofer amplifier. The subwoofer amp has speaker +/- outputs and rca inputs, volume control, frequency control, phase control etc.
Connect +/- of the subwoofer to the +/- output of the subwoofer amplifier and then connect the rca output from the yamaha AVR to the rca input of the subwoofer amplifier.
The Following User Says Thank You to jeevabobby26 For This Useful Post:
demigod (9th February 2010)
  #8
Old 9th February 2010, 06:56 PM
Thanks Jeeva,
That means not only Sub, and i can't connect any of the sat speakers from sony HTIB
When you say AVR will be impacted, can you please tell me exactly what would happen to the receiver? Sorry for my ignorance with impedance stuffs, but i'm already using the HTIB speakers with RX440 AVR.
  #9
Old 9th February 2010, 07:10 PM
I use Wharf 9.2 with Norge 1000 for stereo. Even WF9.2 impedance is 6ohm only where in Yamaha AVR output is 8ohm.
So i can't use WF9.2 also as front L/R.
That means i need to buy 5 more speakers
Is it really necessary to match amp/speaker impedance?
Until now i have been checking only the RMS output
  #10
Old 9th February 2010, 07:59 PM
hi demiogod,
The HTIB speakers will confirmly affect your yamah AVR by means of impedance matching factor. Lesser the impedance, harder the AVR to drive the speakers. Normally the amp will run hot when in use and when you use a lesser impedance speakers the will run much hotter due to high supply power used to drive the lesser impedance speakers, so the internal circuit parts will be affected in this regard. The life of the AVR will also be decreased. (sorry cant able to explain you technically)
All the yamaha AVR will support 4ohms, 6ohms and 8ohms impedance speakers. You can use wharfies withoput any problem and all the wharfedale speakers compatible with any 8omhs amplifier or AVR (Recommende by wharfedale company itself in thier catalogue as specified).
Yes, it necessary to match the impedance factor for amp/speaker and also the you should check about RMS output for both amp/speakers.
If the RMS output of the amp is higher, it is easy drive any speakers.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Problem with Pairing a passive sub-woofer from Sony in a box, with Yamaha RX440 AV
Thread Thread Starter Forum Replies Last Post
Using Yamaha RX440 6.1 AVR only for two channels demigod Surround Amplifiers/Receivers 2 15th March 2010 03:39 PM
Car Passive Sub-Woofer for Home use. Your Views Pls soviet_selva Speakers 10 21st November 2009 02:25 PM
sony 29" TV problem bobby76 Television 4 31st July 2009 03:43 PM
problem with 'sub out' of yamaha rx v361 jaudere Surround Amplifiers/Receivers 3 16th July 2009 02:28 PM
Problem with sony dav151kb home theatre sweetvenom Home Theater In A Box 4 28th March 2008 03:52 PM
Advertise Here
Copyright © 2006-2010, HiFiVision.com All Rights Reserved.
Recommended Websites - www.CameraVision.in
