| Discuss Imporve sound quality, how ? at the Home Theater In A Box within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi all, I have Onkyo HT-SR600. How can I enhance the output of the center ... |
| Notices |
| Home Theater In A Box Home Theater In A Box type units are all-in-one devices that are a Receiver, DVD Player, Amp, and speakers all in one unit. |
Thread Tools |
#1
Hi all,
I have Onkyo HT-SR600. How can I enhance the output of the center channel ? used for dialogues . Problem I face : At low volume the dialogues lack impact. On increasing the volume , special effects sound too loud for comfort. Thanks, Aryan. |
| Sponsored Links |
#2
Re: Imporve sound quality, how ?
Quote:
All failing try to look for the manual online and post the link here. Any of us will find the relevant parts and tell. Last edited by ranjeetrain; 2nd April 2008 at 09:09 PM. |
#3
Quote:
I have tired the +12\-12 db for center channel, but then that just upsets the whole HT calibration. The manual provided is of no help. Online manual ? I will have to look for it, might be able to find one. Have a good day. Thanks, Aryan. |
#4
Quote:
Increasing the volume level for the center channel may be upsetting the calibration because this has the effect of narrowing the sound field in the front speakers and drawing sound away from front left & right and towards the center. Another solution but not recommended is to modify the EQ setting for the center channel. This is provided to enable timbre matching with other speakers but perhaps it could be used to enhance the center channel audio. |
#5
Correction. DRC stands for Dynamic Range Compression
#6
You are right, it was a typo. Funny I did not make that mistake the first time around when we discussed it in another thread.
#7
Your receiver has something called OR-EQ which I thnk is the same as DRC. Try this. It also has Level +/- for each speaker. Does that not work?
If none of this works you don't have much choice but to move the centre speaker closer to you. |
#8
Good ideas so far. I am going to make a guess here.
Is your center channel out-of-phase? Try reversing the +ve and -ve (Red and black terminals) at the speaker's end and see if that helps. If changing it at speaker's end is difficult, you can try on amp's end. Any end is fine. Give it a try and see. |
#9
Hi guys,
Thanks a ton for all the useful advise that is comming my way, ever so greatful, anything to get this problem straightened up. Just needed 2 share with u guys , that I keep playing with the center channel setting, increasing it to +7, keeping L & R fronts at +5, surronds at +4 or at +5, subwoofer at max +12, and then the problem of increased center output along with double increase in special effects output, which is annoying and not pleaserable as it should be. Just to give u guys an idea of how grave the situtions is, My wife now prefers watching movies though the television and irony of the matter, I bought this system to impress her. Failed miserably, hahaha.. Guys this is my center channel config : SKC - 350 C - Centre Speaker Speaker Type: 2-Way, Bass Reflex Speaker Type: 2-Way, Bass Reflex 8 cm cone woofer 2 cm ceramic tweeter Magnetically Shielded Max. Input Power: 120 W Max. Input Power: 120 W Impedance: 6 ohms Frequency Response: 100 Hz–22 kHz WHD: 101 x 273 x 115 mm Weight: 1.0 kg Reciever Config : 5.1 channel A/ V Surround Home Theatre Receiver 120 W/Ch Continuous 6 ohms, 1 kHz, JEITA Frequency Response: 10 Hz–50 kHz (+1 dB, -3 dB) DTS®, DTS® Neo:6 5.1, Dolby® Digital, Dolby® Pro Logic® II 192 kHz/24-Bit DACs for All Channels HDTV-Capable (50 MHz) Component Video Switching (3 Inputs/1 Output) 3 Digital Inputs (2 Optical/1 Coaxial) 4 Composite Video Inputs and 2 Outputs 4 A/V Inputs and 1 Output 2 Audio Inputs and 1 Output H.C.P.S. (High Current Power Supply) Massive High Power Transformer Optimum Gain Volume Circuitry A-Form Listening Mode Memory Non-Scaling Configuration OR-EQ™ Equalizer Function Late Night Mode (High/Low/Off) CinemaFILTER™ Direct Mode Speaker A/B Drive Color-Coded 5.1-Multichannel Inputs (Receive 5.1 Surround Sound from Compatible Blu-ray Disc and HD DVD Players) Color-Coded Speaker Terminals 30 FM/AM Random Presets “Easy-Set” Speaker Configuration Crossover Adjustment (40/50/60/80/100/120/150/200 Hz) Compatible with RI Dock for the iPod A/V Sync Control Function (Fixed at 0/20/40 ms) Full-Function RI (Remote Interactive) Remote Control WHD: 435 x 150 x 369 mm Weight: 9.6 kg I will try what you mentioned, Mr. Particleman, and hope it makes the difference. What I am dreading is that the 8 cm cone is not enough for the kind of clear sound i am wanting. Cheers, Aryan. Last edited by Aryan; 4th April 2008 at 02:59 AM. |
#10
Quote:
You can try for manual calibration of all the speakers. You need a sound level meter. Procedure will be available in your AVR manual. Or you can try reading links like this one: HTadvice.com: On Setup: Speakers: Calibration You can use the test tone in your AVR for the adjustment of the levels. |
| Sponsored Links |
| Bookmarks |
| Thread Tools | |
Similar Threads for: Imporve sound quality, how ?
| Thread | Thread Starter | Forum | Replies | Last Post |
| Tata Sky - DVD Quality?? | hemantwaghe | Digital Cable and DTH | 24 | 2nd November 2008 12:19 PM |
| Good Quality DVD Players | ChetanSouthMumbai | DVD players & DVD/hard-disk recorders | 19 | 16th June 2008 01:58 PM |
| quality of indian branded speakers | mandeep | Speakers | 17 | 15th May 2008 01:58 PM |
| Hello From Sound Of Music | Sound Of Music | Introductions | 7 | 11th May 2008 02:17 PM |
| A bit too Diverse to sound good??? | puchoo | My Audio/Video Setup | 0 | 5th September 2006 05:51 PM |
