HiFiVision.com - Audio Video Hi-Fi Forum
connecting PC to AVR problem
Discuss connecting PC to AVR problem at the Home theater PC (HTPC) or media PC within the HiFiVision.com - Audio Video Hi-Fi Forum; hi folks i am trying to connect my pc(HP 5208uk) to my avr(onkyo 609). I ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > Home theater PC (HTPC) or media PC
Home theater PC (HTPC) or media PC HTPC is a convergence device that combines many or all components of a home theater and the functions of a personal computer setup into one box
Advertise Here
Reply
Thread Tools
  #1
Old 12th January 2012, 10:39 PM
Reputation points: 10
gazdoug is on a distinguished road
hi folks i am trying to connect my pc(HP 5208uk) to my avr(onkyo 609). I had this connected no problem VGA to VGA. The problem is I have just installed a new video card in my PC (Gainward 1gb pci express) Now when I try to connect it to my onkyo again VGA to VGA I recieve no signal. I am awaiting a 5m HDMI to HDMI cable arriving which I will be using soon but hope it will connect as right now I am getting nothing VGA to VGA. is there something I am doing wrong or havengt done? just find it very weird as it was connecting fine using my old video card. any help would be appreciated
Sponsored Ads
  #2
Old 12th January 2012, 11:24 PM
spirovious's Avatar
Reputation points: 1911
spirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant future
Re: connecting PC to AVR problem
Is that graphiccard VGA not working?If yes,then you have to select PCI graphic as primary boot in MB bios.
Secondly if you have also connected monitor to GC,then you need to config video out in control panal of graphic drivers.
  #3
Old 12th January 2012, 11:31 PM
Reputation points: 2822
venkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond repute
When you install a video card. the video output on the motherboard is disabled. You will be able to get video output only from the card. If you card has a VGA output, connect the cable to that.
  #4
Old 12th January 2012, 11:36 PM
yes thats right graphics vga to my vga on my onko 609 is giving no signal. DVI to PC monitor is working fine. How do I set pci graphics as primary boot in MB bios and I cant seem to find anything about drivers in the graphic card control panel to config video out?? whats anoying is that it was working fine on my old card?
  #5
Old 12th January 2012, 11:39 PM
[QUOTE=venkatcr;327571]When you install a video card. the video output on the motherboard is disabled. You will be able to get video output only from the card. If you card has a VGA output, connect the cable to that
I am using the VGA on the card! not from the VGA connector of the onboard graphics but not getting a thing.
  #6
Old 12th January 2012, 11:45 PM
spirovious's Avatar
Quote:
Is this card ATI or nvidia?You can open control panal & check for the video out setting.Even try setting multiple display(clone).
  #7
Old 12th January 2012, 11:49 PM
Reputation points: 64
roseboy24 will become famous soon enough
try to disable on board VGA from POST /power on self test setup Menu
  #8
Old 12th January 2012, 11:54 PM
Quote:
Its nvidia and ive tried mutiple display, extended display, single display but nothing. Ive tried draging single and extened displays but still nothing. I still cant see any video out settings in the nvidia control panel
  #9
Old 13th January 2012, 12:22 AM
Did you try to disable Video card which installed on motherboards --default should be connected PCI VGA card ...
BIOS settings for 3.6 GHz E8400 overclock on Asus P5N-D - YouTube
try to connect computer ..and Attached the monitor, set it to primary, and rebooted....
The Following User Says Thank You to roseboy24 For This Useful Post:
  #10
Old 13th January 2012, 12:41 AM
also try to check change refresh rate 60~80Hz
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: connecting PC to AVR problem
Thread Thread Starter Forum Replies Last Post
Problem connecting WD to Onkyo 5105 with optical cable hr1981 Media & Streaming Players 4 21st April 2011 06:13 PM
Problem connecting dvd to projector and sound out to Receiver hifi1975 Surround Amplifiers/Receivers 6 10th May 2010 07:35 AM
Connecting pre-out to a Pre-amp silentsound Amplifiers 22 13th December 2008 08:04 PM
Connecting PC to LCD TV sud98 Audio & Video Cables 3 22nd November 2008 07:49 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
