HiFiVision.com - Audio Video Hi-Fi Forum
Wireless headphone buzzing
Discuss Wireless headphone buzzing at the Portable Audio Players & Accessories within the HiFiVision.com - Audio Video Hi-Fi Forum; I have this pair of wireless headphones from Frontech. Whenever I connect the transmitter to ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > Portable Audio Players & Accessories
Portable Audio Players & Accessories MP3/MP4/WMA portable audio players & their accessories like headphones, speaker systems, docks, etc
Advertise Here
Reply
Thread Tools
  #1
Old 26th August 2011, 04:58 PM
shredder's Avatar
Reputation points: 139
shredder will become famous soon enoughshredder will become famous soon enough
I have this pair of wireless headphones from Frontech. Whenever I connect the transmitter to a source like PC, hi-fi, etc. I get this buzzing sound, which is not audible for loud music but is audible for softer music. But I noticed that when I connect to a source which is powered from batteries (eg: mobile phone, iPod, etc) then the buzzing disappears. So I am guessing here that the buzzing sound has something to do with proximity to the mains.
Is there some simple solution to this?
I was also thinking of getting a pair of Philips wireless (IR) headphones. Will they also have this same problem?
TIA
Sponsored Ads
  #2
Old 26th August 2011, 09:17 PM
theironhorse's Avatar
Reputation points: 710
theironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to behold
the buzzing noise is due to the main humming....
when its on DC it wont do the same.. however there might be a slight white noise.. but that will be bearable...
also is the transmitter on battery or ac power... you can get cheapo reachargeable AAA batteries for the same. it will reduce the buzz to a great extent but wont wipe it completely..
philips are good.. senn. and logi wireless headsets are said to be noise free... not sure about prices...
Intermittent buzzing can be caused by electrical equipment located in the immediate area of the telephone and headset system, such as fluorescent lights, computers, fax machines, typewriters, and power strips (surge protectors). Frequently, power cords and cables that are bundled together will cause buzzing. The best solution is to keep this type of equipment separated from the headset, amplifier and telephone whenever possible.
Try changing channels using the channel button on your remote unit.
Try locating your base unit in different positions.
Make sure that no objects are positioned between the remote and base unit.
Be sure that neither the remote or base units are next to electronic equipment or other radio frequency devices.
another thing i noticed is if we keep the wireless headphone volume on full and control the volume from the master device.. then its the speakers in the headphone that buzz..
so keep the volume high on the master device and control the volume from the headset and you will find it more pleasing..
  #3
Old 26th August 2011, 09:36 PM
shredder's Avatar
Re: Wireless headphone buzzing
aha TIR I expected you would reply..........
However I know not what you mean by this:
"the buzzing noise is due to the main humming....
when its on DC it wont do the same.. however there might be a slight white noise.. but that will be bearable..."
what do you mean by "main humming" and what is meant by "when its on DC it wont do the same" ??
the transmitter is powered by new AAA batteries, so the cause of humming due to inadequate power can be dismissed.
like I mentioned before, the buzz is not there when connected to a battery powered device.
  #4
Old 26th August 2011, 09:38 PM
the mains ( ac ) power supply.... the humming reduces as you stated when you connect it to a stand alone mp3 player or cellphone as it not connected to AC by any means....
so its due to the interference in AC
can also be due to wireless signal in that area.. try changing the location....of the base and see if it reduces however it wont go completely....
the only option can be the good n expensive wireless headphones that will have built in AC humming isolater and can transmit cleaner sound...
  #5
Old 26th August 2011, 09:45 PM
shredder's Avatar
tried changing the location of transmitter.... no luck. Like I said humming is bearable for music but very audible while watching movies.
Do you know whether the wireless Philips headphones (SHC 1300 or 2000) have this AC humming isolater?
  #6
Old 26th August 2011, 11:02 PM
philips might not have the humming issue as the other headphones work on wireless .. this one is through infrared.. so might be less or non -existent. however network coverage might not be good and might need to be in line of sight for the same....
Audio-Technica - Microphones, headphones, wireless microphone systems, noise-cancelling headphones & more : Resolving Interference Problems
4) USE AN AC POWER ISOLATION TRANSFORMER
AC isolation transformers are common devices in electronic repair shops.
Technicians use them to isolate the power on their repair benches from
physical grounds in the repair shop (pipes, radiators, etc.) This is primarily for
safety reasons.
You can use the same isolation transformers to electrically isolate your A/V
equipment from connected AC power and thus break any ground loops. They
are typically placed in series with the power cord to the projector
We recommend the Tripp-Lite IS 250, IS500 or IS500 models
check this Ground Loop Isolator - RadioShack.com
http://www.cinemasource.com/articles/gnd_loop.pdf
First, the subwoofer: unplug the coaxial cable that connects to your powered subwoofer to see if the ground-loop hum disappears. If it does, it's likely coming in through your cable/satellite TV feed
connect all your av equipment to one ac out.. .it elimates the possiblity of ground loop and can reduce ac hum to a great extent...
The Following User Says Thank You to theironhorse For This Useful Post:
  #7
Old 27th August 2011, 11:55 PM
madbullram's Avatar
Moderator
Reputation points: 898
madbullram is a splendid one to beholdmadbullram is a splendid one to beholdmadbullram is a splendid one to beholdmadbullram is a splendid one to beholdmadbullram is a splendid one to beholdmadbullram is a splendid one to beholdmadbullram is a splendid one to behold
iron horse: Edit your posts if you want to add more info!!! Do not create news posts
  #8
Old 28th August 2011, 03:40 AM
i am sorry due to creating new posts. .but i was in office and some how due to flash issue i was not able to edit them hence new posts.. i will keep a check next time...
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Wireless headphone buzzing
Thread Thread Starter Forum Replies Last Post
Urgent! Looking for Wireless Headphone solution for mom who is Hearing Impaired andycommon What Should I Buy? 8 18th May 2011 01:00 PM
Buzzing noise from TT tek Phono/Turntables 6 30th December 2010 02:23 PM
Wireless HeadPhone requirement sgmane What Should I Buy? 1 4th November 2010 11:56 PM
For Sale Philips Wireless Headphone - SCH1300 superbhikari For Sale by Owner 2 1st March 2010 08:39 PM
Wireless Headphone suggestions... sud98 AV Lounge 4 24th February 2009 04:22 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197
