Monitor Audio Gold Signature GS60 Review
Discuss Monitor Audio Gold Signature GS60 Review at the Speaker Reviews within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Monitor Audio Gold Signature GS60 Review 200702_monitoraudio_gs60.jpg As Monitor Audio’s Gold Signature GS60 loudspeakers were ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Components > Speakers > Speaker Reviews
Notices
Advertise Here
Reply
Thread Tools
  #1
Old 4th May 2007, 12:55 PM
Neal is on a distinguished road
As Monitor Audio’s Gold Signature GS60 loudspeakers were maneuvered around my room by Sheldon Ginn, of Kevro (Monitor’s Canadian distributor), I reflected on how my attitudes toward hi-fi have changed over the years. I remembered reading my first serious review of a high-end product: a Monitor Audio Gold Signature bookshelf speaker. Reading that review, I’d thought that these two small boxes must be the absolute best speakers in the world -- after all, how could they not be something extraordinary when they cost over $1000 per pair!
That first exposure to the British company’s products must have made a deep impression. In the back of my brain, I’ve always thought of Monitor gear as very high-end, and so expensive as to be beyond the reach of all but the super-rich.
But the speakers now before my eyes didn’t mesh with my long-ago formed preconceptions. The GS60 ($3995 USD per pair) is the top model of Monitor’s Gold Signature line, and is therefore the most expensive speaker they sell. In the flesh, it manages to look both stately and modest. The combination of its 42" height and small (8 1/8"W x 13"D) footprint mean that the GS60 won’t overpower a room of modest size, as have some far larger speakers that have squatted golem-like in my basement listening room.
The GS60’s reasonably compact dimensions are offset by beautiful real-wood finishes. The finish on my samples immediately distinguished itself by what it wasn’t. Nowadays it seems almost de rigueur for a high-end speaker to be lacquered and polished within an inch of its life. The GS60s came delivered in a gorgeous, delicious walnut veneer with a matte finish more in line with high-quality antique furniture. The striations in the grain were easily visible, and the finish gave off a sense of old money that stood in stark contrast to the ostentatiously nouveau-riche gloss of some other speakers. That appearance of quality is more than skin-deep -- the cabinet panels are joined tongue-and-groove for strength, and each reasonably svelte GS60 weighs a substantial 59.7 pounds. Its sensitivity is specified as 90dB with a nominal impedance of 6 ohms so they should prove reasonably easy to drive.
As I stared at these slim, attractive floorstanders, my perception of them metamorphosed from unattainable high-end wet dream into reasonably achievable reality. What didn’t fade was my assumption that the GS60 is a genuinely high-end speaker. Its most immediately familiar driver is its gold-colored, 1" dome tweeter, visually similar to the one found in the speaker covered in that age-old review that was my introduction to the brand. Made of Monitor’s proprietary ceramic-coated aluminum magnesium (C-CAM) alloy, the GS60’s tweeter was designed to lower the driver’s fundamental resonant frequency to a claimed 500Hz; according to Monitor, this results in a smoother response and lets them use a simpler crossover.
The midrange and low-frequency drivers are also made of C-CAM, though they’re not gold-anodized. The 6.5" midrange is run full range up to its natural high-frequency rolloff point, as Monitor believes that a capacitor would degrade the sound; the cap’s absence results in increases in clarity and small-scale detail. According to Monitor, their Rigid Surface Technology (RST) cones, which feature a dimpled surface, add sufficient stiffness to the assembly to allow for more linear high-frequency performance and better power handling.
The GS60 comes with a nicely made grille that looks quite natty when attached. The speaker is attractive without the grille, however -- the contrast of the rich wood, the silver midrange and woofer cones, and the tweeter’s gold dome enhances its appearance without appearing overly ostentatious. I left the grilles off. The fairly tall, narrow cabinet is stabilized by a metal plinth that is an inch or so wider and deeper. Monitor supplies the GS60 with a set of nasty-looking spikes that should have no trouble piercing the thickest carpet. I have hardwood floors, so I especially appreciated the inclusion of a set of rubber-damped feet that screw into the bottom of the plinth instead of the spikes. The GS60 has two sets of nicely made and widely spaced binding posts, but I single-wired them with the supplied jumpers.
System and setup
I evaluated the GS60s in my main system, driving them with my Anthem Statement P2 amplifier by way of single-wire Acoustic Zen Satori speaker cables. For most of the review period I used the most excellent Song Audio SA-1 preamplifier, with my Sonic Frontiers SFL-2 also seeing some duty. My Benchmark DAC1 received bits from a Toshiba SD-3750 DVD player by way of a homebrew Canare digital cable.
A Pro-Ject RPM 10 turntable (review forthcoming) did most of the source duties. Early in the review period I used a Shelter 501 Mk. II cartridge, but about halfway through I remounted my long-neglected Roksan Shiraz -- too long had we been apart. Phono-preamplification duties fell to my Ayre P-5xe phono stage.
Interconnects were, for the most part, Analysis Plus Solo Crystal Oval for balanced signals, and Acoustic Zen Matrix when running single-ended. AC was transmitted via Shunyata Research Taipan or Cardas Hexlink 5 power cords; a Shunyata Hydra Model-6 line conditioner filtered the power and protected my gear from surges.
After Sheldon Ginn had left, I spent quite a while searching for the best locations for the GS60s. My listening room is fairly small, but it’s bass-hungry -- its 230 square feet open onto a much larger room by way of a staircase, and behind my listening seat are shelves holding more than 2000 records. The WLM Duo 18 subwoofer’s two 18" drivers never overload the room; conversely, a smaller speaker such as the GS60 needs a bit more boundary reinforcement than might seem ideal. Whereas some larger speakers have been comfortable 36" out from the front wall, I had to shove the GS60s about 7" farther back. That still gave them plenty of breathing room, and neither their imaging nor their soundstaging suffered. After I’d got them situated to my satisfaction, I sat down for a listen. According to Sheldon Ginn, my review samples had already had some serious playing time, so I didn’t worry about break-in.
Sound
I’ve noticed over the years that certain albums shine when played through a particular piece of audio equipment. When I began regularly swapping gear in and out of my system (read: reviewing), I tried to give all different forms of music a fair shake, which meant steering myself away from repeated listenings to one particular album. Nowadays I don’t care what I listen to, and let my instincts tell me what record should find its way onto the turntable. If the same album spins repeatedly, well, that tells me something about what the component is doing. Think of my turntable as a musical Ouija board.
Jazz recordings of all kinds seemed especially suited to the Monitor GS60s’ adept way with space, and the speakers led to my possession by Miles Davis -- specifically his Filles de Kilimanjaro [Columbia PC 9750]. Throughout my time with the GS60s, Filles was never far from the turntable, and this oddball album epitomized all that these British speakers did so well. My first impression was of a lively, quick, revealing sound, with a tight, tuneful bottom end and exceptional imaging, and it took me only a few more minutes to thoroughly appreciate the GS60s’ ability to re-create an enveloping acoustic space in my room. The rhythm section holds Filles together, and while the GS60s definitely tilted toward the lean end of the spectrum, they delivered tight, tuneful, authoritative bass. The GS60 is claimed to extend down to 28Hz (no rolloff is specified), and from my listening, the claim seems reasonable. But more important, in my opinion, the bottom end politely refrained from intruding on the midbass, which worked just swell with Ron Carter’s low-level, always-working electric bass, while keeping each whack of Tony Williams’ kickdrum a distinct event.
Exceptionally tight bass without bloat can at first sound somewhat unimpressive, but ends up being much more satisfying over the long haul than a tubby, flatulent low end. The GS60’s low end was definitely of the self-effacing type -- but then, when I least expected it, in would slam a deep, resonating bass note right where it needed to be, and up would go my eyebrows as these svelte columns cranked out some serious low end. My initial impression that the GS60 was a bit on the lean side gradually modified itself with the qualification that they also delivered serious heft when it was called for.
Up through the midbass and into the midrange the GS60 really began to shine, strutting its stuff with poise and self-assurance. Staying with Filles de Kilimanjaro for a little bit, I found it exceptionally easy to differentiate between the often entangled musical lines in the busy and rhythmically complex "Frelon Brun (Brown Hornet)," which is no small feat -- this track has tripped up many a component in my system.
But while the GS60s did a bang-up job on "Frelon Brun," my estimation of their performance moved up a big notch when I heard them render the spacious "Tout de Suite" with double helpings of space around Davis’ ethereal trumpet. In relation to Williams’ crisp cymbals, the trumpet and Wayne Shorter’s tenor sax took on a bit more of a distant quality than I’m used to, which may well indicate that the midrange was somewhat down in level compared to the octaves above. No matter -- the very slightly recessed midband only helped underscore the delightful manner in which the GS60s re-created an acoustic space.
After laying it aside for a few months, I decided it was time to put Giant Sand’s Chore of Enchantment back in regular rotation. Those of you who’ve read my reviews over at SoundStage! know how highly I think of this album, and nothing much has changed. This combination of Southwestern desert rock and acoustic folk, seasoned with a dash of thrash metal, has to be one of my favorite albums of the last five years. Howe Gelb’s granular tenor can prove problematic for some speakers, but the GS60 exhibited absolutely zero overhang on male vocals -- no resonance, chestiness, or thinness, even on such tracks as the exceptionally close-miked "Dirty from the Rain," in which Gelb sounds as if he’s just swallowed the microphone.
For their vinyl edition of Neil Young’s Greatest Hits [LP, Reprise/Classic 48935-1], Classic Records has worked wonders with some of the older tracks, exhuming more crispness and clarity than I’d have ever thought possible. "Cowgirl in the Sand" was never one of my favorite songs, but it took only one spin on the ’table to seriously invigorate my ears. Young and his band are possessed of an almost sloppy looseness that entirely belies the deep groove in which they lock themselves. The Monitor GS60s locked into that groove themselves, presenting it with an exciting feeling of immediacy. Classic has mastered Greatest Hits a touch on the hot side, and the highest notes of Young’s extended electric-guitar solos could get a bit more bitey than through my Hales Audio Transcendence Five speakers. In fact, with many recordings I was aware that the highs tended to be quite prominent. Poorer recordings that were themselves somewhat bright gained a tiny bit of extra presence in this region, but, contrary to my early expectations, the GS60s didn’t tilt my listening choices toward only well-engineered, neutrally balanced recordings.
Although the GS60’s highs were very slightly prominent, they were truly grainless, and among the purest I’ve heard. Cymbal overtones were extraordinary in their purity, and the speaker uncovered startling layers of harmonics. My Canadian edition of Tom Waits’ Blue Valentine [LP, Asylum 6E-162] isn’t exactly an audiophile pressing, but it’s the music that matters, right? Waits was in fine form in 1978, and on "$29.00" the GS60s pulled it all together to present him at his smoky best. Every cymbal stroke stood out in crisp, natural relief, and although those cymbals were very slightly elevated in level, they remained engaging rather than stepping over the line to induce listener fatigue.
Nancy Wilson and Cannonball Adderley’s 1961 self-titled album [LP, Capitol/EMI SM-1657] was the last I listened to through the Monitor GS60s, and it summed up everything the speakers did so well. I know this LP intimately -- I’ve listened to it on every combination of gear I’ve had in my house. There’s a fair bit of sibilance on Wilson’s voice, and a nasty slice of glare to boot, but the album is nonetheless delicious, and the GS60s served it well. On "A Sleepin’ Bee," the loping bass kept tuneful pace with the crisp drums, and Wilson’s vocals were well defined within a spacious, deep, equally well-defined soundstage. I played this track several times, tremendously enjoying it each time, before reluctantly unhooking the Monitors from my system and packing them up.
Conclusion
There’s much to recommend in the Monitor Audio Gold Signature GS60. It’s a top-of-the-line speaker from a well-established manufacturer well known for producing high-quality products, and it retails for an entirely reasonable $3995/pair. While five bucks less than four kay isn’t exactly chump change, it’s waaay easier to spend more and get less than it is to spend less and get more.
Of course, as with any speaker, I have a couple of caveats about the GS60. Those who prefer a reticent treble or a prominent bass will want to audition it before purchase, but I’d wager that there are few who would buy a speaker of this pedigree without an extended listening session.
For the rest of us, it’s entirely possible that the GS60s’ combination of a thoroughly uncolored midrange, a detailed but butter-smooth treble, a trap-tight bass, and miles-deep imaging will inspire us to invite an English speaker into the house.
…Jason Thorpe
jason@ultraaudio.com
Source: http://www.ultraaudio.com/equipment/...audio_gs60.htm
Sponsored Links
  #2
Old 31st July 2007, 12:21 PM
SHANTI's Avatar
SHANTI is on a distinguished road
Re: Monitor Audio Gold Signature GS60 Review
Lovely Speaker.
Sold in India by The Audio People - Chennai.
Ex-Stock.
Call for demo & audition.
Shanti
  #3
Old 1st September 2007, 06:44 AM
banilk75 is on a distinguished road
Whats the current Price in INDIA ?
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Monitor Audio Gold Signature GS60 Review
Thread Thread Starter Forum Replies Last Post
Cambridge Audio Azur 740C CD Player Review Neal CD Players Reviews 2 10th June 2007 09:39 PM
Monitor audio - Bangalore dealer sandeepk Speakers 4 24th April 2007 04:53 PM
Cambridge Audio AZUR 840C review HiFiVision CD Players Reviews 0 6th March 2007 10:51 AM
Cambridge Audio Azur 640A v2.0 Amplifier Review Jagat Amplifier Reviews 1 27th August 2006 09:29 AM
Advertise Here
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
