Humming...
Discuss Humming... at the Surround Amplifiers/Receivers within the HiFiVision.com - India's Audio Video Hi-Fi Forum; My apologies if this question is a repeat or a noobe one! I get a ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 16th May 2008, 02:39 AM
unleash_me's Avatar
unleash_me has a spectacular aura aboutunleash_me has a spectacular aura aboutunleash_me has a spectacular aura about
Exclamation Humming...
My apologies if this question is a repeat or a noobe one! I get a constant ‘humm’ from my speakers when ever I connect any analogue inputs in my receiver (Denon 4306). How can I fix this?!
I see that on backside there is “Signal Ground or Grounding/Polarization” near the Antenna section as well as around the center of the reciever, is it something I can fix this with?
Should I get the receiver serviced or is this something I should be fixing it from my end?
Thanks in advance!
http://usa.denon.com/avr4306_back_rdax_1200x462.jpg
Note: I asked this question elsewhere also, so common members please excuse
Sponsored Links
  #2
Old 16th May 2008, 03:02 AM
suniil is on a distinguished road
Re: Humming...
is it common for all analogue devices connected?
I'm sure you know all these, but just cross-checking
as a starting point, i would disconnect everything from the circuit except the AVR & one device connected to analogue inputs of AVR. If the hum still exists disconnect earthing from the circuit and test again. Please disconnect any arials / cable tv connection etc too before testing
Quote:
  #3
Old 16th May 2008, 08:34 AM
dinyaar's Avatar
dinyaar has a spectacular aura aboutdinyaar has a spectacular aura about
Re: Humming...
Hi Unleash,
Ya disconnect all and reconnect and see. Am not familiar with most AVR s but the signal ground should be only for a turn table. Are u using some extension box/power strip with an inbuilt fuse? My Nakamichi tapedeck had a hum when connected to a powerstrip but the hum vanished when directly plugged into the wall outlets. A tuner is also notorious for all kinds of induced noise. Are u using shielded ICs? Else move them a bit and see.
Actually i too am having some electrical interference in my set up and am considering an Isolation Transformer of 2KVA.
  #4
Old 16th May 2008, 01:14 PM
awedeophile's Avatar
awedeophile is on a distinguished road
Re: Humming...
Hi, I have had this problem in the past and could possibly help. Some questions:
1. How loud is the hum?
2. What equipment is connected to the receiver?
3. Is the hum constant regardless of the volume level?
4. Is any of the equipment connected to electrical earth via the mains plug?
5. What is the equipment that gives a hum when connected?
6. Is there hum even if the RCA's are connected to the receiver and not connected on the other end?
  #5
Old 16th May 2008, 06:38 PM
unleash_me's Avatar
Re: Humming...
Thank you all for helping me out here.
Sunil,
The “humm” is common across all the analogue inputs. Don’t know how to disconnect the earthing as I haven’t done any earthing as such myself. And yes, I have not connected any aerials or cable tv connections, except for the FM receptor.
Dinyaar,
I’m not sure if the humming was always there, but yes I’m using an surge protector/extension-strip at the moment. When I noticed the buzz, I tried with at least 4 different extension-strips lately. Nothing seems to fix this. Infact, like you mentioned if an Isolation Transformer is the way to go, might as well try that. Btw, I have connected the extn strip to a 1kv servo stabilizer; don’t know if this helps.
Awedeophile,
Here are your answers buddy.
Well it becomes noticeable from around -20db and becomes quite high when I go to the ‘00’ level. Not to mention the upper limits.
TV audio-out, RCA to 3.5mm and a CDP at the moment with the respective analogue i/p in the reciever.
No it is not. It increases with the volume level.
I’m completely unaware of this and frankly I don’t know how to do/undo this. I stay in an apartment complex, so don’t have any clue about the earthing circuitry-if I have understood you correctly.
Interestingly, any equipment regardless of the respective input mentioned in the AVR, generates a humm. CDP give out more, in my opinion. I have mixed and matched all the sources in question and selected the respective mode in the reciever, the humm seems to be constant across the analogue inputs.
This is something I’ve not tried. Will do it tonight and let you know.
The fact is the "humm" is irritating the hell outta me, its like a bee buzzing around your head. Either I'm too sensitive regarding sound or my wife needs to consult an ENT, cuz she seems to be the least bothered with all this!
Again, thank you guys for chipping in. Really appreciate it. Awaiting for your response.
  #6
Old 16th May 2008, 09:09 PM
dinyaar's Avatar
Re: Humming...
Hi again,
If the hum can be heard its a problem that should be solved!!! U are using a 1KVA stabilizer for all the AV? Is that sufficient? Not that i feel thats the culprit. Try an Isolation transformer from some Bglore Co, as if it does not solve the problem u need not buy it.
Actually Awedeophile is a guru for all this. He suggested a UIT to me.
In my opinion ur problem could be related to the earthing.
  #7
Old 16th May 2008, 09:28 PM
Re: Humming...
Just disconnect the earth pin from your extension cable and see how it goes.
Quote:
  #8
Old 17th May 2008, 09:34 AM
Re: Humming...
With everything else in place, remove the Cable TV wire from your TV and tell me if the hum goes or stays.
If any of your components has a 3 pin plug, you're probably connected to earth. In a 3 pin plug the top (thicker) one is the earth. Are any like this?
  #9
Old 17th May 2008, 02:21 PM
Re: Humming...
LOL.. Not at all.. Just know a bit from similar experiences.
  #10
Old 18th May 2008, 08:35 AM
mukand's Avatar
mukand is on a distinguished road
Thumbs up Re: Humming...
Ground loop
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Humming...
Thread Thread Starter Forum Replies Last Post
Help me resolve humming noise problem gobble Amplifiers 29 29th October 2009 05:41 PM
Humming Sound churfsan Surround Amplifiers/Receivers 18 20th January 2009 04:27 PM
Help! Humming sound when I switch on.... ckn Speakers 4 27th December 2008 02:12 AM
Advertise Here
Copyright © 2006-2010, HiFiVision.com All Rights Reserved.
Recommended Websites - www.CameraVision.in
