HiFiVision.com - Audio Video Hi-Fi Forum
How to connect AVR to PC
Discuss How to connect AVR to PC at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; @surinder.. I used a XFi fatality also. The issue is Xfi card shove lot of ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #11
Old 3rd September 2010, 11:07 AM
m-jeri's Avatar
Reputation points: 24
m-jeri is on a distinguished road
Re: How to connect AVR to PC
@surinder..
I used a XFi fatality also. The issue is Xfi card shove lot of stuff like EAX and what nots and yeas the sound maybe not what u want.
Its better to use kernel streaming as a user above said.
Or try this first.. using the console launcher..turn off ALL the settings that Xfi gives..the crystaliser..EAX..and lots.. and try then. dont think then also u will be getting the pure sound.
Sponsored Ads
  #12
Old 3rd September 2010, 01:31 PM
Reputation points: 187
ontherocks has a spectacular aura aboutontherocks has a spectacular aura about
This may help someone.
Types of S/PDIF(digital) outputs seen in Laptops
1. Digital Coaxial along with Stereo analog in the same headphone jack (Most common type )
How to connect it to AVR?
I. Get a 3.5mm Mono to RCA adapter. Then connect a coaxial cable from it to your AVR's coaxial input.
II. Get a 3.5mm Mono to RCA digital coaxial cable. (hard to find). Then connect it from your laptop's headphone jack to your AVR's coaxial input.
2. Digital Optical along with Stereo analog in the same headphone jack (Notice the red light coming out from the LED inside the headphone jack)
I. Get a mini toslink to toslink adapter. Then connect a optical cable from it to your AVR's optical input.
II. Get a mini toslink to toslink optical cable. Then connect it from your laptop's headphone jack to your AVR's optical input.
3. Dedicated Digital Coaxial output
I. Use a digital coaxial cable from laptop to AVR's coaxial input.
4. Dedicated Digital Optical output (Most rare)
I. Use a digital optical/toslink cable from laptop to AVR's optical input.
5. HDMI output (which supports audio output, not passthrough)
I. Use a HDMI cable from laptop to AVR's HDMI input.
And lastly the most common scenario.
6. No S/PDIF output
I. Get a 3.5mm Stereo to RCA adapter. Then connect a Stereo RCA cable from it to your AVR's Sreteo Analog input.
II. Use a 3.5mm Stereo to RCA cable. Then connect it from your laptop's headphone jack to your AVR's stereo analog input.
  #13
Old 3rd September 2010, 11:20 PM
Reputation points: 16
surinder1508 is on a distinguished road
Guys I checked settings myself a bit my Onkyo 807 showing audio input signal format as PCM and audio input indicator as digital.
Now after checking a bit deeper with my sound card's controls I found can control and use only front left/right channels from my PC but my AVR controlling and using all 5.1 channels. So is that means I'm feeding unprocessed audio stream to AVR.
  #14
Old 3rd September 2010, 11:36 PM
spirovious's Avatar
Reputation points: 1933
spirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant future
XP dont support native 5.1 via SPDF,you need to change some settings-
HOW TO - Set up SPDIF output - Sound-Cards - CPU-Components
SPDIF out from MB header to optical?
When I tried for xonar,I disabled/changed sound devices from speakers to other setting ,dont recollect.
  #15
Old 4th September 2010, 03:20 PM
Well guys I Google bit more about my sound card and found that it can only give stereo sound at max through its Optical out and I confirmed it as well by using AVR's listening mode as direct after doing so only FR/FL are flashing on AVR's speakers indicators and only these two channels are giving sound as well in that mode so I think a was getting virtual 5.1 channel sound generated by my AVR previously by listening mode selected as (THX cinema) Dolby digital pro logic II.
Even in windows 7 I could found (2 channels, 24 bit,48000 Hz) under advanced tab in SPDIF out properties. But in supported formats tab in SPDIF out properties I found DTS audio, Dolby digital ticked and in test there all the 5.1 speakers playing test tones. So where I'm and how can I get proper unprocessed 5.1 channel audio stream of MKV files from my PC to AVR?
And can I even use my mother board's (Asus P5KPL-CM) SPDIF connector to achieve my purpose.
Or can I use three 3.5mm Stereo to RCA cables one for FL/FR, one for RL/RR, and one for center/sub but I think although I'll get all 5.1 channels doing so but these will be firstly analog and secondly processed as well by the sound card.
  #16
Old 5th September 2010, 09:36 AM
spirovious's Avatar
It can with MB-
ASUSTeK Computer Inc.-Forum- 5.1 out of SPDIF Coaxial w/ Vista?
SC-
How to Use the SPDIF Output from Sound Blaster X-Fi Sound Cards | Hardware Secrets
specification of SC says multich out of DVD as raw possibble-
Sound Blaster X-Fi XtremeGamer | Creative Labs Online Store
Xonar option-
https://vip.asus.com/forum/view.aspx...Language=en-us
  #17
Old 6th September 2010, 11:25 AM
Nothing seems working for me out of these I tried SPDIF out from motherbord to my XFX 260 GPU audio in then used DVI to HDMI converter to hook it up to AVR's HDMI in but to no avail still got damn two channels.
And I have to forget about my x-fi xtremegamer as well as it is no way going to bypass anything beyond two channels.
So I'm going to change my GPU from XFX 260 216 BE to one of 460/5850/5770 as all these support 7.1 channel bit streaming through HDMI hopefully should be a straightforward affair if I believe on what is advertised out there on the net. So I only hope it should work without any further/new hiccups although I'm not very sure about that as well after having very bad and time consuming experience with my sound-card and motherboard SPDIF.
So members please give your inputs on that option.
  #18
Old 6th September 2010, 02:02 PM
Quote:
Getting multichannel digital output from S/PDIF is fairly straightforward.
You are doing something wrong I guess.
If you are taking out S/PDIF output directly from the MOBO why is XFX 260 coming in between?
Take a coaxial cable and hook it from your MOBO's S/PDIF output to your AVR's digital coaxial input.
Why do you want to go the HDMI route?
Post screen shots of the windows controller where you specify S/PDIF output.
If you still face problems, I can help you if come online sometime in some chat messenger.
  #19
Old 6th September 2010, 02:16 PM
spirovious's Avatar
OK,but did you email creative?
XP dont support 5.1 natively as said earlier.I tried vlc >spdf out> AVR reads as DD/Dts (raw).
I just got the link how I cld get that-
ASUSTeK Computer Inc.-Forum- How ASUS XONAR handles DTS/DD to SPDIF OUT
http://www.hifivision.com/home-theat...sic-pc-12.html
Just see if it works...some XP speaker changes.
  #20
Old 6th September 2010, 03:32 PM
I have to get xfx 260 in between cause I own all the stuff required for this chain like SPDIF cable, DVI to HDMI converter and HDMI cable.
But I couldn't found SPDIF bracket to connect my AVR with motherboard's SPDIF out and I haven't coaxial cable with connectors as well to go other way. So if someone help to get me this braket I can try this option as well.
http://www.helpingwindows.com/_/rsrc...if_bracket.jpg
And here are screen shots
http://img121.imageshack.us/g/newbitmapimage2r.png/
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: How to connect AVR to PC
Thread Thread Starter Forum Replies Last Post
pc to tv connect jayantadak Blu-ray/DVD players & DVD/hard-disk recorders 4 19th May 2010 09:22 AM
pc to tv connect jayantadak Television 1 18th May 2010 10:23 PM
pc to tv connect jayantadak Home theater PC (HTPC) or media PC 1 18th May 2010 10:20 PM
how to connect richard.ezeckial AV Lounge 8 9th February 2010 01:07 PM
How to connect PS3 to a AVR bazee Surround Amplifiers/Receivers 2 18th December 2008 06:11 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197
