HiFiVision.com - Audio Video Hi-Fi Forum
How to connect AVR to PC
Discuss How to connect AVR to PC at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; I'm using onkyo 807 connected with my PC via optical out of creative x-fi xtreme ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 24th August 2010, 08:47 AM
Reputation points: 16
surinder1508 is on a distinguished road
I'm using onkyo 807 connected with my PC via optical out of creative x-fi xtreme gamer sound card but I think I'm getting processed audio signal from my sound card so how can I feed unprocessed audio signal to my AVR so it can do all the audio processing.
Advertisements
Advertisements
  #2
Old 24th August 2010, 09:28 AM
spirovious's Avatar
Reputation points: 1956
spirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant future
Re: How to connect AVR to PC
How did you know that sound is processed?
Which Operating system are you using?
Are you talking of movie sound only?
  #3
Old 25th August 2010, 10:45 PM
I'm thinking that way cause I'm getting all the features and controls available from my sound card's own controller program as earlier without AVR and I'm very use to with sound generated by this ages old card and I'm not getting any significant improvement by hooking up Onkyo 807 AVR. The sound is very similar what I was getting without this AVR.
So am I feeding the AVR processed signal and I have to hook up AVR to PC some other way to get most out of my equipment please suggest.
I'm using Windows XP SP3 and I'm talking about movie and mp3 audio.
  #4
Old 25th August 2010, 11:15 PM
spirovious's Avatar
If you add a ATI card,all process will be simple.
http://www.hifivision.com/home-theat...series-11.html
  #5
Old 26th August 2010, 12:33 AM
Reputation points: 187
ontherocks has a spectacular aura aboutontherocks has a spectacular aura about
Use kernel streaming and bypass Windows Kmixer.
  #6
Old 26th August 2010, 08:35 AM
Quote:
Please elaborate.
  #7
Old 26th August 2010, 12:02 PM
If you want to read what is Windows KMixer, see here KMixer
Now you would ideally want Windows not to fiddle/process the sound and sort of pass-through the original unprocessed audio to an external device (here your onkyo 807). To do this you have to use what is called Kernel Streaming (more about it here Kernel_streaming).
How to achieve it?
Use Foobar (foobar2000) as the audio player and use its Kernel Streaming plug-in (foobar2000: Components Repository - Kernel Streaming support).
Or you could also use Winamp (Winamp Media Player - MP3, Video, and Music Player - Winamp) as the player and use its Kernel Streaming plug-in (http://www.stevemonks.com/ksplugin/).
How to know if Kernel Streaming is working?
When you play something with the above players with the aforesaid plug-ins you will notice that you cannot control the audio with any Windows controls (volume, any DSP, etc). The whole unprocessed audio is passed to the external device.
The Following 4 Users Say Thank You to ontherocks For This Useful Post:
  #8
Old 26th August 2010, 01:20 PM
edjamesx's Avatar
Reputation points: 31
edjamesx is on a distinguished road
Surinder ,
What media player you are using ?. if you are using windows media player , only 11 or above version only have the support to send raw audio to receiver.
Other players
VLC player
Home cinema media player( open source... its best) - good for music/HD movies/DVD movies
Power DVD player - good for DVD movies/music playback
In these players you can choose the option to send the audio via the digital output and you should be able to set the bit rate. This matters for sound quality. Set the bit rate 32 or 48.
I have windows 7.. having the option in volume control intself to choose the default sound output.
I have a SIIG sound card has digital output connected to my amp via SPDIF.
And works well with these players.
  #9
Old 3rd September 2010, 10:27 AM
My sound card has digital out and I have connected my AVR to PC using it but I'm not sure if I'm getting processed or unprocessed audio please some one do let me know as one forum member on an other forum told me I'm getting unprocessed audio but then again if I'm getting it unprocessed then I shouldn't be able to control all the functions, features and effects of my sound card from my sound card controller program from PC like previously but I can. So what I'm getting right now?
  #10
Old 3rd September 2010, 10:56 AM
spirovious's Avatar
splash player is another good option.
Advertisements
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: How to connect AVR to PC
Thread Thread Starter Forum Replies Last Post
pc to tv connect jayantadak Blu-ray/DVD players & DVD/hard-disk recorders 4 19th May 2010 10:22 AM
pc to tv connect jayantadak Television 1 18th May 2010 11:23 PM
pc to tv connect jayantadak Home theater PC (HTPC) or media PC 1 18th May 2010 11:20 PM
how to connect richard.ezeckial AV Lounge 8 9th February 2010 02:07 PM
How to connect PS3 to a AVR bazee Surround Amplifiers/Receivers 2 18th December 2008 07:11 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
