HiFiVision.com - Audio Video Hi-Fi Forum
5.1 home theatre package within Rs. 50000
Discuss 5.1 home theatre package within Rs. 50000 at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; Hello everybody! I am new to this forum. I want to buy 5.1 HT package ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 1st September 2010, 08:04 PM
mkm mkm is offline
Reputation points: 11
mkm is on a distinguished road
Hello everybody! I am new to this forum. I want to buy 5.1 HT package within Rs. 50000/-. I have a 32" LCD TV. I dont have much idea of HT packages, but I have the ear to listen good quality sound. The HT package should include two floor standing speakers. My preferences are mostly for movie, but audio quality should also be fare. I live near Durgapur, West Bengal. So the availability should be around durgapur/kolkata.
Sponsored Ads
  #2
Old 6th September 2010, 12:30 PM
Deepchand's Avatar
Reputation points: 22
Deepchand is on a distinguished road
Re: 5.1 home theatre package within Rs. 50000
Quote:
50 K is a good budget for a 5.1 and I am sure you will pick up a good set eventually. But, I'd advice you google some more about HT's, HTIB's, and AVR's, Ohms, wattage and most importantly decoders and connectivity.
I put a couple of links here FYI. You could also keep digging into this forum for more knowledge.
Abt Electronics Home Audio Receiver Buying Guide
AV Receiver Buying Guide- AxiomAudio
We will talk of brands and prices once you have gathered enough stuff.
Best
Deepchand
  #3
Old 20th September 2010, 12:26 PM
Reputation points: 14
sunild is on a distinguished road
Dear All ,
I am new to the group good that ,my requirement was already posted in this thread but some additional details.as am not much familiar with the Hi-fi systems you help will be greatly appreciated.
am planning to buy r Home theater total to spend 1.2 lakhs which includes bellow
50 k for 7.2 home theater (Receiver ,Speakers and cables)
20 k for dvd player .
50 k for LCD.
i would like to go for TX-SR608 Receiver , i would like to know about speakers ,which brand to buy,if possible please provide prices.
am so much confused about the speakers as there are so many brands with pros and cons.
Any suggestion on above requirement highly appreciated.
Sunil
  #4
Old 20th September 2010, 03:38 PM
amystery is on a distinguished road
Quote:
Originally Posted by sunild View Post
Dear All ,
50 k for LCD.
Sunil
The budget you've decided for the receiver and the 7.2 Channel speakers would fall terribly short.. I would suggest to re-allocate the budget and go for lesser number of channels..
  #5
Old 21st September 2010, 04:17 PM
Reputation points: 327
sud98 is a jewel in the roughsud98 is a jewel in the roughsud98 is a jewel in the roughsud98 is a jewel in the rough
Dear All ,
50 k for LCD.
Assuming your primary requirement is movies and not music, do also give your room size as it will help in offering suggestions.
Are you sure you want to look for a dvd player or want to move to a blu ray player?
DVD players are in the 5k range and the budget blu rays are in the 10k range.
Add that budget to your receiver/speakers/cables.
Unless your room is really large you can put off the second sub woofer for later. Since most blu rays and all dvd's only give 5.1 you might get better value with a 5.1 speaker system.
For pricing, there are separate threads under the speaker sections which will give you a range of speakers under different price bands.
For a 50k budget, you might be better off with a Htib like the Onkyo options rather then a separate receiver and speakers which may go beyond your budget.
  #6
Old 21st September 2010, 05:27 PM
Dear All Thanks for all your suggestion.
Budget is not a matter ,but i would live to have a high end Receiver and speakers ,mainly to experience best audio and video.i can go little more higher in the budget till 75000 Rs for Home theater.
Please suggest 7.2 Receiver and Speakers brand for the same.
Sunil
  #7
Old 21st September 2010, 07:01 PM
b4u b4u is offline
b4u is on a distinguished road
Take demo of Harman Kardon - AVR 134 wid Speakers HKTS 9...
The Following User Says Thank You to b4u For This Useful Post:
  #8
Old 21st September 2010, 10:16 PM
theironhorse's Avatar
Reputation points: 703
theironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to behold
hey sunil welcome to forum..
20k for dvd player is too much.. u can get a good one for 4-5k or a bdp for 10k
\and 75k is decent amount to start with
however if u are investing that amount i would suggest you to
build ur htib sequentially.. get an avr.. then front speakers and slowly add the sub and surrounds. that way u will be able to get the best out of ur money.
try auditioning denon,marantz,yamaha. see what sound rings a bell in ur heart.
The Following User Says Thank You to theironhorse For This Useful Post:
  #9
Old 22nd September 2010, 01:15 AM
mkm mkm is offline
Best
Deepchand
Hello Deepchand, thanks for your reply. According to your advice I have done some research and already baught Denon 1611. And also extended my budjet upto 75000/-. But cant afford more than that. My room size is 16' X 12'. I have also chosen some speakers after going through some threads in this forum and also considering my budget. My budget is around 45000/- coz already spent 29000/- on AVR.
I have chosen-
1. Polk Tsi 300 FS
Polk Cs 10 for centre
Wharf 9.1 bookselvs for rear
and Wharf SW 150
another option may be-
2. Sonodyne Sonus 2605 FS
Sonodyne Sonus 2401 Centre
and Wharf SW 150
Do the above configuration match? I have only auditioned Sonodyne in durgapur. It sounds really good to me. I cant do frequent audition as I live near Durgapur and for audition I have to go to Kolkata.
I need suggessions from the experts in this forum.
  #10
Old 29th September 2010, 09:15 PM
Reputation points: 88
techboy will become famous soon enough
I would suggest going for Monitor Audio or Wharf 9.2 or above.
Try to not go for Polk.
Wharf 9.5 + 9.2 should do a good job.
Monitor Audio is very good too, some models may not have that much bass though.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: 5.1 home theatre package within Rs. 50000
Thread Thread Starter Forum Replies Last Post
Upgrade 5.1 Speaker Package or Buy a BookShelf+Stereo Amp for Rs 50000-60000 rana_kirti Speakers 4 24th September 2012 05:48 PM
5.1 Speaker Package for Rs 50000-60000 rana_kirti Speakers 7 17th July 2010 09:03 PM
Need your advice for selecting home theatre speaker package akrish01 What Should I Buy? 7 11th June 2010 09:05 PM
Home Theater package for <1 lakh sforsuresh Introductions 22 22nd June 2009 10:03 PM
Need your suggestion in buying a package home theater system for home purpose piyushcom Home Theater 18 25th January 2009 10:48 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195
