HiFiVision.com - Audio Video Hi-Fi Forum
Denon AVR and laptop connect issues
Discuss Denon AVR and laptop connect issues at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; I am having issues connecting my laptop hdmi output to denon 1911 avr. There is ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 10th September 2010, 03:07 AM
Reputation points: 10
sdeva is on a distinguished road
I am having issues connecting my laptop hdmi output to denon 1911 avr. There is no video/audio at all on the tv. I have HP media center laptop which has a Nvidia graphics card (geforce 9200M GS). This is terrible for me because I was always hoping to play video from my laptop along with better sound from denon avr.
I also took my laptop to profx to see if it works with any denon at all. I could check with another 1911 and some other high-end avr (probably 4300) but the the result is same. One of the sales manager there had another laptop and that seem to connect fine. They suggested to upgrade display driver for my video card and they said they will check with denon and nvidia to see if it is a known issue. Apparently, nvidia folks use denon receivers for some testing it seems.
I came back and updated my driver and still unable to see even a flicker on the screen when I am feeding input from the laptop.
BTW, I almost forgot If I connect the laptop directly to the TV via HDMI It comes out crystal clear in full hd (1080p) so I am assuming it has something to do with denon avr.
Any help is hugely appreciated.
thanks,
-Srinivas.
Sponsored Ads
  #2
Old 10th September 2010, 04:07 AM
theironhorse's Avatar
Reputation points: 711
theironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to beholdtheironhorse is a splendid one to behold
Re: Denon AVR and laptop connect issues
hi ... if u are connecting laptop through hdmi.. chk for the display settings in nvdia .. in control panel and what os are using on it so we can help accordingly..
  #3
Old 10th September 2010, 01:08 PM
Thanks for extending the help. I am using windows 7 64bit. I checked all possible settings in nvidia control panel. I tried with various resolutions and refresh freq, but still nothing happened. Is there anything you want me to specifically check?
  #4
Old 12th April 2011, 02:07 PM
Reputation points: 11
iamanand is on a distinguished road
Hi sdeva,
Is this working now for you? I am also trying to connect my laptop to denon AVR but doesn't seem to be working..
Can anyone help on this?
-Anand
  #5
Old 12th April 2011, 03:03 PM
abhijeet.ghosh's Avatar
Reputation points: 31
abhijeet.ghosh is on a distinguished road
Hi, I have a Denon AVR 1911 and connected it to my Dell studio laptop via HDMI.. it was a breeze. No handshaking issues connected in one shot.
  #6
Old 12th April 2011, 03:08 PM
Kittu's Avatar
Reputation points: 1020
Kittu has much to be proud ofKittu has much to be proud ofKittu has much to be proud ofKittu has much to be proud ofKittu has much to be proud ofKittu has much to be proud ofKittu has much to be proud ofKittu has much to be proud of
Can you tell us what is the exact problem in detail ? . I have connected a laptop and desktop with nvidia cards to many AVRs I auditioned and never had any issue.
Try connecting to the front HDMI port. Make sure your nvidia shows/detects denon 1911.
Reply
Bookmarks
Tags
denon, hdmi, laptop, nvidia
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Denon AVR and laptop connect issues
Thread Thread Starter Forum Replies Last Post
How to connect HP laptop to Samsung LCd cosmoss_1974 Television 5 14th July 2010 06:19 AM
Connect Laptop to LCD TV Karanboochra Television 15 7th June 2010 02:00 PM
How to connect my laptop with HT? saurabh81 Home theater PC (HTPC) or media PC 17 28th August 2009 12:52 PM
How to connect Laptop to AVR? chella Surround Amplifiers/Receivers 19 26th August 2009 01:24 AM
How to connect a laptop/PC to a HTiB ? ash147 Home theater PC (HTPC) or media PC 19 13th July 2009 04:24 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
