HiFiVision.com - Audio Video Hi-Fi Forum
AVR Shutting down - Denon
Discuss AVR Shutting down - Denon at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi, I have Denon AVR 1508 and for the past few weeks, I face a ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 19th September 2010, 03:51 PM
Reputation points: 10
mechmohra is on a distinguished road
I have Denon AVR 1508 and for the past few weeks, I face a strange problem. My AVR is shutting down automatically and if i turn on immediately it gets on, it displays AV Surround > Receiver > IN DVD/HDP and at this time it gets switched off. but if remove the power cord and leave it off for around 40min - 1hr..and then again i switch on, it plays for around 15-20mins and again it is shutting down. If i leave the receiver without playing anything for whole evening and night and then play the receiver next day morning, it plays without any problem around 45min - 1hr and afterwards it starts getting shutting down.
What could be the problem?
Sponsored Ads
  #2
Old 19th September 2010, 05:00 PM
Reputation points: 80
Imrahn will become famous soon enough
Re: AVR Shutting down - Denon
Most probably the AVR is overheating.....did u feel anything of the sort?
The Following User Says Thank You to Imrahn For This Useful Post:
  #3
Old 19th September 2010, 05:53 PM
spirovious's Avatar
Reputation points: 1951
spirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant future
I feel the same.
The Following User Says Thank You to spirovious For This Useful Post:
  #4
Old 19th September 2010, 06:31 PM
Ya..if the receiver plays for more then 45min..if feel some heat, if i touch the top panel...I wouldn't say that it is too hot...but i can feel the heat.
  #5
Old 19th September 2010, 10:25 PM
spirovious's Avatar
Which speaker are you using?If they dont match well with AVR,you may get problem.
  #6
Old 19th September 2010, 11:40 PM
Reputation points: 140
NetFreak will become famous soon enoughNetFreak will become famous soon enough
Quote:
What is the impedance of speakers? Is it less than 6 ohm?
The Following User Says Thank You to NetFreak For This Useful Post:
  #7
Old 20th September 2010, 12:20 AM
Reputation points: 24
maniac_2004 is on a distinguished road
might be going into "protection mode" to save speakers from damage? only way to track it is to connect sources one by one and then check which is the offending input.
Does it do this with nothing connected?
The Following User Says Thank You to maniac_2004 For This Useful Post:
  #8
Old 20th September 2010, 10:47 AM
Dushie's Avatar
Reputation points: 304
Dushie is a jewel in the roughDushie is a jewel in the roughDushie is a jewel in the roughDushie is a jewel in the rough
better to get the same checked up if its in warranty don't push the setup, yes it can be due to protection circuit coming on due to load or impedance issues, also can be due to heat or malfunction of some part which after certain period is faulting, also check the cabling just to ensure you don't have a cut or damage on the wiring.
The Following User Says Thank You to Dushie For This Useful Post:
  #9
Old 20th September 2010, 08:20 PM
Thanks to all,
My speaker imp is 8ohm, I didnt buy this in india so I dont think Profx can help me with this and also its been nearly 3yrs since I buy this AVR.
  #10
Old 20th September 2010, 10:36 PM
spirovious's Avatar
Yes,but sensitivity,minimum power required?
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: AVR Shutting down - Denon
Thread Thread Starter Forum Replies Last Post
Denon 1910 or the Denon 1610 ?? gsenthil99 Surround Amplifiers/Receivers 22 28th March 2012 01:39 PM
Denon 1610 vs Denon 1910 sanchits Surround Amplifiers/Receivers 38 8th December 2010 05:34 PM
Prices for Denon 1910 amp in Singapore & Does Jamo go well with Denon? prasadkatre1 Home Theater 16 13th April 2010 08:54 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
