Home theater - 50 K
Discuss Home theater - 50 K at the Surround Amplifiers/Receivers within the HiFiVision.com - India's Audio Video Hi-Fi Forum; I bought a DLP Projector and want to set up a Home theater.. Would like ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Notices
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 26-06-08, 08:24 PM
jerryns is on a distinguished road
Home theater - 50 K
I bought a DLP Projector and want to set up a Home theater.. Would like to buy AV receiver and Speaker set within 30 to 50 K... Plz help
AV receiver can be 5.1 or 7.1 ... Should have HDMI atleast for audio.. My room size is 13 * 12 feet .. FM receiver is a must... Mainly i will use for watching movies and sometimes music
Jerry
Sponsored Links
  #2
Old 26-06-08, 10:29 PM
vinay's Avatar
vinay is on a distinguished road
The Wrong Lane
Jerry
Jerry,
Your room size is too small to have a projector. Please tell me the screen size which you are using.
I think your budget is quite less for av receiver and for 5.1 speakers. Your room size will not be eligible for 7.1 speakers.
Vinay.
  #3
Old 26-06-08, 11:50 PM
unleash_me's Avatar
unleash_me is on a distinguished road
Re: Home theater - 50 K
Jerry
Jerry, looks like you are new here. Welcome!
A component based system would be a compromise in that budget, if that is what you are after. If you are comfortable, try the 2nd hand route. Or else, HTIB or Sub/Sat is the way to go - you can find some decent ones in the Onkyo range. Might suit your room size better imo. Most of them do come with FM/AM tuners.
Regarding the screen-size vs. viewing distance, you can use this chart-
1080p Does Matter - Here's When (Screen Size vs. Viewing Distance vs. Resolution) � CarltonBale.com
and this spreadsheet-
http://www.carltonbale.com/ht/calcul...lator_v3.7.xls
All the best.
  #4
Old 27-06-08, 01:58 AM
vinay's Avatar
Tragedy At It's Best.
I bought a DLP Projector and want to set up a Home theater. My room size is 13 * 12 feet
Jerry
Jerry,
The spread sheet was very informative, which the member has given to you.
I think whatever the size of your screen, the easiest way out for you to salvage the situation is now, to reduce the picture size to around 35/40 inches, this way you will loose the charm of a much bigger picture size of say 80 - 100 inches, so the whole charm of having a projector has been defeated.
I think that you have still not bought the screen, if this is so, than maybe i can suggest you some other way out, which may give you some relief rally. The idle way would be if you can return the projector to the dealer, but he will not take it, till you use a gun at his fore head.
When my mini theatre was in the making i also had realized that my room length is small, so i had to remove my bathroom, to make the room longer, so now my theatre room length is 23 feet, while it was earlir at 17 feet.
When my mini theatre was in the making, I had got my wall white painted to a screen size 90 inches breadth with a height of 7 feet, than for several days I saw full movies, with different sizes on the white wall, I used markers and measurement tapes to set different sizes, finally I choose two sizes, 72" x 3.5 feet (16 x 9 - Dnp brand), and 82" x 5 feet (4 x 3 Dalite brand).
To conclude i also have gone through a lot of tragedy during the making of my theatre.
Vinay.
  #5
Old 04-07-08, 02:17 PM
Thanks .. But i need to set up a 5.1 system... How about Sonodyne Gene 1 HTS ...
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Home theater - 50 K
Thread Thread Starter Forum Replies Last Post
Home Theater marsilin Home Theater In A Box 7 07-06-08 05:12 PM
Home Theater NOSHANSU Introductions 1 19-11-07 09:11 AM
Looking For Home Theater SUNIL ARORA Introductions 2 11-11-07 08:25 PM
Best Home theater under 25K INR aeroman Home Theater In A Box 21 27-08-07 12:24 PM
Home Theater reiki Surround Amplifiers/Receivers 1 01-03-07 07:17 AM
Advertise Here
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
