| Discuss Receiver with 2 HDMI outputs. at the Surround Amplifiers/Receivers within the HiFiVision.com - India's Audio Video Hi-Fi Forum; I plan to install a 42 inch HDTV flat screen & an HDMI projector. I ... |
| Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers |
Thread Tools |
#1
I plan to install a 42 inch HDTV flat screen & an HDMI projector. I want a receiver which has two HDMI output sockets so that I can connect the receiver to both. Can someone someone suggest a good 7.1 receiver for this setup? Thanks H Patel |
| Sponsored Links |
#2
Re: Receiver with 2 HDMI outputs.
Onkyo NR905
Marantz SR7002 and SR8002 Denon 4308 |
#3
Only the more higher end receivers come with two HDMI outs.
You could go the cheaper route and use an HDMI repeater/splitter. Although some people have claimed to have HDCP issues but you could try it atleast if you wanna save money. Last edited by audiodelic; 2nd July 2008 at 08:25 AM. |
#4
Does anyone know the price for a hdmi repeater and a hdmi booster,
heard for the repeater you need to connect power, for booster no power is required and it runs on power from the cable itself, so booster will server the purpose better, anyone using or having similar products , will be great if you can share the price and performance of the same and recommend which company product to buy ? |
#5
wanna check this out? OPPO HM-31, Advanced 3x1 HDMI Switch, 1080P and HDMI 1.3 Certified
| Bookmarks |
| Thread Tools | |
Similar Threads for: Receiver with 2 HDMI outputs.
| Thread | Thread Starter | Forum | Replies | Last Post |
| How do I connect Onkyo 506 Receiver to the HDMI Up-scaling Player | rreddy18 | DVD players & DVD/hard-disk recorders | 12 | 31st October 2008 02:19 PM |
| Coaxial Digital Audio Outputs | ajithlal | DVD players & DVD/hard-disk recorders | 9 | 21st September 2008 10:10 PM |
| How to Connect TV and DVD (HDMI) with HT non HDMI | gaurav013 | Home Theater In A Box | 4 | 22nd August 2008 12:32 AM |
| HDMI TV or HDMI Monitor (24 inch) ???? | zatang | Television | 4 | 29th July 2008 06:52 PM |
| How to Connect TV and DVD (HDMI) with HT non HDMI | gaurav013 | Television | 3 | 12th June 2008 05:23 PM |
