HiFiVision.com - Audio Video Hi-Fi Forum
Denon AVC 3530
Discuss Denon AVC 3530 at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; Friends can anyone give me info on Denon AVC 3530 . I have seen one ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 20th December 2010, 11:48 AM
niloy666's Avatar
Reputation points: 12
niloy666 is on a distinguished road
Denon AVC 3530
Friends can anyone give me info on Denon AVC 3530 . I have seen one in very good condition... what should be the price to be paid for it ?
Sponsored Ads
  #2
Old 22nd December 2010, 12:01 PM
niloy666's Avatar
Re: Denon AVC 3530
Quote:
no updates on this gurus ??????
  #3
Old 22nd December 2010, 12:32 PM
Reputation points: 207
vivek.saikia has a spectacular aura aboutvivek.saikia has a spectacular aura aboutvivek.saikia has a spectacular aura about
Re: Denon AVC 3530
I was offered the Denon 3800 AVR for 10k along with a pair of local made speakers. The AVR was fine but could not check the true potential of it as it was sounding trash with the paired speakers.
  #4
Old 5th January 2011, 05:53 PM
Reputation points: 255
Vinod.R is a jewel in the roughVinod.R is a jewel in the roughVinod.R is a jewel in the rough
Re: Denon AVC 3530
Hi Vivek,
If the condition of the AVR is good, meaning no major repairs etc, it is a killer AVR. I think you will get only five channels of amplification but build quality is superb like a battle tank the caveat being the condition of the AVR. Remote is a bit old styled but it is a good AVR. Assume that the speakers are free and you are buying the AVR for Rs 10,000. I personally have AVR 3803 and I have no regrets even for one moment also bought pre owned from a friend of mine for Rs 50,000. Check the screws for openings etc. Best of luck.
I hope this helps.
Vinod
  #5
Old 6th January 2011, 10:34 AM
kapvin's Avatar
Reputation points: 332
kapvin is a jewel in the roughkapvin is a jewel in the roughkapvin is a jewel in the roughkapvin is a jewel in the rough
Re: Denon AVC 3530
I cannot comment on the power amp quality per se, but it should be good. (you should let your ears judge anyway) However, I would recommend you look elsewhere if you are buying this for hometheatre use.. reasons- it only has pro-logic (not even dolby digital) and it does not have 5.1 inputs (AFAIK) so you cannot use it with an external processor.
of course if you want to use it for 2 channel, and it sounds good to your ears and it's available real cheap.. that would make it a "buy"
edit:: real cheap means sub 5k under all circumstances and more like 2 or 3k. for reference someone on the forum just sold a 5 year old NAd reciever for about 12k.. and it had all decode for non hd audio formats, equal power to all channels and external multichannel inputs for HD audio/SACD
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Denon AVC 3530
Thread Thread Starter Forum Replies Last Post
Denon 1311 or Denon 1611 jjn Surround Amplifiers/Receivers 13 23rd September 2012 08:22 PM
Denon 1910 or the Denon 1610 ?? gsenthil99 Surround Amplifiers/Receivers 22 28th March 2012 01:39 PM
Denon 1610 vs Denon 1910 sanchits Surround Amplifiers/Receivers 38 8th December 2010 05:34 PM
Prices for Denon 1910 amp in Singapore & Does Jamo go well with Denon? prasadkatre1 Home Theater 16 13th April 2010 08:54 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
