| Discuss Usage of Equalizers at the Surround Amplifiers/Receivers within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Dear friends, I thought of this question for a long time in my mind. What ... |
| Notices |
| Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers |
Thread Tools |
#1
Usage of Equalizers
Dear friends,
I thought of this question for a long time in my mind. What is the role of equalizers in audio listening/recording. Is it mandatory to use equalizers for good audio quality because musical shops are using equalizer for recording. During my college days I used to make cassette collections by recording songs from musical shops. There I found equalizers for every recording unit (Connected as Turntable > Equalizer > Recording deck > amplifiers > speakers). As the tracks in vinyl records are recorded high quality, does it make any sense in using the equalizers. For equalizer recording, they charge additionally. After my college days, me and our friends started a recording shop and we also followed the same method. Is there any value addition using equalizers for listening or recording. Looking forward to your views regarding this issue. Regards, Muthusami. S |
| Sponsored Links |
#2
Re: Usage of Equalizers
Quote:
I guess it may have helped in flat recordings where the user could boost the lacking frequency. The BIAS TUNE on some decks could achieve similar as that too is like a tilt towards either frequency. In a decent system i would avoid artificially boosting certain frequencies and hence would avoid using an equalizer for playback. In my opinion it would not have any value addition. I regularly visited a CD/LP library in mumbai called Melody ages ago and they would record for a small charge. When they recorded on tape they turned the bias knob to enhance the trebles as they claimed the customers demanded a treble boost while i preferred to record flat or as is. Maybe there could be some value addition in recording esp if doing it commercially but not so for playback IMO. Regards |
#3
Hi Muthusami, Dinyaar is right. Boosting frequencies lead to distortion. I too was using Technics eq for few years, sounds too artificial.
#4
Dinyaar,
Thank you very much for the clarification. I was about to purchase an equalizer and now I found it is unnecessary. Thanks a lot. Regards, Muthusami. S Quote:
#5
Anil,
Thank you very much for the reply. Regards, Muthusami. S |
#6
Mr M Swamy,
U are most welcome. Regards |
#7
Dear All
Since all audiophiles suggest not to add an equalizer to your component chain, may I suggest the T-Qualizer which is an equalizer which you can wear while listening to the music. I sell these t-shirts at my website and also make wall posters of the same to be used in the Stereo/HomeTheatre rooms. Please check my website at Ray Store and let me know what you think. Regards Rahul Pandit Ray Store |
#8
Hi Rahul,
The products are innovative; will purchase through online if needed. Thanks, Muthusami. S Quote:
#9
Dinyaar and Anil Kumar has given you some good answers.
Unfortunately my fingers itch too much to keep away from the keyboard. Sorry Dinyaar and Anil. I just have to add my two bit to this. No offense meant. At the outset, there is a bit of contusion on the terminology. The term âequalizerâ is often erroneously used, Audio components and mixing equipment include the so-called graphic equalizers, or simply, equalizers. These are actually general all-purpose filters. Divided into a number of frequencies, these filters produce the effect of high-pass, low-pass, bandpass and band-stop filters. These filters function as equalizers only when their mode of arrangement is such that they reverse the effects of the internal circuitry on the output. The control of frequency loss or gain is only a small part of an equalizers. The main function is to counter balance the unequal frequency response of an external signal processing system. Using an equalizer, you can adjust one or more parameters that are determinants to the overall shape of the filter's functioning. Equalization filters are generally used to enhance sound fidelity, eliminate undesired components in the signal, emphasize certain instruments, and develop completely new sounds. Equalizer filters are of multiple type - namely peaking filters, shelving filters, low-pass and high-pass, and band-pass filters. Peaking filters work on frequencies, 'Q. and Boost/Cut. The peaking filter uses a bell curve and functions smoothly over a wide frequency range. The center frequency, occurring at the crest of the bell, is the one affected by the equalization. Frequency, as you know, is measured in Hertz. 'Q' is a quality factor that refers to the width of the bell curve. Q is inversely proportional to the bandwidth - a higher Q denotes that only a few frequencies are affected and vice versa. Q is generally measured in Octaves. Boost/Cut, also called, gain, determines the amount of selected frequencies that should be present. A boost enhances the presence of the frequencies, while a cut softens the frequencies. A gain of +10dB indicates doubling of the amplitude of the original sound. Shelving Filters are used to cut or boost a determined frequency till a preset level is reached. The same level is then applied to the rest of the frequency spectrum. Shelving filters are common on the treble and bass controls of home audio systems, and are also employed in audio mastering. High-pass and Low-pass filters are used to boost or cut frequencies above or below a set frequency termed as the cutoff frequency. High pass filters allow the frequencies above the cutoff frequency to pass through unaffected. Frequencies that fall below the cutoff are attenuated at a constant rate per octave. Low-pass filters, on the contrary, allow frequencies below the cutoff to pass through unaffected. High-pass and low-pass filters are used to eliminate pops, reduce noise, and remove rumble. A bandpass filter is simply a combination of one low-pass filter and one high-pass filter. Band-pass filters allow frequencies that fall within a certain range and reject all others. An RLC circuit such as those used in AM/FM radio to tune to a particular radio frequency, uses bandpass filter extensively. Parametric Equalizers A parametric equalizer is used in live sound reproduction, in public address systems and, in sound recording. Parametric equalizers enable audio engineers to control the parameters such as the center frequency, amplitude and bandwidth of the internal bandpass filters. A parametric equalizer allows the amplitude of each band to be controlled, and the center frequency to be widened, narrowed or shifted. A parametric equaliser 1. removes excessive unwanted resonance, which can cause a âboomyâ sound found in musical instruments such as double basses and acoustic guitars. 2. eliminates undesirable elements such as foreign noises. 3. eliminates feedback that causes an excessive resonance (or what we hear as shriek). This usually happens in live performances when amplified sound is captured by a microphone. 4. can be used for tonal enhancements. For, example a tampura player usually sits behind the main artists and does not have a separate microphone. At the same time, the sound of the tampura is important for the rhythm of the music. The equaliser can boost the sound of the tampura before it is cut into a CD or tape. Graphic equalisers use slide potentiometers to gain control. In addition they may have a display that shows the frequency curve in real time. Applications of Equalizers One of the most important use of equalizers is in live performances where speakers and microphone operate together. Here the equalizer is used to eliminate feedback causing frequency bands. Equalizers are frequently used in public address systems and in places such as churches, temples, stadiums, sports arenas. etc. Here equalizers are used to sharpen the sound. Temporary structures will need equalizers as it is impossible to build a good system in such places. Studios invariably use equalizers to coordinate the various microphones and sound inputs into the system, and to reduce and eliminate external noises such as a hum. . As Dinyaar and Anil have said, at present times, the equalizers as we know them do not have much use in a home environment. Speakers have full bandwidth capabilities and excellent crossover inside eliminating the need to boost or cut a frequency. Similarly, amplifiers have reached level of sophistication where their internal circuitry takes care of smoothening across frequencies, if required. Modern AVR have a set-up system (such as from Audessey) that give a feedback to the system about the room, so that the amplifier can handle the room acoustics. There may yet be a small set of people who demand amplified low frequencies. For such people using a filter to boost low frequencies when you record for them may make sense. But for those who value high fidelity, we always listen to music without any artificial attenuation. Whenever I audition equipment, I ensure that the demo equipment are all set to flat so that I can hear the natural capabilities of the source, the amplifier, the connectors/cables, and the speakers. In your business Muthusami, whether to have a equalizer or not depends upon the kind of customers you deal with. If there is a high percentage of people who are happy with artificial frequency boosting, then I suppose that is what you have to give them. Cheers. |
#10
Nice explanation. Thank you very much. By the way, I am not in the recording business now; only for my personal use, I planned to buy an equalizer. In my business I had Akai 10+10 band graphic equalizer. Without any technical knowledge, we managed to bring quality recording by adjusting the bands.
Thanks again. Regards, Muthusami. S Quote:
| Sponsored Links |
| Bookmarks |
| Tags |
| equalizers |
| Thread Tools | |
Similar Threads for: Usage of Equalizers
| Thread | Thread Starter | Forum | Replies | Last Post |
| Availability of Graphic equalizers in Mumbai | raja iyer | AV Enhancers & Room Acoustics | 20 | 5th December 2008 12:28 PM |
