How do i connect a microfone in my marantz sr 4002
Discuss How do i connect a microfone in my marantz sr 4002 at the Surround Amplifiers/Receivers within the HiFiVision.com - India's Audio Video Hi-Fi Forum; I would like to connect a microfone in my marantz SR-4002 AMP for karoke purposes ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Notices
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 28th July 2008, 05:54 PM
Bunn999 is on a distinguished road
Arrow How do i connect a microfone in my marantz sr 4002
I would like to connect a microfone in my marantz SR-4002 AMP for karoke purposes anyone has an idea how to do so?
Sponsored Links
  #2
Old 29th July 2008, 01:37 AM
venkatcr is just really nicevenkatcr is just really nicevenkatcr is just really nicevenkatcr is just really nice
Re: How do i connect a microfone in my marantz sr 4002
I am not very sure my answer is correct. But here goes.
Look at Page 6 of your manual. There is a set of inputs that are labelled AUX and closed with a cover. If you open this, you will find various inputs jacks such as optical, SVideo, L&R. etc. One of these have to be used for your mike. You may also to go to setup and set the input point you to use and set it for the resistance and other factors needed for the mike.
I am not even sure your AVR can be used as a Karaoke. Though it says somewhere you can mix two inputs, these are audio and video from two different sources.
As I said, I am not sure my answer is correct. Check with a Marantz dealer or send an email to their support center.
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: How do i connect a microfone in my marantz sr 4002
Thread Thread Starter Forum Replies Last Post
How to connect MP3 to A/V Reciever ? Aryan Home Theater In A Box 16 19th November 2008 11:44 AM
How to Connect TV and DVD (HDMI) with HT non HDMI gaurav013 Home Theater In A Box 4 22nd August 2008 12:32 AM
Can i connect a Notebook via S/PDIF? tinny9 Home Theater In A Box 11 27th June 2008 01:32 PM
How to Connect TV and DVD (HDMI) with HT non HDMI gaurav013 Television 3 12th June 2008 05:23 PM
C.A. vs NAD vs Marantz vilfy Amplifiers 11 6th November 2007 09:26 PM
Advertise Here
Copyright © 2006-2009, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
