HiFiVision.com - Audio Video Hi-Fi Forum
Onkyo TX-SR608 Remote Control issue
Discuss Onkyo TX-SR608 Remote Control issue at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi All, My Onkyo TX-SR608's (bought from US) remote controller is not working from day ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 23rd March 2011, 09:00 PM
Reputation points: 17
alexanish is on a distinguished road
Hi All,
My Onkyo TX-SR608's (bought from US) remote controller is not working from day one I got it in India. Probably the baggage handling done the job. I have given it to Onkyo service here in Bangalore and also contacted the Chennai Onkyo. Both did not take up servicing. They touch only those with warranty. I have also contacted the US onkyo and they haven't replied for about a week now. So I guess I will have to buy one now. A new one costs about 23$. Should I buy the Onkyo remote or a universal programmable remote which can replace all my other remotes as well along with the dead Onkyo one?
Thanks!
Anish
Sponsored Ads
  #2
Old 23rd March 2011, 10:12 PM
Reputation points: 255
Vinod.R is a jewel in the roughVinod.R is a jewel in the roughVinod.R is a jewel in the rough
Re: Onkyo TX-SR608 Remote Control issue
just a basic suggestion. See if you can take the remote apart, clean it and put it back. Most times just one or more buttons are depressed from the keypad inside and hence the remote may not be working because of baggage handling. Since anyway you have no choice for service or replacement why not try this. May work. I hope this suggestion helps!
PS: I used to sell Onkyo systems and have fixed quite a few remotes similarly! (Disclaimer!!! from any lawsuits!) And very careful while taking it apart, some of them have screws and some of them have small latches on the sides, so take your time to do it.
  #3
Old 23rd March 2011, 10:59 PM
Thanks Vinod!
I in deed tried that the moment I got it back at home :-) opened and put it back.
But not worked out. By the way, the manual mentions that when you press the button in the remote and especially with certain combinations like [Reciever] + [Setup] the LED on top of the remote blinks. Nothing like that happened what so ever combinations I tried. So my best guess is this guy is not going to come back alive. Not either sure if any technician can rectify the issues with these small boards.
  #4
Old 23rd March 2011, 11:10 PM
Hi Alexanish,
A few things to try (I am sure you have tried it but still thought better to tell you than not to):
1) Check with some other batteries
2) When you open the remote and take out the PCB, clean it with some spirit using a old toothbrush, taking care not to leave any scratch marks on the PCB, let it dry completely and put it back again
3) Take the remote to SP Road, I am sure someone can fix it or sell you the same duplicate remote, don't leave the remote there!
4) Of course order it from websites or contact Onkyo or Lokesh at Techlok, I am sure he may have a workable solution as he has contacts in Onkyo and was their Manager for the Indian region
5) If someone from this forum or relative is visiting the US, you can ask them it bring it to you
6) These remotes usually have only 1 or 2 ICS and carbon problems as a techie told me, so it should be easily fixable in the right hands
  #5
Old 23rd March 2011, 11:20 PM
Thanks again Vinod!
I have tried the 1st one with out success.
I will try the 2nd one soon.
Third one is another possibility though thinking about reaching/parking/congestion in SP road ah... but I will give a try.
What is Lokesh's contact number? or location?
The last is most easy one I believe among these - get a new one :-)
But again at this point I have another option to go for a similar priced universal one an program it to do all my gadget controlling.
But I will still give a chance to the rest of the ideas you had put forward.
  #6
Old 23rd March 2011, 11:52 PM
Hi man,
Lokesh 9845545429
Shop is in JP Nagar
  #7
Old 24th March 2011, 12:38 AM
Thanks Vinod!
Let me ask him tomorrow.
  #8
Old 24th March 2011, 06:57 AM
You are welcome
  #9
Old 24th March 2011, 09:32 AM
baijuxavior's Avatar
Reputation points: 1567
baijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant future
To test whether the IR LED works, point the remote to your mobile phone camera and press any key. If you can see white light in the camera then the LED is working fine. (You could create a night vision camera using this technique. Just connect a bunch of IR LEDS to a power supply and place it in a dark room. Now turn your camera on and see how the night vision works!)
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Onkyo TX-SR608 Remote Control issue
Thread Thread Starter Forum Replies Last Post
DIY Remote control for HTPC stereorules DIY 8 22nd February 2011 09:34 AM
Remote control of AV recievers ? All-in-One ? akshaysalkar What Should I Buy? 1 20th October 2010 12:57 AM
Airtel remote code to control ONKYO AMP edjamesx Digital Cable and DTH 0 5th October 2010 09:51 PM
DIY troubleshooting of remote control kaushik DIY 7 10th June 2009 08:40 AM
Looking for a Remote Control hifipal4all Blu-ray/DVD players & DVD/hard-disk recorders 0 17th September 2007 12:38 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
