A/V Receivers
Discuss A/V Receivers at the Surround Amplifiers/Receivers within the HiFiVision.com - India's Audio Video Hi-Fi Forum; which one.... which one 1) Denon AVR-1507 525W 7.1 Channel A/V Receiver With Auto Setup ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 1st September 2008, 05:55 PM
girl21 is on a distinguished road
A/V Receivers
2) Denon AVR-1508 525W 7.1 Channel A/V Home Theatre Receiver
3) Denon AVR-1707 525W 7.1 Channel A/V Home Theatre Receiver
4) Onkyo TX-SR304 500W 5.1-Channel A/V Surround Receiver
5) Onkyo TX-SR504 910W 7.1 Channel A/V Surround Receiver
6) Onkyo TX-SR505 1120W 7.1 Channel Home Theatre A/V Receiver
Sponsored Links
  #2
Old 1st September 2008, 06:10 PM
smsrini is on a distinguished road
Re: A/V Receivers
Denon is good for Music, Onkyo for Movies.
What is your preference ? music/movies you listen to ?
what is the mix of music/movies you listen to ?
What speakers do you have ?
Ans. these questions and then narrow down your choices.
  #3
Old 1st September 2008, 07:31 PM
unleash_me's Avatar
unleash_me has a spectacular aura aboutunleash_me has a spectacular aura aboutunleash_me has a spectacular aura about
Re: A/V Receivers
Be patient. Save up a bit more and go for the 1909.
Bliss.
  #4
Old 2nd September 2008, 12:39 AM
Dushie's Avatar
Dushie will become famous soon enough
Thumbs up Re: A/V Receivers
Is 1909 available locally, but it would be very expensive as its recently launched, better to hold on for prices to come down and then go for the same
  #5
Old 9th September 2008, 03:22 PM
Re: A/V Receivers
planned for ->>>>>> Onkyo HT-S5100
suggestion plssssssss
  #6
Old 10th September 2008, 11:45 AM
Re: A/V Receivers
Answer these questions below:
what is the mix of music/movies you listen to ? 60% movies ? 40% music ?
Have you played your choice of music on this package ?
Do you have the space/walls to mount the left/right surrounds ? or are you going in for stand mounts ? Stands are not part of the pkg.
The receiver specs show 130w min power while the speakers show 130w maximum. power rating at 8ohms. Have you played any music / movies loud on this combination of receiver/speakers ? You should be able to turn up the volume upto 25% of the range without any distortion in sound ?
rgds
  #7
Old 10th September 2008, 01:00 PM
Re: A/V Receivers
Pls see my replies in bold and colour
Quote:
Originally Posted by smsrini View Post
answer these questions below:
What is your preference ? Music/movies you listen to ? - both
what is the mix of music/movies you listen to ? 60% movies ? 40% music ? - 50:50
have you played your choice of music on this package ?: no not yet
do you have the space/walls to mount the left/right surrounds ? Or are you going in for stand mounts ? Stands are not part of the pkg. : yes will wall mount
the receiver specs show 130w min power while the speakers show 130w maximum. Power rating at 8ohms. Have you played any music / movies loud on this combination of receiver/speakers ? You should be able to turn up the volume upto 25% of the range without any distortion in sound ?
Rgds
  #8
Old 10th September 2008, 01:16 PM
mandeep's Avatar
mandeep will become famous soon enough
Re: A/V Receivers
Quote:
Denon is still not available officially as per Profx website at
Profx - Advanced Audio Solutions
  #9
Old 10th September 2008, 03:35 PM
Re: A/V Receivers
Quote:
Ok. Take your top5 Audio and Video CDs/ DVDs and play them on the exact system you intend to buy.
As I mentioned earlier, try out different sound modes available in the receiver.
Raise the volume to as high as you can comfortably listen to, and see if there is distortion in sound, given the receiver seems to be of a higher spec than the speakers.
Make sure the audition room has a 7 speaker setup or a 5.1 setup at a minimum.
The Onkyo HTIB should be good. Specs look good. If you are the type who dont want to get into the details but want good sound, it should do the work for you. If you are a audiophile who can discern between the finer nuances of sound, you would probably opt for a separate Speaker package.
  #10
Old 10th September 2008, 03:51 PM
Re: A/V Receivers
week before I have checked out the Harman kardon-JBL speakers and onkyo basic model and felt that onkyo was better than HK-JBL......so prefer onkyo...
can u suggest any combi or different brand
-how is pro-fx, sensai, jbl speakers???????
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: A/V Receivers
Thread Thread Starter Forum Replies Last Post
Do AV Receivers really Bi-amp or just Bi-wire? MTP Surround Amplifiers/Receivers 28 12th September 2009 04:40 AM
New Onkyo AV receivers gap g j Surround Amplifiers/Receivers 8 4th August 2009 05:36 PM
Worldspace receivers - which is the best buy? sunilkm AM/FM Tuners & Satellite Radio 15 14th December 2008 11:21 PM
marantz a/v receivers maniac_2004 Surround Amplifiers/Receivers 61 7th December 2008 04:16 PM
AV Receivers anthjose Surround Amplifiers/Receivers 6 29th July 2008 10:31 PM
Advertise Here
Copyright © 2006-2010, HiFiVision.com All Rights Reserved.
Recommended Websites - www.CameraVision.in
