HiFiVision.com - Audio Video Hi-Fi Forum
Buttons on front panel of Denon 1610 not working
Discuss Buttons on front panel of Denon 1610 not working at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; I have a denon 1610 that 1 bought about a year ago. As expected, i ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 2nd June 2011, 09:47 AM
Reputation points: 51
avink will become famous soon enough
Unhappy Buttons on front panel of Denon 1610 not working
I have a denon 1610 that 1 bought about a year ago. As expected, i mostly use remote for all the functions and hardly use the buttons on the AVR. I noticed couple of weeks ago that none of the buttons on the front panel of the AVR are working. Some dont respond at all and some will perform diff function. e.g pressing quick select or even menu button gives options of surround etc. even the standby button doesn't seem to work. I have tried to reset the AVR and that didnt help either. All the functions/features work perfectly fine via remote. Could it be dust/carbon deposit. Is there anything i could do/clean myself (its just out of warranty by about 2 months). I have been reading about how Denons work fine for so many years but mine is just a year old
Thoughts / Suggestions ?
_Thanks
Sponsored Ads
  #2
Old 2nd June 2011, 10:40 AM
Reputation points: 60
acoustics will become famous soon enough
Re: Buttons on front panel of Denon 1610 not working
yes this can be corrected if you can open up the front face of the amp.This problem is generally due to dust and carbon deposits as you have already suspected.First remove power cord and then the top cover,now look for all the screws that hold up the front face of the avr to the main chasis.There could be screws on all four sides of the face and please be sure that you have unscrewed them all. Now once the front face is off there could be a few plastic buttons covering the original micro switches which you have to clean . These plastic buttons can again have screws , remove them all and be sure to note what screws belong to which part. Now u need some synthetic paint thinner which can be bought from any hardware shop , dip a cotton bud into this thinner and apply on all the malfunctioning switches , the quantity of the thinner used on each switch should be around 4 to 5 drops , keep pressing each button as you are cleaning it .After you are done with cleaning wait for 5 to 10 mins so that the thinner evaporates by itself .Now put everything back i mean the front face and all the screws etc . Wait again for half an hour or so and then switch back your avr.
there you go all the switches should have been brought back to life :-)
now smile and consider your self a hero , you did a great job
.... you have saved your amp from getting into bigger trouble because all these little switches could have given birth to major problems with time even a bricked amp and also you have saved yourself some of the biggest red shiny currency notes(you must have guessed by now which ones i am talking about)
and one thing more go for this self service process only if you have an out of warranty avr
finally if any of the buttons are still not working then that has not been properly cleaned up or it needs to be replaced and you should seek professional help
let me know how things went
The Following User Says Thank You to acoustics For This Useful Post:
  #3
Old 2nd June 2011, 12:46 PM
thanks ..will give it a try.
  #4
Old 2nd June 2011, 07:28 PM
Quote:
seems like its not as easy as it sounds ..I unscrewed all the screws but the panel doesn't come off. has anyone tried opening a denon ?
  #5
Old 18th August 2011, 06:21 PM
To close this loop..I finally got my AVR serviced via Denon(ProFX) authorized service center in Nehru Place. The switching IC for the front panel was replaced. Costed Rs. 3700/.
  #6
Old 19th August 2011, 12:19 AM
Good to hear that your avr is back to normal,were you told or did you ask the part number of the replaced part and also was the replaced part handed over to you? If you have the part number can you post it,because its very hard to believe that they charged u so much for a common problem that just requires cleaning of the micro switches.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Buttons on front panel of Denon 1610 not working
Thread Thread Starter Forum Replies Last Post
How to easily make Professional looking front panel kaushik AV Lounge 5 3rd February 2013 07:53 PM
front panel design kaushik Amplifiers 5 26th December 2012 08:44 PM
Denon 1910 or the Denon 1610 ?? gsenthil99 Surround Amplifiers/Receivers 22 28th March 2012 01:39 PM
Denon Avr 1910 +Jamo A102 (Excluding Front Spekars)+Warfdale 9.2 front Speakers deven_shah Speakers 2 30th June 2010 02:11 PM
Denon 1908 front panel locked. How to unlock? Sumain Surround Amplifiers/Receivers 0 26th March 2010 04:48 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
