HiFiVision.com - Audio Video Hi-Fi Forum
Connect PC to AV Receiver
Discuss Connect PC to AV Receiver at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; How a Computer(PC) can be connected to AV Receiver. I want to get the 1080p ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 16th June 2011, 08:50 PM
Reputation points: 80
kaptan will become famous soon enough
How a Computer(PC) can be connected to AV Receiver. I want to get the 1080p video and dts audio from it. Is ther any way
Sponsored Ads
  #2
Old 16th June 2011, 09:00 PM
baijuxavior's Avatar
Reputation points: 1567
baijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant future
Re: Connect PC to AV Receiver
If your pc has hdmi output then connect it to the avr. If you don't have one then buy a graphics card with hdmi.
  #3
Old 16th June 2011, 10:00 PM
spirovious's Avatar
Reputation points: 1950
spirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant future
Your PC config?
  #4
Old 17th June 2011, 07:31 AM
Processor : AMD Athlon II X2 245 Processor 2.91GHZ
RAM: 1GB
OS : Windows 7 Ultimate
Board : ASUS
  #5
Old 17th June 2011, 08:51 AM
Update your memory to at least 2GB. 4GB recommended. You will need to add a graphics card with hdmi if you want to connect both audio and video to your avr. If you just want to connect audio only then a sound card with optical or co-axial output will do.
  #6
Old 17th June 2011, 03:00 PM
spirovious's Avatar
Your MB should have PCI-E 16X slot,so you can get ATI HD graphiccard with HDMI out.
  #7
Old 17th June 2011, 03:18 PM
Will wd HD media player be a good replacement for the PC
  #8
Old 17th June 2011, 05:06 PM
just4kix's Avatar
Reputation points: 1719
just4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant future
Quote:
In terms of convenience, definitely yes.
You just connect the media player to AVR, power it up and bingo - you are all ready to go.
The PC is a noisy appliance. There are at least two cooling fans - CPU and chasis. If there is a high-end gfx card, it may also have a fan. All these fans make noise which disturbs the ambience of watching the movie.
  #9
Old 17th June 2011, 05:30 PM
If have a file with dts and 1080p video shall i able to play that file using WD HD media player. I found that wd media player plays mkv file. I want to know whether it will give dts5.1 audio . In the wd media player specs its mentioned that dts2.0 out.
  #10
Old 17th June 2011, 06:38 PM
The dts 2.0 out refers to the stereo output which the player does by down mixing dts surround tracks. The player will pass through dts 5.1 output so that you will get surround effect using AVR. See the link WD TV Live
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Connect PC to AV Receiver
Thread Thread Starter Forum Replies Last Post
How to connect tata sky to AV receiver amitzhankar Digital Cable and DTH 2 14th April 2011 06:00 PM
Airtel HD DTH Receiver's Remote Code for Onkyo Receiver PrasannaK Digital Cable and DTH 2 9th August 2010 08:16 PM
In US and unable to decide: Integrated Amp. or Stereo Receiver or A/V Receiver pinkfloyd Surround Amplifiers/Receivers 15 29th April 2010 05:30 PM
How to connect PS3 to a AVR bazee Surround Amplifiers/Receivers 2 18th December 2008 06:11 PM
How do I connect Onkyo 506 Receiver to the HDMI Up-scaling Player rreddy18 Blu-ray/DVD players & DVD/hard-disk recorders 12 31st October 2008 01:19 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
