HiFiVision.com - Audio Video Hi-Fi Forum
Need help - 8-16 ohms amplifier output with 6 ohms speakers
Discuss Need help - 8-16 ohms amplifier output with 6 ohms speakers at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi , Need help with this problem.. I have got Sony Home Theatre Receiver - ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 24th July 2011, 12:31 PM
Reputation points: 10
Pawanh75 is on a distinguished road
Hi ,
I have got Sony Home Theatre Receiver - STR DE997 (Canadian model running on 110 volts) with the audio output of 8-16 ohms. Along with it am using Benz - 6 ohms speakers.
The problem am facing is that of overheating of amplifier in about 45-50 mins and the amplifire is geting turned off due to over heating on its own.
I tried fixing 2.2 ohms (half watt) resistors in series with the speaker cable, however sound quality degraded and the depth of sound was lost.
Need some help with any other solution for this issue. Using 10 ohms and above resistor in parallel will solve the issue !!??? Not sure....
Please help with some reliable and permanent solution as most of the international web-sites treats this as no problem in normal running, however am facing the shut down due to overheat...
Thanks.. Regards Pawan
Sponsored Ads
  #2
Old 27th July 2011, 09:31 PM
Re: Need help - 8-16 ohms amplifier output with 6 ohms speakers
Hi Again.... so many views, however no replies/ suggestions received....pls help..
Pawan
  #3
Old 27th July 2011, 09:44 PM
baijuxavior's Avatar
Reputation points: 1552
baijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant future
How many speakers you have? Connect two speakers in series to get an effective resistance of 12 ohms.
  #4
spirovious's Avatar
Reputation points: 1916
spirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant future
Sony amps are not gr8 to run 6ohms when manual says 8-16ohms only.If it was Onkyo,no problem.
Here we are talking about impedance & not resistance & so adding extra resistance will not help.You know the result.
You need to change either speakers OR Amp as amp will be damaged mostly.
  #5
Old 27th July 2011, 09:47 PM
gobble's Avatar
Reputation points: 862
gobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to behold
Try connecting your speakers in series instead of parallel.
Read this first : Series Vs. Parallel Wiring
Then attempt it.
Then to revise : Speaker Impedance Explained - Ohms
HTH
--G0bble
  #6
Old 27th July 2011, 10:33 PM
jaudere's Avatar
Reputation points: 301
jaudere is a jewel in the roughjaudere is a jewel in the roughjaudere is a jewel in the roughjaudere is a jewel in the rough
Using speakers in series will solve the problem with impedance but you will need more speakers (in fact double the no.) if you need all channles of home theatre to be active. So rather than buying extra set speakers of 6 ohm impedance, it would be more logical to buy speakers of 8 ohm impedance, or even better change from sony to Yamaha /onkyo.
In fact , 6 ohm for an amp rated at 8 ohm should not be a problem if you do not crank up the volume. My yamaha AVR said to use speakers of 6 ohm or more. I have used 4 ohm speakers without any problem.
By the way, Didn't you get a set of compatible speakers with the Sony AVR?
  #7
Old 28th July 2011, 01:18 PM
visaster is on a distinguished road
Best way to get out of this trouble is to switch the amp or the speaker.
Connecting in series and stuff just increase the load on the amp and it is going to go someday.
Get an amp which can vary ohms and even give you a HDMI output option. (all the more reasons to change)
  #8
Old 28th July 2011, 01:25 PM
How will increasing resistance increase load on the amp? (Load is synonymous to current). Load decrease as resistance increase.
What is the use of HDMI output in amp? We can't connect speaker to the hdmi output.
  #9
Old 28th July 2011, 10:05 PM
Thanks for all the replies....
I have only 2 tower speakers (6 ohms each)... if I connect them in series, then I'll have 2 buy another 2 speakers which is not the option viable for me as of now and probably not even the option of changing the receiver...
Well I didn't receive any speaker with Sony AVR as it came from Canada..... for side sorround am using Technics Cubes and for Center Technics cube 2 way speakers (all three of them 8 ohms...suits well with the set up).
Also increasing the resistance didn't increase the load on the amp, but depth in the sound was lost.... playing it normally i.e 6ohms speakers with the amp with 8-16 ohms output made the amp heated and went on the auto shut off mode....
Thanks 'gobble' for both the links, however slightly technical info for me....
please suggest if any solution with the current set up available without compromising on the sound quality...... in long run probably chaning one of them will be the solution... however not right now....
Thanks..
Pawan
  #10
Old 31st July 2011, 05:17 PM
sydneyvj's Avatar
Reputation points: 11
sydneyvj is on a distinguished road
You can connect 6 ohms speaker to 8 ohms rated AVR provided your AVR has got a decent power output. The shutting down suggests that the AVR power supply cannot hold up or you are driving your speakers too hard. Also make sure that you have adequate ventilation.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Need help - 8-16 ohms amplifier output with 6 ohms speakers
Thread Thread Starter Forum Replies Last Post
Can We Pair 4 Ohms Speakers With 6 Ohms AVR? naren2512 Surround Amplifiers/Receivers 42 1st May 2011 02:01 AM
Speaker OHMS 4-16 isrsuresh Speakers 4 2nd November 2009 09:08 AM
Reducing 6 ohms to 4 ohms blaze45 DIY 14 17th August 2009 09:00 PM
8 Ohms Headphones...... Any ?? deba Audio Video Accessories 2 17th August 2009 05:49 PM
4 Ohms Load Stress on Amplifier Anil kumar AV Lounge 1 1st August 2008 08:03 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195
