HiFiVision.com - Audio Video Hi-Fi Forum
Yamaha DSP-A2070
Discuss Yamaha DSP-A2070 at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; Finally cracked into the 100 reputation points barrier. (Self proclaimed unashamed propaganda ) That too ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #51
Old 10th October 2011, 05:08 PM
rishiguru's Avatar
Reputation points: 276
rishiguru is a jewel in the roughrishiguru is a jewel in the roughrishiguru is a jewel in the rough
Re: Yamaha DSP-A2070
That too after posting only 196 posts in hifivision.
My Rep Ratio : 100/196 = 0.510
Has anyone have a better rep ratio than me? Just for interest.
This means my every other post received a rep point.
Man i do not know how a noob like me get so much rep points.
I want to thank every audiophile & learned members of hifivision for giving me this opportunity and to be a part of this wonderful group of people and let me grow.
Warm Regards
rishiguru
Sponsored Ads
  #52
Old 10th October 2011, 06:55 PM
jaudere's Avatar
Reputation points: 301
jaudere is a jewel in the roughjaudere is a jewel in the roughjaudere is a jewel in the roughjaudere is a jewel in the rough
Quote:
Originally Posted by rishiguru View Post
Ha ha .... rightly so.
Good for me, I am young & not married yet. Still got some time left to play hell loud and enjoy the sound of music.
Before marriage, no one introduced me to this hobby. Anyway I neither had money nor the wife or time. Now I have money &some time but wife also.
You are lucky to have money,time but not the wife.
The Following User Says Thank You to jaudere For This Useful Post:
  #53
Old 14th October 2011, 01:43 PM
Reputation points: 23
dovin is on a distinguished road
Hi Rishiguru,
I have a Yamaha DSP A1 that I got in 1998 in the US. I used it for 4-5 years, then moved to India. Its been sitting in a box all this time and just now I have taken it out and tested (After I got a good voltage converter!!) to see if its still working. It is!
I hope to get the HT setup done in another month's time and back to enjoying the Yamaha experience. It looks almost exactly like your 2070.
Nice to see someone here who has a Yamaha DSP series and enjoying it.
regards,
Dovin
  #54
Old 22nd October 2011, 10:31 AM
rishiguru's Avatar
Congratulatios jaudere for being fortunate enough of having a wife who understands your needs regarding music & Audiophilia!!!!
My elder sister can hardly differentiate the sound quality between Logitech Z-2300 & my mighty Yamaha DSP-A2070
She thinks Z-2300 is cute while DSP-A2070 & Sony bookshelves are black ugly boxes. According to her these systems should be very small so that they do not rob the decency of the room.
Man you are lucky.
Anyway I feel good to be back at hifivision after nearly two weeks of hard work for official reasons. I missed a lot.
  #55
Old 22nd October 2011, 01:23 PM
rishiguru's Avatar
Quote:
Originally Posted by dovin View Post
Hi Rishiguru,
regards,
Dovin
Thanks dovin for your appreciation. The DSP-A1 is undeniably one of the best amps of Yamaha. I think A1 was released after A3090. This DSP range just got fatter with time having more & more features cramped in.
Regarding me, well I am just a regular bloke who is trying to understand what true sound quality really means. And I know I have lot to learn.
  #56
Old 1st November 2011, 07:09 PM
rishiguru's Avatar
Quote:
Originally Posted by darshanjoshi View Post
On the back of AVR i see Coupler section. What are these ? Pre In / Pre Out?
These couplers are for using these amp as a pre or power amp. These couplers connect the inbuilt 7 channel pre amplifier with the inbuilt 7 channel power amplifiers.
So by talking out the couplers one can:
1) Use a discrete 7 channel pre amp with the DSP-A2070 used as a 7 channel power amp.
2) Use the inbuilt 7 channel pre amp to power any discrete 7 channel power amp.
The dsp series are very well known for their good phono stage. And yes upto 2 subwoofers are supported by DSP-A2070 pre amp.
  #57
Old 3rd November 2011, 12:43 AM
Reputation points: 738
hemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to behold
Quote:
Originally Posted by avidyarthy View Post
"The amazing thing is, before the top of the amp used to get hot (hot air having less density always rises up), now there is a hot breeze from below while the top remains cool. This means effective cooling is taking place".
Tend to disagree with you here ........
In a still atmosphere, where there is no air movement, whenever there is a heat source (in your case, the heat sinks and few transistors) natural air convection currents set in. 'Heat transfer' makes the heat source transmit the heat to the immediate surrounding air, which gets hot and naturally rise above. The ampflier is so designed that the air vents are placed on top of it, whose role is to throw out the 'lighter' hot air from the amplifier top, thus creating a negative draft within the amplifier, which inturn invites the surrounding ambient cooler air to enter the equipment from whatever 'other' inlet ports given. You say, such ports are there on the bottom of the amp .... right? It is for this reason your amp used to get hot on the top .... as all amps do. But, thats how is has been designed !
What you have now done is to force outside cool air inside. You have made this into a 'forced' blow-thru unit ..... which might prove counter-productive. Why so, since many components which may not be attuned to ever get heated would now continuously get a stream of warm ... maybe, hot forced air .... might be detrimental in the long run.
What I would suggest, is that you reverse the fans and make it into a draw-thru operation. In other words, pull the hot air from the unit top. This would create a strong negative draft inside the unit ..... which would bring in outside cool air continuously .... and keep the unit in its original format. You would now find a steady stream .... sorry, blast of hot air blow from your amp top. Coooool ... thats how the Japos have designed it.
Obviously, the Calcutta heat (air) would also get carried in and end up getting hotter than usual blast from the top outlet..... which would make matters bad in a non-airconditioned listening room ...
"superhot" info!!
Thanks for saving rishiguru from wrong blowjob!
  #58
Old 3rd November 2011, 12:44 AM
"superhot" info!!
Rishi you were blowing in wrong direction..
  #59
Old 3rd November 2011, 08:29 AM
Reputation points: 542
avidyarthy is a glorious beacon of lightavidyarthy is a glorious beacon of lightavidyarthy is a glorious beacon of lightavidyarthy is a glorious beacon of lightavidyarthy is a glorious beacon of lightavidyarthy is a glorious beacon of light
^^^^^ ..... CBJ or BBBJ ......
  #60
Old 6th November 2011, 04:08 AM
Reputation points: 10
skinknmisery is on a distinguished road
Apparently there are some folks who post here that appreciate the yamaha dsp a2070 amplifier and I would value their input as to the current monetary value of a good yamaha sytem that I have located. I have read the posts concerning this amp by rishiguru and appreciate greatly the comments and specifications.
by the by: Since the value of a good 'wife' has recently been discussed I'll have to admit that Robin gave me a pair of 1982 vintage Klipsch LaScalla speaker for my last birthday after a late night confession (later forgotten) that I had drooled over the speakers since I graduated from high school. ... I know the worth of that... priceless
and in fact that's why I need a good amplifier because I've got a good wife heheh
ssooooo.... I'm not calling my self an audiophile but I have a pair of La Scala's and I like to play them loud... I appreciate what they sound like and I'm not looking for sound processing but sound amplification. I only have some Bose 201s and some advent a200s otherwise but the klipsch are in the shop and need to rock. and here's the skinny:
I've located a system consisting of three components what would you give for them if they looked new with remotes and user manuals etc... like they sat in a second home and didn't get use much at all.
yamaha dsp a2070 processor/ amplifier
yamaha dx2 amplifier
tx480 reciever
it seems as though I would have two amplifiers either of which would work for my two speaker system although I know the mx2 would require a pre amp to work solo and the signal processor of the a2070 is dated but (not required specifically for a two speaker system) the reciever is of no value to me at all but oh... i'm drooling over what I know about the amps....
advise me please
skink n missouri
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Yamaha DSP-A2070
Thread Thread Starter Forum Replies Last Post
Suggest me - Yamaha 463 or Yamaha 465 or Onkyo 507 Vijay KD What Should I Buy? 6 26th June 2010 03:54 PM
Yamaha 465 avr + canton 120mx or yamaha 465 avr + jamo 402s or hk 11 system sets_2009 Speakers 3 26th November 2009 03:35 PM
Need opinions on Yamaha rx-v461 and yamaha rx-v459, as well as speakers sandipb Surround Amplifiers/Receivers 4 20th June 2008 03:36 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197
