| Discuss Manually adjusting Crossover Frequency on Denon 2309 at the Surround Amplifiers/Receivers within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi Friends, My home theater setup includes the following:- Denon 2309 AV/Receiver (100 W RMS/channel) ... |
| Notices |
| Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers |
Thread Tools |
#1
Hi Friends,
My home theater setup includes the following:- Denon 2309 AV/Receiver (100 W RMS/channel) Quad 12 L2 Front Left/Right (100 W RMS) Quad L2 Center (100 W RMS) Quad 11 L2 Surround Left/Right (90 W RMS) Definitive SuperCube III SubWoofer (650W Digitally Switching) PS3 for BlueRay/Games Sony DVD Player with HDMI Going thru the settings on the Denon 2309, I came across settings for Crossover Frequency under Speaker Setup. If I go to the advance option, we can set the Crossover frequency separately for each speaker and SubWoofer. By default these frequencies are set to 80 Hz. What I understand from the docs is that this frequency is for low range bass sounds. If I increase the crossover frequencies, what would be the effect? - Would there be more bass sound from the Front /Rear speakers? - The highest range is 250Hz that is configurable on the Denon, will my speakers support it? The crossover frequency mentioned on Quad Speaker manual says 2.2 Khz. http://www.quad-hifi.co.uk/downloads...0low%20res.pdf Definitive sub specs says:- SuperCube III Specifications: Dimensions: 10-1/4" W x 10-1/4" D x 10-1/4" H Frequency Response: 16 Hz â 200 Hz Driver Complement: One 7-1/2" long-throw driver to two 7-1/2" pressure-driven infrasonic bass radiators. Amplifier: 650 watt Digitally Switching Low-Level High Pass: 40Hz â 150Hz (variable) 12dB per octave Speaker Level High Pass: 80 Hz (6 dB per octave) Low Level Low Pass Filter: 24dB/octave continuously adjustable variable (40 â 150 Hz) plus Unfiltered LFE direct coupled input. Phase Control: 0 degrees â 180 degrees (continuously variable) Finish: Piano gloss black Weight: 40 lbs. Suggested Retail: $699 ea. I want to confirm this from expert who deals with Home Theater setups or has good knowledge on this subject. Thanks a lot Regards Thomas |
| Sponsored Links |
#2
Re: Manually adjusting Crossover Frequency on Denon 2309
somewhat covered here -
http://www.hifivision.com/surround-a...essions-2.html |
| Sponsored Links |
| Bookmarks |
| Tags |
| crossover, denon, frequency ranges, quad |
| Thread Tools | |
Similar Threads for: Manually adjusting Crossover Frequency on Denon 2309
| Thread | Thread Starter | Forum | Replies | Last Post |
| Denon 2309, any suggestions | pradski | Surround Amplifiers/Receivers | 14 | 7th November 2008 08:36 PM |
| Frequency vs dB | ajithlal | Speakers | 16 | 13th August 2008 01:37 PM |
| Subwoofer crossover? | insane79 | Speakers | 23 | 23rd June 2008 06:26 AM |
