AV Receiver and floorstanders (40K - 50K)
Discuss AV Receiver and floorstanders (40K - 50K) at the Surround Amplifiers/Receivers within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi, I am planning to build HT budget (70K - 80K) But to start off ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Notices
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 22-03-07, 02:33 PM
sunchand is on a distinguished road
But to start off I have budget of 40-50K, so I am planning to buy a receiver and floor standers, then some time later when I have some more money and approval I would be buying sub, surrounds and center.
I have audioned Jamo s606/Jama AVR-693 along with S6 series center and surround. It was good but I am not really keen on buying Jamo receiver.
complete package which includes(S606 floor standers, s6 surrounds, center channel and Jamo 693 receiver) comes for 60K.
I have also auditioned JBL E60, they were good and loud.
I am also planning to audition Wharfedale Diamond 8.4 and 9.5 floorstanders.
The usage is going to be 70% music and 30% movies.
Audio gurus, please give ur
suggestions on 5.1 receivers in the price range of 20 -22K.
suggestions on floor standers in the price range of 20-26K.
suggestions on sub in the price range of 15-20K.
TIA
Suneet
Sponsored Links
  #2
Old 20-07-07, 12:59 AM
MTP MTP is offline
MTP is on a distinguished road
Re: AV Receiver and floorstanders (40K - 50K)
Hey,
I was looking at the same setup but Iam not keen on a Jamo receiver as well. What did you finally go for? do let me know it would be of great help.
cheers
TP
  #3
Old 21-07-07, 12:46 PM
Jagat is on a distinguished road
I would suggest you hear the Denon 1507 with the Wharfedale's. They make a good combo.
  #4
Old 27-07-07, 01:14 PM
rashmikant is on a distinguished road
I would suggest Onkyo Av Receiver TX SR 603 or TX SR 674 along with Tannoy Fusion 4 main, Tannoy Fusion II for surround, Tannoy Fusion center.
it is very excellent set up if any suggestion require, call to Mr.Jignesh - 09825133320
  #5
Old 27-07-07, 11:12 PM
MTP MTP is offline
The onkyo receivers are all rated at 6 ohm, thats the only reason i havnt been looking at onkyo cause there would be an impedence mismatch to most of the speakers at 8 ohms. Does anyone have an idea if onkyo can work at 8 ohms as well ?
thanks
MTP
  #6
Old 28-07-07, 07:17 AM
Mohan is on a distinguished road
Quote:
thanks
MTP
This is a convienent method for Onkyo to quote a higher wattage load into 6 ohms. At 8 ohms the wattage from the Onkyo receiver will be even lower. Please keep this in mind.
  #7
Old 05-08-07, 12:52 PM
Shuvc is on a distinguished road
How much does the Onkyo 674 retail for here ?
Has anyone used it with Polk Monitor speakers ?
  #8
Old 07-08-07, 07:31 AM
cyrus is on a distinguished road
I think you should get the Onkyo for around Rs. 30K. The Polk Monitor speakers are good (great value for your money in India) but if you are audiotioning the Onkyo check out the Elac speakers too.
  #9
Old 07-08-07, 07:48 AM
Quote:
Any particular Elac model ?
I was considering the Polk Monitor 50's. So obviously the budget is around 20-25K for the front towers.
Are European speakers priced more than the American ones in India. I find that for similar specs, the Polk range and the Klipsch range tend to cost a bit lower than the Danish, British etc brands.
Finally, how suitable is the Onkyo 674 for listening to music (stereo) ?
  #10
Old 07-08-07, 09:40 AM
The Polk Audio Monitor 50's are good speakers for their price. Elac will be way above your price range.
I think the American speakers cost less could be because of the favourable dollar rate with the rupee.
I would definately prefer Denon AVR-1907 to Onkyo for music(stereo).
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: AV Receiver and floorstanders (40K - 50K)
Thread Thread Starter Forum Replies Last Post
feedback review on Onkyo TX-SR504 receiver Jagat Surround Amplifiers/Receivers 3 21-02-08 11:01 AM
Mordaunt – Short Avant 904 Floorstanders - Brand New paj4x4 For Sale 1 03-02-07 09:16 AM
Advertise Here
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
