HiFiVision.com - Audio Video Hi-Fi Forum
Denon vs Marantz vs Yamaha
Discuss Denon vs Marantz vs Yamaha at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; Hello everyone. Im looking forward to buying a new receiver, Im not much of an ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 20th December 2012, 09:08 PM
Deloy88's Avatar
Reputation points: 10
Deloy88 is on a distinguished road
Hello everyone.
Im looking forward to buying a new receiver, Im not much of an expert when it comes to receivers so I like to get some opinions on which direction I should go.
My current setup is
Yamaha RX-V667
Klipsch
4 B20
1 C10
2 S10
1 SW350
As for the AV Receivers that I am looking at, there are
Denon AVR-1913
Marantz NR1603
Please share your thoughts, and if you think there are better options than the ones I have that are in the range of $500 and $700 please share those as well.
Sponsored Ads
  #2
Old 21st December 2012, 07:36 AM
Kittu's Avatar
Reputation points: 1020
Kittu has much to be proud ofKittu has much to be proud ofKittu has much to be proud ofKittu has much to be proud ofKittu has much to be proud ofKittu has much to be proud ofKittu has much to be proud ofKittu has much to be proud of
Re: Denon vs Marantz vs Yamaha
I'd say you have the best receiver with you already, you just need to add a 5 channel power amp and you are set for long years to come.
The Following User Says Thank You to Kittu For This Useful Post:
  #3
Old 21st December 2012, 08:02 AM
spirovious's Avatar
Reputation points: 1927
spirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant future
What is the reason for new AVR?If power is the issue then poweramp can be the solution as kittu said.The AVR you shortlisted are not powerful though.
The Following User Says Thank You to spirovious For This Useful Post:
  #4
Old 21st December 2012, 10:57 PM
Deloy88's Avatar
Thank you so much for your input!
Im just considering it, Im not saying that Im ready to change my receiver.
It might be a dumb reason, but Im just interested in getting a receiver with networking capabilities and while Im at it, maybe upgrade my sound quality/power. But like I said, Im really happy with this piece of equipment.
About the 5 channel power amp, will it still serve its purpose even when my speaker setup is 7.1?
  #5
Old 21st December 2012, 11:52 PM
spirovious's Avatar
You can use 5ch for speakers other than surround rears,AVR can drive surround rear which has hardly any role in movies.
  #6
Old 22nd December 2012, 03:27 AM
Deloy88's Avatar
Can you guys suggest power amps?
Or share a guide so I can pick one?
  #7
Old 22nd December 2012, 06:54 AM
Kittu's Avatar
Emotiva
ADcom
Rotel
All have decent 5 channel amps. Since you are in mexico , it should be easy for you to source from USA reselling sites like audiogon.
  #8
Old 22nd December 2012, 08:31 AM
spirovious's Avatar
To my ears,Emotiva is powerful,but Rotel sounds natural.
Reply
Bookmarks
Tags
denon 1913, denon vs marantz, marantz 1603, yamaha 667
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Denon vs Marantz vs Yamaha
Thread Thread Starter Forum Replies Last Post
Most Reliable Brand? Denon/Onkyo/Yamaha/Marantz visanj Home Theater 18 20th April 2013 08:29 PM
Yamaha rx-v673 or Yamaha A810 or Denon 2312 or Marantz 6006 for Polk RTI A5 raj_krish Surround Amplifiers/Receivers 4 15th November 2012 12:21 AM
Marantz Sr5005 vs Denon 1612 vs Yamaha-v671 ? paramesh Surround Amplifiers/Receivers 41 28th August 2012 03:18 PM
AVR Group Buy- Yamaha, Onkyo, Denon, Marantz ! mav Hot Deals 102 24th November 2011 12:06 PM
Marantz , Denon Yamaha sameerlemos Surround Amplifiers/Receivers 7 30th September 2011 03:39 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
