| Discuss Entry Level AVR needed at the Surround Amplifiers/Receivers within the HiFiVision.com - India's Audio Video Hi-Fi Forum; I have been using -in my bedroom- a Harmon Kardon 15 WRMS /Channel AVR (yes ... |
| Notices |
| Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers |
Thread Tools |
#1
I have been using -in my bedroom- a Harmon Kardon 15 WRMS /Channel AVR (yes really only 15 Watts/channel !) since ten+ years and its due for a replacement as the metal bits are crumbling.
Which is a good entry level AVR ?? My speakers are the small JBL Control One with max input of 150 WRMS (impediance 4 Ohms) with a powered sub for the bass. The existing AVR delivers enough clean volume for my needs, so I would not look at something over 40 or 50 WRMS / channel. Also, don't need a "bright" sounding AVR. Any ideas? Last edited by ChetanSouthMumbai; 29-06-07 at 08:41 AM. Reason: corrections to data |
| Sponsored Links |
| Bookmarks |
| Thread Tools | |
Similar Threads for: Entry Level AVR needed
| Thread | Thread Starter | Forum | Replies | Last Post |
| Entry level turntables for the vinyl lover | cyrus | Phono/Turntables | 6 | 03-04-07 10:04 AM |
| Help needed | Rameshrao | My Audio/Video Setup | 2 | 02-09-06 09:30 PM |
| Entry level Budget Bookshelf Speaker Review | Anil | Speaker Reviews | 2 | 13-08-06 06:25 PM |
