HiFiVision.com - Audio Video Hi-Fi Forum
Voltage fluctuation caused power supply failure
Discuss Voltage fluctuation caused power supply failure at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; This I am writing to know the possible ways to avoid damage to amplifiers due ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Bookmark and Share Thread Tools
  #1
Old 6th May 2009, 11:49 AM
Reputation points: 36
vivekam is on a distinguished road
This I am writing to know the possible ways to avoid damage to amplifiers due to voltage fluctuations.
Actually couple of days back in my locality voltage supply reached 400V. Unfortunately my Yamaha amplifier was on at that time, due to this high fluctuation it switched off automatically. When voltage came back to normal level it never turned on. Luckily my amplifier was under warranty and yesterday I got it back. Its runnning fine now.
But, when I asked service center guys about how to avoid this in future. They said using voltage stablizers is only 50% safe. Still your amplifier will be in danger.
So my query is, is it really true (50% logic) Or can we really protect our amplifier from voltage fluctuations?
Sponsored Links
  #2
Old 6th May 2009, 11:58 AM
Reputation points: 18
dali is on a distinguished road
Re: Voltage fluctuation caused power supply failure
Hi vivekam
Use a good quality Servo Stabilizer 1 kVA . This should solve the problem. If there is lot of fluctuations in your area , use a isolation transformer along with the stabilizer. This should give you constant power supply and thus prevents your equipments from fluctuations.
Vijay.
  #3
Old 6th May 2009, 12:15 PM
Quote:
Originally Posted by dali View Post
Hi vivekam
Vijay.
Hi dali,
Fluctuations occurance chances are minimal. It reached to 400V due to some short circuit in transmission line.
I see your location as Pune. Can you please guide me from where can I get servo stabilizer in Pune. Also it would be great if I get to know approx. price.
Thanks,
Vivekam.
  #4
Old 6th May 2009, 12:21 PM
Hi Vivekam
I use a servo Stabilizer from Vertex ( recommended by most of the members from this forum ) I use 2KVA and the price i paid was Rs.13k , shipped directly from Chennai.
vijay.
  #5
Old 6th May 2009, 12:26 PM
gobble's Avatar
Reputation points: 844
gobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to behold
Hi Vivekam
vijay.
Hi Vijay
did you notice a difference in SQ with and without stab?
TIA
  #6
Old 6th May 2009, 01:01 PM
dinyaar's Avatar
Reputation points: 224
dinyaar has a spectacular aura aboutdinyaar has a spectacular aura aboutdinyaar has a spectacular aura about
Am surprised that the Yamaha service centre guy told u that the stab can only offer about 50 % protection.
A well made servo stab from vertex, Argo etc with over /under voltage cut off should offer adequate protection IMO. We had checked the Argo stab on a VARIAC and the stab cut off when the incoming voltage crossed 250V
U can get 3 KVA servo stabilizers for as low as 3K in bbay where as a 3 KVA Argo is about 12 K so if one opts for the former one is in trouble but if one opts for reputed brands one should be safe.
Rgds
  #7
Old 6th May 2009, 01:55 PM
Same surprise factor led to this query.
Dinyaar Ji in bbay where can I get it. I wish to protect my equipment rather than keep it testing against high voltage.
Any where in Pune servo stabilizers are available?
  #8
Old 6th May 2009, 02:51 PM
cmsajith's Avatar
Reputation points: 258
cmsajith is a jewel in the roughcmsajith is a jewel in the roughcmsajith is a jewel in the rough
As per my understanding none of the stabilizer can handle a sudden dip or hike in voltage (within the cutoff limit) because of the fluctuation detection and correction time delay. It will be passed on to the connected equipments till it crosses the cutoff limit or it will be rectified within the correction time. Compared to normal stabilizers, servo will provide a smooth voltage correction. Normal stabs handles this by increasing the voltage to some fixed 30/40 volts when it is crossing the voltage correction range (usually is +/- 20-40v from the calibrated o/p, unlike 2-3v in servo). So better choose a servo and from reputed brands coz' the voltage sensors and the quality of the servo motor matters a lot.
"Am surprised that the Yamaha service centre guy told u that the stab can only offer about 50 % protection.", correct with normal stabilizers because of the sudden voltage corrections of 30-40v.
Correct me if i am wrong.
I am using Vertex servo 3Kva with RF/EMI filters and spike protection (11500/- under special disc.).
  #9
Old 6th May 2009, 03:25 PM
Asit's Avatar
Reputation points: 611
Asit is a name known to allAsit is a name known to allAsit is a name known to allAsit is a name known to allAsit is a name known to allAsit is a name known to all
Thanks,
Vivekam.
Hi Vivakam,
I am finally getting 3 KVA Krykard servo stabiliser with RF/EMI Filter and spike suppressor directly from Chennai for about 13.5K. It is currently in transport, should reach my home around next weekend. If you read some old threads, you will know about this Krykard brand, it is equal or better than the Vertex. Another good brand is Aplab for servo, their factory is in Thane. Based on my information, the transformer in Krykard is something special which others may not have.
Krykard has a selling office in Pune. All you have to do is contact them and pay directly to them and they will deliver the product.
Our forum member SuhasG who lives also in Pune and an Electrical Enginner by training and profession owns a 3 KVA Krykard stabiliser and he bought it exactly the way I have described above. Please contact him to know the address and phone no of this place in Pune.
Before I made my decision, I did contact him by sending him a PM. The only problem in my case was that Krykard does not have an office in Kolkata, they only have one service person here, so I myself had to get it directly from Chennai.
The Following User Says Thank You to Asit For This Useful Post:
  #10
Old 6th May 2009, 03:28 PM
Reputation points: 534
kaushik is a glorious beacon of lightkaushik is a glorious beacon of lightkaushik is a glorious beacon of lightkaushik is a glorious beacon of lightkaushik is a glorious beacon of lightkaushik is a glorious beacon of light
no more worries ..no more sepnding 12k... 13k for me ..
i use a protector rated 6AMPS made by su-kam
[does not regulate the voltage,it is a voltage and freq. window protector]
it has
-60 sec Time delay relay,upon switching on ,during this it checks for line condition
-It will protect the equipments from bad power quality like under voltage, over voltage, Frequency variation, surges, spikes, sparks due to loose connections and short power interruptions
-It has very fast response time of typical 15-20 millisecond to cut off the equipment from the bad
quality power
-allows only 190 -230v
>>> SU-KAM <<< Leading manufacturer of Power Products in India, Only Power back up company manufacturing world class UPS, Home UPS, Online UPS, Inverters, Batteries, Battery Chargers, Solar Products
costs 350Rs hehe ..now some people will express serious doubts ..for me it worked very well so far
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Voltage fluctuation caused power supply failure
Thread Thread Starter Forum Replies Last Post
Voltage issues in power supply/Inverters sidvee Audio Video Accessories 30 20th December 2010 04:00 PM
HELP! MY ROTEL CDP Power Supply Burned out! malvai AV Lounge 20 18th January 2010 10:33 AM
Power supply for Klipsch Subwoofer sub10 in India? sunragav Speakers 1 24th June 2009 11:44 AM
Power Supplies - SMPS vs linear power supply anm Home theater PC (HTPC) or media PC 2 3rd May 2009 06:16 PM
Mains Power supply and Hi-Fi Mohan AV Enhancers & Room Acoustics 2 8th September 2006 11:32 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189
