HiFiVision.com - Audio Video Hi-Fi Forum
Need recommendation for Yamaha AVR
Discuss Need recommendation for Yamaha AVR at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; Originally Posted by Anand23 guys one more question..i was checking out the specs of yamaha ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #21
Old 3rd September 2013, 09:06 AM
Reputation points: 11
aditya mishra is on a distinguished road
Re: Need recommendation for Yamaha AVR
Quote:
Originally Posted by Anand23 View Post
guys one more question..i was checking out the specs of yamaha htib yht299... the specs of yamaha rx-373 or rx375 looks almost same with the htib's reciever... can some one tell me any specific difference between these systems...
i have a pair of wharfe 9.5 floor standers ..looking to build a HT around these as mentioned earlier...
i have two options :
1. Yamaha YHT299 HTiB -- 36.7 k
2. Yamaha rx 375 --26.2 K + Yamaha NSP40 center +surround --12.3 k = 38.5 k
pro's of option 1.: extra sub woofer and front speakers and i would as well save 2 k
con's : you guys should tell me..
IMHO, never go for small satellite spks, if u hv space to accomodate FS (specially for music listening). Good FS & an active SUB will be a great setup.
.... 373 has no USB, lesser ports, & is obsolet, i think
regards
-Aditya
The Following User Says Thank You to aditya mishra For This Useful Post:
Sponsored Ads
  #22
Old 8th September 2013, 05:55 PM
Reputation points: 15
adi_vastava is on a distinguished road
^^ 373 does have a USB port (also act as a DOC for iDevices)
  #23
Old 10th May 2014, 06:13 PM
pmvali is on a distinguished road
Quote:
Originally Posted by sarangd22 View Post
Hello experts,
Can you please recommend any yamaha AVR in the price range of around 30K (bit flexible on the price) and available in india. I saw 73 series and 75 series but many options there and reviews differ. I would want recent models as technolgy keeps upgrading all the time and I expect my new AVR to keep up with it for near future at least. I also see Sony STR - DN 1030/1040 getting good reviews though dont know how they compete against Yamaha.
Any BS speakers recommendations to go with the respective AVR? I am more of music fan than moview watcher, so is subwoofer really needed?
Dear friend
I purchased Yamaha AVR RX-V473 in the month of June 2013. The speaker are: NS-8390(THREE WAY BASS REFLEX , (TOWERS )MAIN SPEAKERS); NS-P60(CENTRE & SURROUND SPEAKERS) and YST-SW215 (SUBWOOFER).
Asus O Player Mini Plus is complementing the system.
The system is well covering my living room of 13 X 18 feet. So far no issues.
The AVR RX-V473 is a Network amplifier. This means you can play internet content via wifi, content from DLNA enabled devices without connecting them through cables. But for these features, there is literally no difference between 473 and 373. There is considerable price difference. Both give same sound quality.
Yamaha RX-V573 has same feature as RX-V473 except it can be used in two rooms with extra speakers and obviously costs a little more. The prices of these three AVRs are Rs.27,000/-, Rs.35,000/- and Rs 44,000/- respectively.
I hope this will be of some help to you in making a decision.
  #24
Old 10th May 2014, 06:56 PM
Reputation points: 184
sgmane has a spectacular aura aboutsgmane has a spectacular aura about
@sarangd22 - did you get the AVR?
@pmvali - appreciate your comments. The OP's thread/comment is a year old now!
Let's wait and see had he got any AVR still?
  #25
Old 10th May 2014, 06:57 PM
Hello experts,
Dear friend
I purchased Yamaha AVR RX-V473 in the month of June 2013. The speaker are: NS-8390(MAIN SPEAKERS; NS-P60(CENTRE & SURROUND SPEAKERS) and YST-SW215(SUBWOOFER).
The AVR RX-V473 is a Network amplifier. This means you can play internet content via wifi, content from DLNA enabled devices without connecting them through cables. Except these features, there is literally no difference between 473 and 373. There is considerable price difference. Both give same sound quality.
Yamaha RX-V573 has same feature as RX-V473 except it can be used in two rooms with extra speakers and costs a little more. The prices of these three AVRs are Rs.27,000/-, Rs.35,000/- and Rs 44,000/- respectively.
Of late we can see many consumer electronics are made with DLNA or similar feature, including pocket cameras. It is worth spending a few bucks on network AVRs, specially in 5 years perspective.
I have gone through the discussions in various fora and purchased AVR RX-V473. Please check whether it has in-built wifi is available. If not you have to purchase a separate adapter and is costly. This model is reasonably priced and made-in-Malaysia are sold in India. It consumes less power compared to Onkhyo AVRs.
The other point raised by you is Book-shelf speakers- I say do not go for them. A separate and active sub woofer will not draw power from AVR which is advantageous.
1.The AVR will not gets heated up.
2.The main speakers and surround speakers will have steady power even when the demand from sub woofer is more, like when low frequency is dominating the scene.
3. with active sub woofer, the room will be filled with excellent sound when a DTS file is played. It will help the system in producing all the frequencies at the level of settings through out. A passive sub woofer which is a part of the BS speakers, will depend on AVR and draws a lot of power in such scenes denying actual power required by the main and surround speakers and this results in their poor performance. Hence, it is always better to have a separate active sub woofer, if funds are not a constraint.
Reply
Bookmarks
Tags
avr, yamaha
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Need recommendation for Yamaha AVR
Thread Thread Starter Forum Replies Last Post
3D TV Recommendation. Indian11 Television 194 14th July 2013 07:02 PM
DAC Recommendation Please riteshmadhok Portable Audio Players & Accessories 0 9th July 2013 06:29 PM
Help ! ! Tv Size recommendation puneet Television 22 9th July 2011 01:09 PM
AVR Recommendation please baijuxavior What Should I Buy? 10 13th March 2011 01:25 PM
Request recommendation for Speaker Sets for Yamaha RX V1900 AV Receiver jravich What Should I Buy? 10 1st December 2010 09:42 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
