| Discuss AVR or Stereo Receiver (Yamaha RX797/Marantz SR4023/Denon DRA697)? at the Surround Amplifiers/Receivers within the HiFiVision.com - India's Audio Video Hi-Fi Forum; This is for a set up in the bedroom (14' X 12') separate from the ... |
| Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers |
Thread Tools |
#1
This is for a set up in the bedroom (14' X 12') separate from the Home Theatre. Primarily the following components will be used. 1. Plasma 42" HDTV (720p most probably) 2. STB - Tata Sky 3. DVD Player 4. iPod 5. Camcorder/Digicam 6. Quad 11L2 / 12L2 with a Sub may be (2.0 or 2.1) 7. Dedicated CDP 8. Ceiling speakers in Zone 2-3 (Audio Zones) i.e. sit-out and the bathroom. 9. Stereo Receiver or 5.1 AVR Primarily all the sources being used do not have 1080p Data which needs HDMI or component. Thus they can be connected via composite video given in the Stereo Receiver. Or they can be directly connected to TV for video purposes. Also any HD source added later can be connected directly to the TV. What is choice recommended for number 9. (Stereo receiver or 5.1 AVR)? pros and cons. Usage is evenly split between TV/Movies/Music. Budget 30-40K flexible. Also if Stereo receiver is considered better then which of the below three. 1. Marantz SR40023CI Marantz America | SR4023 CI Friendly Stereo Receiver 2. Yamaha RX-797 RX-797 3. Denon DRA-697CI Denon USA | DRA-697CI Hoping for proper guidance in the above. Raghav |
| Sponsored Links |
#2
Re: AVR or Stereo Receiver (Yamaha RX797/Marantz SR4023/Denon DRA697)?
Since you already have a HT setup and also thsi is the bedroom, you want to go for a music system. The Quad's are really natural speakers that stay true to the source.
By doing zone 2 ... you are spreading yourself too thin in terms of having a solid system versus one with a lots of bells and whistles. I would go for a mid level integrated amp like an Arcam or a Nait or Music Hall and a decent CDP such as a Cambridge Audio or a Marantz or a Arcam |
| The Following User Says Thank You to marsilians For This Useful Post: | ||
Raghav (4th July 2009) | ||
#3
Quote:
You have now made it a choice between amp or stereo receiver. Should i take it that 5.1 AVR is not at all recommended. |
#4
Quote:
This is also what a stereo receiver offers. However it wont have a built in pre-processor and amplifier sections that are separate. If you intend to use composite to connect to the TV, then having a Plasma is a waste of money. In this case you may be better off with an AVR but to have to settle for marginal audio quality relatively |
#5
integrated amp or stereo recievr- you need to choose what you need
however as for which brand you should take well ive heard the quads with a denon and a marantz. i would definetely pick a marantz for these speakers. Denon would require some brighter speakers to make a good pairing which Quad is NOT however i cant say anyting about Yamaha since ive not heard it with these speakers. though i do believ that yamaha would make a good match too |
| The Following User Says Thank You to magma For This Useful Post: | ||
#6
If the source is SD (DVDs, Tata Sky, iPod) what is the benefit of connecting them via HDMI. Upscaling maybe one of them, but there are several arguments that the HDTV does equally good job of upscaling vis-a-vis AVR. Also if I get BD player, I can by pass the 2.1AVR and connect staright to TV for the Video.
#7
Quote:
| Bookmarks |
| Thread Tools | |
Similar Threads for: AVR or Stereo Receiver (Yamaha RX797/Marantz SR4023/Denon DRA697)?
| Thread | Thread Starter | Forum | Replies | Last Post |
| In US and unable to decide: Integrated Amp. or Stereo Receiver or A/V Receiver | pinkfloyd | Surround Amplifiers/Receivers | 15 | 29th April 2010 05:30 PM |
| Marantz SR4002 or Denon AVR-1910 or any other receiver | Prashant Poojary | Surround Amplifiers/Receivers | 9 | 27th March 2010 10:37 PM |
| AV Receivers Denon 2310 or Marantz SR6005 or Yamaha RX V665 | balu_tigers | What Should I Buy? | 1 | 22nd March 2010 02:02 AM |
| Diff between Integrated stereo amplifier / Stereo Receiver | elangoas | Amplifiers | 6 | 19th March 2010 08:29 PM |
| Which is Good : Stereo Receiver / Multi Channel Receiver for listening to Stereo CD's | elangoas | What Should I Buy? | 4 | 12th February 2010 10:22 AM |
