HiFiVision.com - Audio Video Hi-Fi Forum
Upscaling - Is it worth ?
Discuss Upscaling - Is it worth ? at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi all I am plannign to get onkyo s 3200 , recently i have been ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 19th August 2009, 10:59 PM
Reputation points: 60
Naveen_Reloaded will become famous soon enough
Hi all
I am plannign to get onkyo s 3200 , recently i have been seeing , reading about upscaling .. and S3200 has only HDMI pass through.
I watch more DishTv , CAble , so does upscaling really help in better quality of these inputs ? i mean ca 480i been upscaled to 1080 / 720 p ? and does it look better ?
my budget is around 30K and onkyo S3200 perfectly fits , but since i am now into upscaling thought , can anyone suggest me / advice on this issue...
Sponsored Ads
  #2
Old 19th August 2009, 11:20 PM
Reputation points: 109
skumar will become famous soon enoughskumar will become famous soon enough
Re: Upscaling - Is it worth ?
Upscaling a good quality DVD msy be worth it, but if you are talking about SD content dished out by our cable wallahs and DTHs, I don't think it is worth. I have a 32" HDReady LCD and BigTV DTH pictures look damn good on it, I do have an upscaling DVDP which churns out stunning quality. Upscaled SD images may not be better than the original, especially if original content is of low quality (cable/DTH).
I suggest (relative to your budget) that you go for the HTIB you like without bothering about upscaling. When you have budget, buy a DVDP like Pio610 or BDP and connect the video directly to the TV. You can always route the audio to the AVR.
  #3
Old 19th August 2009, 11:42 PM
moserw's Avatar
Reputation points: 398
moserw is just really nicemoserw is just really nicemoserw is just really nicemoserw is just really nice
The only upscaling/upconverting I really enjoy and can recommend is the one by Oppo line of DVDPs. They do a wonderful job with SD DVDs. For TV content unfortunately just about everything sucks but of course I've not used a high end AVR with a great upscaling chip either but those are definitely not in the said budget of 30K.
  #4
Old 20th August 2009, 12:10 AM
spirovious's Avatar
Reputation points: 1955
spirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant future
Upscaling may not worth is many ways-
ie.Generally the source(DVDp/BDP) can upscale much better than others(think of making ideal connections DVDp> AVR> TV)
One thing where its most needed is DTH/Cable TV.If TV scales better,then really no need.Save money & spend on source.
  #5
Old 20th August 2009, 12:21 AM
thnks for reply guys ...
but i cant understand... leave out the DVD upscaling , i dont use much DVD .. and i have PS3 , i think it does upscale....
i am bothered about my local cable / Zee DishTv ( not HD ) , coz at present they are linked directly and they dont look good , so if i pass through a AVR which has upscaling , will it look better ?
if so can anyone suggest a good AVR + 5.1 around 30-35 k ...
  #6
Old 20th August 2009, 12:25 AM
spirovious's Avatar
Yes PS3 upscales better.
Dishtv will lookk good in 2 way.
1.If tv upscales better(like sonyw550/V550 series) no need of AVR doing it.
2.In your case if you cant enjoy Dish,you really need better scaler like in new Denon 1910.
The Following User Says Thank You to spirovious For This Useful Post:
  #7
Old 20th August 2009, 12:48 AM
frnd08's Avatar
Reputation points: 30
frnd08 is on a distinguished road
just a casual query.
is blu ray and an upscaled dvd have a heaven and hell difference in picture quality or is it just minimal?
  #8
Old 20th August 2009, 01:12 AM
moserw's Avatar
It is indeed a huge difference, no way is it minimal. Once you watch HD you cannot go back to SD.
  #9
Old 20th August 2009, 01:51 AM
can i cover 5.1 + AVR within 30-35 K ? how much is denon 1910 ?
  #10
Old 20th August 2009, 09:38 AM
You need to take a call on your budget. ~30k, your options will be the HTIBs from Onkyo/Yamaha/HK only which will not have upscaling. Also, you need to worry about the power bill, if you watch hours of TV everyday routed thru your AVR (for upscaling). An AVR consumes about half an Unit of power per hour.
If you really want to go for an upscaling AVR, up your budget ~45k, buy an AVR and 2.0 speakers for now.
I understand you wish to get the best out of your budget, and we would definitely help in acheiving it. At the same time, your options will not change (from HTIB to upscaling AVR+5.1) by repeating the same question.
If you watch lots of TV, another option worth considering is to get a DTH connection like BigTV. Their video quality is among the best (if not the best) in Indian DTH providers and their STB has component output for video.
The Following User Says Thank You to skumar For This Useful Post:
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Upscaling - Is it worth ?
Thread Thread Starter Forum Replies Last Post
HMV GRAMAPHONE worth freshseasons Phono/Turntables 14 6th March 2013 11:57 PM
Sony: DVP-NS728HP/B video upscaling vs AV receivers video upscaling balajeem Surround Amplifiers/Receivers 0 22nd February 2010 04:29 PM
is it worth to buy LG32LH60YR? vipul1313 Television 7 14th February 2010 02:28 PM
Bringing LCD-TV from US. Worth it? fide Television 3 27th May 2009 01:17 PM
Is thx certification really worth. manofernando Surround Amplifiers/Receivers 4 17th October 2008 12:04 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
