Onkyo SR605 Help (US make)
Discuss Onkyo SR605 Help (US make) at the Surround Amplifiers/Receivers within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Originally Posted by planetavi Hey guys thanx for all te help, I happened to reconfigure ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Notices
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #11
Old 19th March 2008, 12:12 PM
goose is on a distinguished road
Re: Onkyo SR605 Help (US make)
Quote:
Originally Posted by planetavi View Post
Hey guys thanx for all te help, I happened to reconfigure them again yesterday, n they all worked fine.....I thing I think one open speaker cable was touching the Receiver...(short)
Ive got Klipsch Quintet III, need a suggestion to buy a Subwoofer any advice?
Hi, I'm planning on either the 605 or the yamaha 663. The one thing that I keep hearing about Onkyo receivers are that they overheat? Are you encoutering any problem like this pl? Or maybe you haven't used it enough yet? thanks!
G
Sponsored Links
  #12
Old 31st August 2008, 01:50 AM
shangrila is on a distinguished road
hi,
I am facing a similar issue. I have brought an Onkyo NR905 to India. I got a step down transformer made to handle 1KW load. The transformer is giving out less than 110V output.
I tried to switch on the amp through this transformer. I have no speakers or equipment connected to it. When I press the power button, the red light on the power button blinks & the system goes back to standby.
Please advice what to do.
Thanks,
Vik.
  #13
Old 31st August 2008, 01:23 PM
venkatcr is just really nicevenkatcr is just really nicevenkatcr is just really nicevenkatcr is just really nice
Quote:
have been using an 875 for over six months. Yes, it does get hot even when it is on standby. What you have to do is the following:
1. Give it power from a separate wall unit, so that you can power off completely when not in use. Do not give it power from the same wall unit that gives power to your TV, DVD Player etc.
2. Use slightly higer A/c capacity in the room. Maybe 1.2 a ton more than specified.
3. Keep the AVR on the top most rack of an audio rack, if you have one. In other words, other than the bottom, all other sides must be open.
4. To be doubly safe, see if you can buy a cooling unit and place it on top of the unit. Such cooling units which is basically a board with a small fan inside, will be available in computer shops.
Vik:
110v should be enough. Though the 905 is specified as consuming 1000 watts, I would be happier with a transformer that is 1.5 KW at least.
(1)
Ensure your transformer is not tripping when there is load demand. You can get a electrician to confirm this for you. Better electricians have a external unit that have a external unit with a amanual switch by which they can set the demand on the transformer. This will increase this in steps to see how the transformer behaves.
(2)
The Onkyo series has a setting by which you can set off all display on the unit. The unit will continue to be working. This happens particularly when you are using two channel audio in 'Pure Direct' mode, as Onkyo cosiders even the display to be unnecessary for 2 channel audio. The unit will usually come on with the same settings you switched it off with.
Please read the manual carefully and ensure that this has not be triggered on by mistake. If so, set it off, and you will have all the display lights working.
(3)
Ensure that the batteries in your remote are in good condition. Sometime back I got a fright when the system will refuse to come on, till I realised the remote batteries were weak.
(4)
There is a way to reset button the unit. Use this and restart the unit. Before doing this remember, you have to set up the unit as if it is the first install. Use this as the last option.
Keep giving us feed back and I am sure we can resolve your issues.
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Onkyo SR605 Help (US make)
Thread Thread Starter Forum Replies Last Post
Review of Onkyo TX-SR304E Receiver with Onkyo SKS-HT230 5.1 need advice...help me akshaye Home Theater In A Box 7 21st November 2008 02:29 AM
what speakers for Onkyo Tx-SR605? vijay_ditango Introductions 9 2nd June 2008 07:10 PM
Do Power cords make a difference to a hi-fi systems performance Neal Audio & Video Cables 2 18th March 2007 01:09 PM
Advertise Here
Copyright © 2006-2009, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
