| Discuss Help on HDMI setup at the Surround Amplifiers/Receivers within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi Can any one tell me if I can play the TV (audio) through HDMI ... |
| Notices |
| Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers |
Thread Tools |
#1
Help on HDMI setup
my TATA sky is directly connected to LCD ad not Via Receiver, my reciever is connected to LCD through HDMI cable. do I need add another connection to play audio on external speakers, or Ive to pass Tatasky through Receiver? |
| Sponsored Links |
#2
Re: Help on HDMI setup
To play TV audio in any external speaker you need a connection from the AUDIO OUT PUT to your external speaker or AVR or AMP. it can be from the TV or your tatasky box.
-Sk |
#3
605 Does not upconvert, and Tatasky does not yet have HDMI out.
so, in case you need to pass TS through receiver, connect the TS to composite in of the recv and pass composite out of the recv to composite in of the LCD. You would end up with two sets of cables to your LCD ( the composite for your TS and HDMI for your hdmi video source). Your HDMI will be worthwhile only if you have a hdmi video source feeding your recv. My 2 cents. |
#4
Yes, you can. This is how I have done it:
1.
regards |
#5
Kiran,
<digression> Does TataSky send out 480i signals? I thought it was much worse: -) <end-digression> |
#6
Not to nitpick but I assume it sends out a 576i signal as it is a strictly PAL device (also as composite cable is incapable of carrying a progressive scan signal, it is almost certainly interlaced).
@planetavi: Assuming that your TS box is the only composite video capable device, it would be best to connect it directly to the TV via composite cable and send the audio to your AV receiver. If you wish to be able to watch TV without switching on the AV receiver, then connect the TS to audio-in on the TV and then route the audio-out from TV to AVR. |
#7
Dang, I forgot, PAL = 576i is correct.
| Sponsored Links |
| Bookmarks |
| Thread Tools | |
Similar Threads for: Help on HDMI setup
| Thread | Thread Starter | Forum | Replies | Last Post |
| DVI HDMI or Component Video? | Mohan | Audio & Video Cables | 1 | 19-07-08 10:22 AM |
| Best HDMI upconverting AVR under 50K | spycatcher | Surround Amplifiers/Receivers | 9 | 01-03-08 12:17 PM |
| my HT setup | shamps | My Audio/Video Setup | 4 | 07-11-07 09:26 AM |
| My setup | madman29 | My Audio/Video Setup | 1 | 06-11-07 03:18 PM |
| Looking for Stereo Setup | Sim | Amplifiers | 6 | 10-09-06 09:57 AM |
