HiFiVision.com - Audio Video Hi-Fi Forum
Denon 1908 front panel locked. How to unlock?
Discuss Denon 1908 front panel locked. How to unlock? at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; Dear All, My Denon 1908 front panel has got locked on its own. If I ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 26th March 2010, 04:48 PM
Reputation points: 23
Sumain is on a distinguished road
Dear All,
My Denon 1908 front panel has got locked on its own. If I try to operate any knob other than power-on or volume, it does'nt work and I get the message "Front Panel Locked" on the display.
It is fully operational through the remote though. Except for Speaker Set A/B switching, which works only from the front panel.
I tried to reset the system with the procedure described in the manual. Worked once, then the system got locked again, and now even the reset sequence does not work.
Please help. I am in Noida. Can I show the system to someone?
Best regards
Sumain
Sponsored Ads
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Denon 1908 front panel locked. How to unlock?
Thread Thread Starter Forum Replies Last Post
How to easily make Professional looking front panel kaushik AV Lounge 5 3rd February 2013 07:53 PM
front panel design kaushik Amplifiers 5 26th December 2012 08:44 PM
Big problem in denon 1908 neo_49 Surround Amplifiers/Receivers 19 24th September 2012 07:42 AM
Buying a panel instead of TV anm Home theater PC (HTPC) or media PC 4 4th February 2010 09:16 AM
What should I buy Denon 1908 or Marantz 5002 govind What Should I Buy? 1 19th September 2008 09:33 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197
