HiFiVision.com - Audio Video Hi-Fi Forum
Problem connecting dvd to projector and sound out to Receiver
Discuss Problem connecting dvd to projector and sound out to Receiver at the Surround Amplifiers/Receivers within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi All, I have an Onkyo 606 AVR and now have a Optoma hd65 projector ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Components > Surround Amplifiers/Receivers
Surround Amplifiers/Receivers Multi Channel/Surround Amplifiers and Receivers
Advertise Here
Reply
Thread Tools
  #1
Old 9th May 2010, 10:59 PM
Reputation points: 11
hifi1975 is on a distinguished road
Hi All,
Unable to get sound through my AVR ( speakers ) . I have connected it this way
1) DVD Composite video out to Projector
2 ) DVD Digital out to AVR digital IN ( 2) and assigned Digital In (2 ) to VCR
My idea is to set the AVR to VCR mode so that i get the digital sound output
and play the movie through projector using the composite video
IT doesnt work ..just get the Video ..No sound ..Any flaw in my connections
Please suggest
Sponsored Ads
  #2
Old 9th May 2010, 11:48 PM
svenkateshsmart's Avatar
Reputation points: 254
svenkateshsmart is a jewel in the roughsvenkateshsmart is a jewel in the roughsvenkateshsmart is a jewel in the rough
Re: Problem connecting dvd to projector and sound out to Receiver
Composite video or component video? May I know which digital option, optical or coaxial? Did you try other audio options, for e.g., if you are using a optical, then coaxial or RCA stereo?
Cheers!
  #3
Old 9th May 2010, 11:55 PM
It is component video .. Red , blue , green from DVD player to projector IN .
digital out of dvd to digital in of AVR
Since i use one digital IN of AVR to connect another dvd player which i use for watching movies on tv , i am using another digital IN for this and have assigned the VCR option to it ..
So now i want to have the AVR in VCR mode ( for getting the sound ) and use the direct output from dvd to projector
Regarding other outputs , like connecting to stereo also do not work
  #4
Old 10th May 2010, 12:24 AM
Did you try swapping the cables and inputs, especially with the input that is working fine?
Cheers!
  #5
Old 10th May 2010, 12:36 AM
yes i did ..no luck ..
Does it have anything to do with - the receiver is expecting both audio and video signals to go through it ? In this case i am only sending the audio signal , as video is directly connected from the dvd to the projector
  #6
Old 10th May 2010, 01:44 AM
Reputation points: 2854
venkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond repute
Though you connection methodology is strange, there is nothing wrong with it.
With these connections, when you switch the AVR, do you choose 'VCR' as your input source in the AVR? If it is locked to some other source (such as DVD) you will hear nothing.
  #7
Old 10th May 2010, 08:35 AM
Yes i do change it to DVR
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Problem connecting dvd to projector and sound out to Receiver
Thread Thread Starter Forum Replies Last Post
Connecting Denon with a VGA projector sachinke Home Theatre Projectors & Screens 4 7th April 2010 04:50 PM
Sound Setting on AV Receiver hifi1975 Surround Amplifiers/Receivers 3 2nd November 2009 02:59 PM
Connecting Sound Card directly to Amplifiers. anooj30299301 Amplifiers 10 11th October 2009 01:15 PM
Strange problem with onkyo 340 R receiver anm Surround Amplifiers/Receivers 3 12th May 2009 12:51 AM
Denon AVR-2803 receiver - no sound o/p raj.nalekar Surround Amplifiers/Receivers 24 22nd August 2008 02:20 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
