Need expert advice on a 7.1 CH HT system.
Discuss Need expert advice on a 7.1 CH HT system. at the What Should I Buy? within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Originally Posted by kairalee Thanks Subash...floorstanders would not fit into my home decor....but I am ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Welcome Message & Introductions > What Should I Buy?
Notices
What Should I Buy? Not sure what model or equipment you should buy? It's a tough decision, so post questions and get help from our expert forum members!
Advertise Here
Reply
Thread Tools
  #11
Old 19th November 2008, 01:05 AM
hifipal4all's Avatar
hifipal4all is on a distinguished road
Re: Need expert advice on a 7.1 CH HT system.
Quote:
Originally Posted by kairalee View Post
Thanks Subash...floorstanders would not fit into my home decor....but I am going to re-audition the AVRs (the 606,787 ,875)...this weekend maybe.
Cheers.
Hello Kairalee ... Welcome aboard
You are right ... I have also heard the Jamo subwoofer ... It is pretty good for its price.
As fellow-pal Subhash suggested, try to go for the bookshelves instead of satellite speakers. There will be a lot of difference in sound. Atleast try to have a pair of bookshelves only for the fronts ... by this you will have a much better sound especially while listening music in stereo/direct mode.
Ramesh
Sponsored Links
  #12
Old 19th November 2008, 09:59 AM
kairalee is on a distinguished road
Quote:
Originally Posted by afj View Post
if you listen mostly to music why dont you look at a 2.1 system. or even a good 2.0 system. you'll get much better sound quality. whats your budget
Well I mostly listen to music...but have to consider the rest of the family's preferences...which is movies....with a budget of around 60K...I cant afford to go in for two systems...one for music and another for movies.
2.1/2.0 is undoubtedly for music lovers...but i need to compromise here...
So maybe as hifipal4all and subash suggested, I may go in for bookshelves, at least for the fronts....
Thanks guys!
  #13
Old 19th November 2008, 10:09 AM
Quote:
Originally Posted by moserw View Post
I would agree with afj here. Just a pair of Audioengine A5 speakers rock my boat for the music. That's for mp3s played from my PC system, not even Audio CD. If possible audition the Audioengine A5, you will be surprised at what they do.
2.0/2.1 systems are out of the question buddy...i may get banished from the living room if i go for that
5.1/7.1 is a must have.....(family pressure )
  #14
Old 19th November 2008, 11:04 AM
Ramesh
Thanks hifipal4all...
...Bookshelves only for the fronts is a good idea....will audition that and come back with an update...
...any suggestions on a good bookshelf set...I am auditioning the Elac 200 SERIES-BS 203.2 and the Onkyo D302-E bookshelves this weekend.
Thanks....
thanks...
  #15
Old 20th November 2008, 01:06 AM
Thanks....
thanks...
You are welcome pal .... I don't recommend any speakers of Onkyo. In my opinion & experience Onkyo brand speakers are not that good for music. So avoid Onkyo speakers an try the Elac.
Ramesh
NOTE: I have sent a PM to you.
  #16
Old 20th November 2008, 08:24 PM
subhash is on a distinguished road
hi,definetly onkyos are not meant for speakers,try out mezzo2 from morduant short, warfadale diamond series,or even jamos may hav good bookshelfs,keep looking out, but definetly not onkyo for speakers,u cud may be try out yamahas they are bak into speakers ,,,all the best
  #17
Old 21st November 2008, 08:12 AM
Quote:
Ok..so onkyo speakers are out...didnt realise that they are not even an option
Thanks guys!...its Jamo and Elac in this weekend audition.
  #18
Old 25th November 2008, 12:01 PM
Ok...so auditioned the following combo last weekend:
AVR: Onkyo TX SR575
Sub: Jamo Sub 300
Surround/fronts: Elac Cinema 1 Sats
Center: Elac CENTER 1 CM
I liked what I heard...played several of my favourite CDs and DVDs...(the rest of the family approved too), so went ahead and bought it...installed it and am enjoying every minute of it.
I did check out the bookshelves (Elacs, B&W and Polk). It did sound better, but i did not find that much of a difference to justify the cost difference between the Cinema Sats and the bookshelves...so voted against them. The Sats are doing a great job!
Thanks to everyone here... venkatcr, hifipal4all, subash, moserw ...your advice helped me very much.
Will post ownership experience in a few days.....
cheers.
  #19
Old 25th November 2008, 01:30 PM
venkatcr is just really nicevenkatcr is just really nicevenkatcr is just really nicevenkatcr is just really nice
Congratulations!
  #20
Old 25th November 2008, 03:09 PM
moserw's Avatar
moserw will become famous soon enough
AVR: Onkyo TX SR575
Sub: Jamo Sub 300
cheers.
Very happy for you kairalee! Have a blast and do disturb the neighbors (though not too much I suppose).
Sponsored Links
Reply
Bookmarks
Tags
av reciever avr, elac, home theatre, jamo, onkyo
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Need expert advice on a 7.1 CH HT system.
Thread Thread Starter Forum Replies Last Post
Need advice on upgrading my audio system doors666 Speakers 21 3rd October 2008 11:56 AM
Advice on setting up new stereo system for Music only ajey Amplifiers 13 8th September 2008 08:12 PM
Advice on entry level system via PC source NoVoices Introductions 14 19th August 2008 01:35 PM
Need Expert Advice barani Home Theater In A Box 6 19th July 2008 09:53 PM
need expert advise - innova car audio winXPHE Car Audio 8 13th June 2008 04:38 PM
Advertise Here
Copyright © 2006-2009, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
