✔Marantz NA6005 Network Audio Player for ₹23,999/-
Audiolab 6000CDT Dedicated CD Transport
Status
Not open for further replies.
HiFiVision
Super Moderator
Enjoy a thrilling high-resolution audio experience with the Marantz NA6005 network audio player, which features built-in Wi-Fi® and Bluetooth® wireless streaming via dual Wi-Fi/Bluetooth antennas, and built-in Spotify Connect®music streaming via your home network as well as AirPlay® and internet radio.
Featuring advanced audiophile design and construction, the NA6005 delivers superlative high-resolution audio via the reference-class CS4398 high current D/A converter that's coupled with a dedicated jitter removal system, along with 2.8 and 5.6 MHz DSD file compatibility (the file format for high-resolution SACD).
Via the available Marantz Hi-Fi Remote App (iOS; Android™) you can easily operate the NA6005 from your favourite portable device, and the NA6005 also features a convenient front-panel USB port for connection to portable devices and USB drives.
Exclusive HDAM Technology
Equipped with our renowned HDAM technology, the NA6005 features multiple HDAM and HDAM-SA2 modules in critical circuit blocks, including the analog output stage and the headphone amplifier circuit. Compared to conventional IC op-amps, HDAM discrete circuit elements technology delivers ultra high slew rate and high bandwidth to ensure purist audio sound quality.
Premium Grade CS4398 D/A Conversion
Featuring the reference-class high current CS4398 D/A converter handling PCM 24-bit/192-kHz and bitstream DSD, the NA6005 delivers superb fidelity and dynamic range with high resolution audio file formats including PCM and DSD.
Advanced Jitter Reduction System
Working in concert with the CS4398 D/A converter, the NA6005's jitter reduction circuit features a dedicated timing data re-clocking system that eliminates distortion caused by poor timing stability in the incoming audio data stream.
Built-in Wi-Fi & Bluetooth with Dual Diversity Antennas and Dual Band "N"
For optimum Wi-Fi and Bluetooth transmission and reception, the NA6005 boasts highly sophisticated next-generation technology that features dual diversity antennas with individual internal wave guides along with a powerful RF section equipped with dual core 300 MHz DSP processors that help to ensure solid, stable streaming and decoding, even in crowded urban environments.
The Wi-Fi section features dual band "N" high speed auto-band switching technology that constantly seeks out the optimum channels to ensure smooth and glitch-free listening. Via the WPS and iOS Wi-Fi protected setup buttons, you can connect your device with the NA6005 in moments. Via Bluetooth, the NA6005 will remember pairing information of up to 8 devices.
Built-in Spotify Connect Music Streaming; Apple AirPlay; Internet Radio
Available as a free (with ads) or paid subscription (no ads) streaming music service, Spotify boasts one of the largest catalogs of streaming audio recordings in the world, and the NA6005 features Spotify Connect app compatibility.
Owners of popular iOS devices, including the iPod touch®, iPhone® and iPad® can instantly stream their favorite tracks from their iTunes® library via AirPlay, which provides one touch automatic turn-on and source selection. The NA6005 is also DLNA® 1.5 certified for streaming content from your home PC, laptop PC or Mac®.
You can also choose from literally thousands of internet radio stations from around the globe, with a tremendous range of music genre choices.
Wide Range of File Types Supported, Including 2.8 & 5.6 MHz DSD
In addition to compatibility with conventional PCM audio tracks from digital audio sources such as CD, the NA6005 supports no less than 8 additional audio file types:
File TypeSampling Freq.Bit RateBit LengthFile Extension
WMA32/44.1/48 kHz48-192 kbps-.wma
MP332/44.1/48 kHz32-320 kbps-.mp3
WAV32/44.48/88.2/96/176.4/192 kHz-16/24 bits.wav
MPEG-4 AAC32/44.1/48 kHz16-320 kbps-.aac/.m4a/.mp4
FLAC32/44.48/88.2/96/176.4/192 kHz-16/24 bits.flac
ALAC32/44.1/48/88.2/96 kHz-16/24 bits.m4a
AIFF32/44.48/88.2/96/176.4/192 kHz-16/24 bits.aif/.aiff
DSD (stereo)2.8 MHz-5.6 MHz--.dsf/.dff
The NA6005 supports gapless audio playback with WAV, FLAC, ALAC, AIFF and DSD file types.
Standalone D/A Converter Capability
Via the optical digital input you can use the NA6005 as an audiophile D/A converter when connected to a digital disc player or other digital audio source with an optical digital output.
Audiophile Construction
The substantial chassis features dual layer chassis foundation construction. Instead of having just 1 large circuit board, the NA6005 features multiple individual circuit cards to prevent mutual interference - even the headphone output features its own dedicated circuit board.
Inside, the NA6005 is packed with premium grade active and passive components, including multiple high speed, high current Shottky barrier diodes that boast super fast recovery times and high reverse current protection, plus audiophile grade capacitors and precision tight tolerance resistors.
Standby Recharging System
Featuring smart device recharging, when a device such as a smartphone or a tablet is connected to the NA6005's USB port and the NA6005 is put into standby, it continues to charge the device. Once the device is fully charged, the NA6005 enters very low power standby mode for minimal power consumption (less than 1/2 watt).
Multiple Control Options
Supplied with an ergonomic remote control that's also compatible with Marantz Integrated Amplifiers, the NA6005 also supports the new Marantz Hi-Fi Remote app (iOS/Android) via your home network. The rear panel includes remote control input and output ports for direct connection to a Marantz disc player and an infrared (IR) flasher input for connection to an external control device, along with an RJ-45 LAN port.
Purchase the Marantz NA6005 Network Audio Player for ₹23,999/-
✔ FREE Shipping to most locations in India
✔ Official Manufacturers Warranty valid in India
✔ Brand NEW in Box & 100% Original
✔ Price includes GST
✔ Electronic products run on 230 volts
✔ Secure payment options & EMI
✉ Subscribe to the HIFIMART mailing list to get offers & deals on Home Theatre, Hi-Fi, Audio components and accessories.
RRR
Yes superb price for such a good product.
I too would have purchased it if i had not taken the Cambridge Audio Stream Magic.
HiFiVision
Super Moderator
This is back in stock. So please place your orders now if you missed it the last time.
tcpip
Bombay
Is this still available? I think the shopping site is showing it sold out.
rajivaryan1984
INDIA
This is great. Can you please advise if it can play all the formats like -- WMA,MP3,WAV,AAC,FLAC,ALAC,AIFF & DSD via USB Drive.
tcpip
Bombay
This is a question I too have -- about USB drives. Can these players all play music off, say, a 2TB USB hard driver formatted in NTFS? I've often tried to read the specs and descriptions of these players but have been unable to get a clear answer.
tcpip
Bombay
Thanks a lot, the link was really interesting.
Going by that page, this device does not clearly say whether it has the current drive needed by its USB port to power a USB hard drive. (Some expensive network players don't.) Secondly, it clearly omits NTFS from its list of file system formats, which means it will not play the vast majority of USB hard drives. FAT16, FAT32, exFAT and vFAT are all formats used by flash drives. Out of these, exFAT allows file systems in excess of 4GB, and is therefore popular with DAP these days with large microSD cards. But NTFS is not in this list, so this player won't be able to play the vast majority of USB hard drives.
There was another page I found in the same website you had given. This one talked about playing files over a network from a PC or NAS. This page removed the 5,000-file restriction, but failed to mention which network protocols are supported. One can only conclude that the Windows SMB protocol will be the only one supported, which will take care of the big majority of users.
In comparison, my open source media player (LibreELEC) running on Raspberry Pi supports NFTS, Linux ext2/ext3/ext4, and all the FAT formats, and doesn't have any 5,000 file restriction, doesn't mind a 600KB artwork image, and can access NAS drives using Windows SMB, Unix NFS, and Apple AFS protocols. Nice. :)
swamytk
Pune
Exactly. This is the reason I skipped this kind kind network player and built my own player having full control with us.
skroderider
Hyderabad
You're welcome.
Well said. I find most commercial devices have support only for archaic Windows-origin filesystems like FAT and FAT32, when so much more advanced ones like ext4 have been around for a long time.
tcpip
Bombay
Even if we keep aside the differences in the various file system formats, it's necessary that the commonest file system on a USB hard drive must be read by the network DAP. And that file system is the NTFS.
I have a different suspicion about this device which makes the entire file system discussion secondary. I have a suspicion that this device cannot power a USB hard drive. This means that even if I format my USB hard drive into exFAT format, this device may not be able to play it, because the hard drive may not get enough power from the USB port to start spinning.
Many TVs which support media playback from USB dongles have the same two problems: no support for NTFS and not enough power out of the USB port to power up the small USB-powered portable hard drives.
If any owner has been able to play back anything from a USB-powered hard drive through this device, it'll be great to hear from him.
tcpip
Bombay
I too have. I run LibreELEC on an RPi 3. I have added a HifiBerry HAT on the Pi to get good audio quality output.
But I miss a device like the Marantz, because it has better ergonomics and a screen. I can't use my RPi player without a TV, because it doesn't have any screen. This Marantz device or its less expensive Pioneer cousin (I forget the model numbers) don't need a TV to let you scroll through your folders and play audio.
The Cambridge Audio CXN (I hope I am getting the model number right) network media player can play USB hard drives and process NTFS. A friend has one, and had taken a copy of my entire music stash on a hard drive, and plays from it. But it's more expensive than this Marantz.
Status
