5.1 on a budget
arjunking
delhi
I am looking to setup a 5.1 system on a budget.
I was using a Samsung HTiB for past 7 years so I hope anything should be an upgrade to this.
I got Sony STR-DH550 for 21k.
Now I am looking speakers on a budget.
I don't want to go above 25k
Currently the options I have figure are:
1)Sony SA-CS910HT (These are the ones which are sold with this receiver by Sony in form of a package)
2)Yamaha NS-P40
Please suggest any other in similar range
Also could you suggest some good dealers in NCR.
Most of those I found on justdial have speaker packages starting at about a lakh.
You can try TAGA HARMONY TAV-606 V3 SPEAKER PACKAGE @ 27k
or you can consider also WHARFEDALE DX-1SE HOME THEATRE CINEMA PACKAGE @ 49k based on your budget.Both are available at hifi mart
Yamaha NS-P40 is good if there is space concern. As said above Taga tav606se is best choice if space is not a problem with in budget.
