5.1 Speakers set required for Denon 1911 --Budget 50K
Kolkata/Patna
Need suggestion for 5.1 speakers set for Denon 1911.
Have auditioned the
1) Paradigm cinema 70ct- Not satisfied
2) Sonodyne Genie1, Genie2 and genie3- Good.. but missing something
3) Polk RM6750- Ok.. missing the Bass depth
My budget is 50k-60k only for speakers and sub
has anyone auditioned Lithos Noa2 HTS..
Experts please help..
Pretty good for movies as well as music ...
In fact, this is one system which is a bit difficult to select amongst the many available, since it is good for both. Would say, it is better for music (in the 2 channel stereo mode) than movies (in actual 5.1 mode), if you are that particular.
A new kid is on the block, maybe, should in available in India in the next 2 months .... Cambridge Audio MINX.
My recommendation is a Wharfedale Package .....
Diamond 9.2 bookshelves - 2 pairs
Diamond 9.CM centre
SW-150 subwoofer
MRP of the above package is 70K. You may get for about 60K after discount.
Diamond 9.CM centre
SW-150 subwoofer
This is obviously a 'superior' package to the MS 70+, but, with a > hole diameter in your pocket!
BTW, whats your room size? .... a very important question ...
MS 70+ would be on the brighter side, while the Diamond 9 pack laid back. Depends a lot on how you like your music. AUDITION is a must ...
Very important fact that i missed.. room size? it 11x12
So i think ms70 will be perfect. How is mordaunt short alumni 2.. it is available in kolkata for about 55k but no set up for audition. Any opinion on this.
